#1023 | |
You could do -2/-2, but what will work best will ultimately come down to your setup and driving conditions. Too much static camber will make the car less stable in a straight line and give less grip under braking, so you want to balance it with how much you actually need. -1 front / -2 rear is pretty mild, but will definitely give you a bit more grip in hard cornering.
#1024 | |
#1025 | |
Drives: FR-S Whiteout
#1026 | |
It's all a balance. Too much dive will make the car squirm under braking, and too stiff of sway bars takes away independent wheel travel which can make it handle a bit funny over bumps. You're definitely right that the ideal setup for anyone is going to involve their preference to a large amount though.
| The Following User Says Thank You to wparsons For This Useful Post: | solidONE (03-18-2014) |
#1027 |
Drives: Raven Fr-S
Sorry for being such a suspension newb, but what size bars should i get? I have a budget earmarked for both front and rear sway bars. Will the RCE bar set be a good fit for my application?
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#1028 | |
Drives: '13 BRZ Ltd
It's not rare to see the inside rear of a GTI or the inside front of a Porsche lifting wheels - it's because the other end is relatively softer, the chassis has some torsional rigidity, and the softer end in roll is picking up the inside of the stiffer end. So the end of the car that has the inside wheel picking up has more uneven distribution across it's inside/outside tires and is transferring more weight (it actually has zero weight on the inside lifted wheel). Think of a car with corner weights Front 100 100 100 100 Rear Put it through a left turn that generates lateral acceleration that causes a total weight transfer of 100 lbs, and assuming identical stiffness front and rear, you have 50 150 50 150 (assuming no fore/aft weight transfer in this example, no braking, accel, etc) Note the total weight on the right side is now 300 lbs, total weight on inside is 100 lbs. If you stiffen the rear by some amount, you might get something like 75 125 25 175 Still same totals as before, but now the front is more evenly loaded, and more evenly loaded tires generate more aggregate grip (since tire friction reduces as load increases). In the case where the rear is lifted, you'd get 100 100 0 200 This is awesome for front grip and terrible for rear. Two tires evenly loaded will generate more grip than one tire supporting all of the load. Note that since we didn't have any fore/aft weight transfer, the front axle weight and rear axle weights totaled 200 lbs in all scenarios. And all examples under cornering load always maintained 100 lbs of weight shift, so left side always totaled 100 and right side always totaled 300. So I didn't mean for that last example to show no load xfer in front and all in rear, as if the front isn't doing anything, realistically this doesn't make a lot of sense but it's just how my example numbers happened to end up. It would have played a little better if I assumed more weight xfer than 50 lbs. In a completely unreasonable scenario where the chassis has zero torsional rigidity, front/rear roll stiffness wouldn't affect each other. |
| The Following 7 Users Say Thank You to Wepeel For This Useful Post: | Assunta (03-18-2014), Dimman (03-18-2014), Racecomp Engineering (03-18-2014), RJasonKlein (09-27-2015), Shankenstein (03-18-2014), solidONE (03-18-2014), ZDan (03-18-2014) |
#1029 | |
Drives: '23 BRZ
Stiffer rear will increase outside rear loading, putting it more in the nonlinear part of the grip vs. load curve where increasing load doesn't give as much increased grip, thus reducing grip at the back of the car. |
| The Following 4 Users Say Thank You to ZDan For This Useful Post: | Dimman (03-18-2014), Racecomp Engineering (03-18-2014), RJasonKlein (09-27-2015), Wepeel (03-18-2014) |
#1030 | ||
Last two posts above are good on weight transfer!
Also it helps put power down on corner exit. A little stability is nice. With firmer spring rates (in the 10k range) we have used rear biased springs. We do have a lot of auto-x customers but we do a lot of our testing at the track. Quote:
![]() - Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | solidONE (03-18-2014), ZionsWrath (03-18-2014) |
#1031 |
You guys are forgetting that more roll stiffness at one end of the car will also increase weight transfer to the other end longitudinally. You'll never lift an inside front or rear tire if the weight isn't shifting to the other end of the car. A FWD car with the inside rear tire in the air has a TON of weight on the outside front, a RWD car with the inside front tire in the air will have a TON of weight on the outside rear.
Without doing REALLY complicated math, I would still bet that if you looked at how much weight is actually on each tire you would find that stiffening an end results in less weight on the outer tire at that end because more weight went to the other end.
#1032 | ||
Drives: '23 BRZ
Whatever you do with front/rear roll distribution, it doesn't affect the front/rear load distribution OR the left/right load distribution. I.e., RR + LR and LF + LR are the same for a given combination of lateral and longitudinal accelerations, not affected by roll stiffness distribution. Roll stiffness distribution affects dynamic corner loading, RR+LF and LR+RF, under lateral or lateral/longitudinal combined accelerations. Quote:
Stiffening one end of the car will result in MORE load on the outer tire at that end of the car. That's what "stiffening" means! More load per deflection. Relative to the suspension, the body of the car is fairly rigid. The amount of ROLL is the *same* at both ends of the car. Therefore, you'll get more lateral load transfer at the *stiffer* end of the car. |
#1033 |
I'm not talking about under braking... I'm talking about how stiffening the rear will increase weight transfer to the front (or vice versa).
I'm not arguing that increasing rear roll stiffness won't increase weight transfer to the outside rear, all I'm saying is that you're also getting more weight transferred to the front end overall as well.
#1034 | ||
Drives: '23 BRZ
Fore/aft weight transfer is longitudinal acceleration in g's multiplied weight multiplied by the c.g. height and divided by the wheelbase. No braking or acceleration, no fore/aft load transfer. |
#1035 |
Bumpstops... I wonder how much of the 'at-the-limit' handling characteristics I attributed to springs, but were in fact bumpstops. I always assumed that once the bumpstops were engaged in the the compression stroke the effect would be very very abrupt. I don't think this is the case with our 86's stock bumpstops.
bumpstops. |
#1036 | |
i'm sorry, what?
Drives: Canada
on a smooth road you wouldn't feel the transition but next time you take an off/on ramp at speed, aim for a pothole with your loaded front tire.... if you get kicked up harshly with almost no delay then you know you've had no more travel left for that bump.
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
