#1009 |
Drives: GT86
#1010 |
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
I finally decided to start logging to "fine tune" my tune... and this happened.
Is this a bad connection to the OFT or what? I'm using the OBDII Y splitter cable from amazon recommended by many people here, and the other end is connected to a P3Cars vent gauge. http://www.datazap.me/u/tatovalverde...&mark=117&hg=5 Help please
#1011 | |
also the to devices may use same addressin on can buss and interfere with each other |
| The Following User Says Thank You to steve99 For This Useful Post: | tato.valverde (03-21-2016) |
#1012 |
I would suspect as steve99 said. Y splitter is not ideal to use with OFT at least in my case. I had similar issue when I tried y splitter with oft and obdii bluetooth for torque app. It sure seems like interferes each other when both are hooked up together.
| The Following User Says Thank You to nunonuna For This Useful Post: | tato.valverde (03-21-2016) |
#1013 |
I'll try again next weekend, hopefully i can get some clean pulls. Thanks!!
And on another note, I'm bringing my car to the shop tomorrow, and last time it was there, they took it out for a test drive, going pretty hard... Since I don't want anyone going on joyrides with my car, i thought i would make a map with the rev limiter at 3000rpm (3000rpm limiter, 2950 resume). Is this dangerous? Any downsides? Or is there anything else I should change? Thanks! |
#1014 | |
Drives: UK GT86
.: Stealth 86 :.
#1015 |
I disconnected the Y cable, and the log looks good now =)
Can you take a look at it? It's a 3rd gear pull in a slight uphill. http://www.datazap.me/u/tatovalverde...-5-6-7-9-11-12 Also, about the map for the shop.. If anyone is trying to do it, remember to disable LC, because i didnt and it kicked in at 1000rpm lesson learned
#1016 | |
It running a bit on the rich side past 5000 rpm, maybe adjist the ol maf scaling to correct, will pick up a bit of power |
| The Following User Says Thank You to steve99 For This Useful Post: | tato.valverde (03-22-2016) |
#1017 |
Drives: 15' Frs
Data Logs! Post them here.
Hey guys i did 3 data logs. I got JDL UEL headers installed about a week ago and deiced to do a data log. Did you think it is safe running this? I think its running rich but want your opinion. http://datazap.me/u/jlim7/2nd-and-3r...log=0&data=1-8
Thanks |
#1018 |
So I've been reading your threads and Wayno's threads on MAF scaling... is that java program from RomRaider's forums the best option to go with? Or is it better to tweak the tables manually?
#1019 |
Drives: 2015 STi
Hey guys, my hosting provider is having DNS issues. They've identified the problem apparently so hopefully Datazap will be back up shortly! Sorry for the inconvenience
https://status.digitalocean.com/
2016 340i xDrive / 6MT / M Sport
www.datazap.me - free shareable interactive datalog viewer |
#1020 |
Drives: 2015 STi
looks like datazap is back online, hopefully it stays up!
(that's what she said)
| The Following User Says Thank You to jpsimon For This Useful Post: | DocWalt (03-25-2016) |
#1021 |
Drives: Toyota 86
Hi,
I've done dyno runs while finding cam timings. Considering how to enhance 6600~ rpm. Any suggestion? Thanks. http://datazap.me/u/makinenkr/201512...&data=1-6-7-13 Mods: HKS catted EL header OP stock from FP K&N panel filter |
#1022 |
Drives: UK GT86
What cam timings did you get in the end?
Could probably make a bit more by targeting a bit richer to allow a little more timing advance. Dyno chart looks quite good though. Why the request at 6600? Due to the way the power drops off? If so, not much you can do.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | makinen (03-24-2016) |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
