Old 01-26-2014, 02:51 PM   #1009
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
A cell phone holder would probably work. The kind that looks like a clamp.
I'm assuming you'll need one for a large phone, like a Note.
Thanks,
Any idea on the dimensions of the OFT, specifically the width?
I came across the Beatsonic universal tablet mount, that is 5.7" wide at the top, and adjusts to different lengths, along with a specific BRZ/FRS tablet mount:
http://www.beatsonicusa.com/mobile-a...der/qba29.html
http://www.beatsonicusa.com/qbf13.html
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 01-26-2014, 04:32 PM   #1010
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I used the EZ Pass Velcro (Made by 3M and insanely stong). It worked really well covering the Front defroster button (and I could still access everything behind it with it in place), but it was too cold when I mounted the car side and it fell off. I'll a new piece up when it gets warmer and it should be perfect.
Luckrider is offline   Reply With Quote
Old 01-26-2014, 05:46 PM   #1011
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Originally Posted by smbstyle View Post
Is there any mounting solutions out for the OFT to keep an eye on live data while driving or on track? (i.e. oil temps, water temps, etc?)
I use the Grip Go!
Vlady is offline   Reply With Quote
Old 01-27-2014, 10:39 AM   #1012
dom
86 owner
Drives: Toyota 86 GT
May I ask if there are any way to correct the mis-displayed Gear number if I have changed the final gear from 4.1 to 4.556? As the gear number will only show 5 but not 6. Thanks
dom is offline   Reply With Quote
Old 01-27-2014, 10:49 AM   #1013
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
You'll need to tweak the table seen here in RomRaider:
I couldn't find it in TunerPro, but it may still be defined and I just missed it.
AdrianG is offline   Reply With Quote
Old 01-27-2014, 11:08 AM   #1014
Luckrider
Luckrider's Avatar
That is what you will need to edit, but it will take some math to figure out exactly what you need to input as the REV/mile.
Old 01-27-2014, 12:32 PM   #1015
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
The scaling units are engine rev/mile, calculated as 96560.6/x
Td-d is offline   Reply With Quote
Old 01-27-2014, 02:33 PM   #1016
Sargy
Long Distance Driver
Sargy's Avatar
Thought I would share my Dyno videos and Plots with you all.
My following mods:
TRD Intake, Stock Header, Stock Overpipe, Motiv Catless front pipe with a cutout, stock mid pipe, JDM TRD Quad axleback, OTS v1.42 Stage 2 EL E85 map + E85 fuel
Represents 4th gear pull with Cutout in the CLOSED position
Represents 4th gear pull with cutout in the OPEN position.
Weather:58F, 39% Humidity
Headers on the way!
Video 1 represents blue and video 2 represents red
[ame="http://youtu.be/UcEpPg62bEc"]http://youtu.be/UcEpPg62bEc[/ame]
[ame="http://youtu.be/4mHR-BOcuaY"]http://youtu.be/4mHR-BOcuaY[/ame]
Sargy is offline   Reply With Quote
Old 01-27-2014, 02:41 PM   #1017
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Awesome info! Could you post STD corrected graph since that is what most people seem to use on this forum?
My following mods:
Headers on the way!
Old 01-27-2014, 03:09 PM   #1018
Sargy
Sargy's Avatar
Done
Old 01-27-2014, 05:33 PM   #1019
Luckrider
Luckrider's Avatar
@shiv@vishu, can you explain why FBKC is turned off above 7,250 RPM? I noticed in my logs that the FBKC went to zero at the top and and it wasn't until I found that tab in RR that I realized it was by design. Is there anything wrong with bumping this up to say 7,450 RPM?
And just so you know, I am working on a better Cold Start map still. It hasn't been above 30° F AT ALL here so I can't get decent data there. Feedback I have heard is that it is harder to start up there with my corrections, and from the research I have done, that makes sense based on the changes I made.
Old 01-27-2014, 07:52 PM   #1020
jamesm
7250 is actually higher than stock iirc. i believe the stock value is around 6500. the reason is because noise is a problem at those high rpm, causing it to pull timing unnecessarily. i haven't seen this actually happen, but that's the theory.
Old 01-27-2014, 07:59 PM   #1021
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
My following mods:
Which cutout are you using?
Old 01-27-2014, 09:42 PM   #1022
jamesm
hold on... you say it 'went to zero' above 7250? does that mean it wasn't zero the whole time before? if so, das no good.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
