05-01-2017, 12:53 AM | #995 |
Drives: 2015 Scion FRS
I did managed to flash it back to stock, but at the same time I'm worried that they can check the last time i flashed to stock (which was directly before I brought my car to toyota). I really hope they wont find out tho..
05-01-2017, 01:00 AM | #996 | |
05-01-2017, 06:03 AM | #997 | |
If
When you flash to stock with oft its 100% stock rom no licencing or anything else left behind. Checksum is same. A reflash looks same as an ecu reset to them ie removing battery connection or a flat battery as it just resets all the timers in ecu. Thier is no realtime clock in ecu it just has counters from last ie it was reflashed or reset ie power removed or flat battery. It may be possible for some super guru from toyota or subaru to dig further but ive not seen definitive proof that its possible evertthing seems to be lost on power rest besides the rom area. It unlikey they will investifate further if ecu rom is stock and you don't have substiantal engine mods or something like an oil cooler that couls have leaked |
The Following User Says Thank You to steve99 For This Useful Post: | tato.valverde (05-02-2017) |
05-03-2017, 02:25 AM | #998 |
i just did a quick data log and saved in csv file. anybody with better knowledge free to take a look for me.
i also set my alarm to adv multi <1. i see it blinks sometimes when i look at the parameters but is always showing 1? ltft once in a while will get to around -10.5 as well thanks, im new at this. im running stage1 oft tune. http://www.datazap.me/u/brrrzzz/log-...7?log=0&data=1 Last edited by BRRRZZZ; 05-03-2017 at 02:40 AM. |
05-03-2017, 03:19 AM | #999 | |
Iam of 1 all the time is good means minimal knock Afr is goid Fuel trims are gois except as idle so is ok If it not causing you any hesitation off idle dont worry, if your kean you could take 5% out of the maf fliw numbers at the idle flow rates |
The Following User Says Thank You to steve99 For This Useful Post: | BRRRZZZ (05-03-2017) |
05-03-2017, 03:36 AM | #1000 | |
Just wanted to make sure everything looked alright. still going to look at params day to day, but now i am confident to push it hard. |
05-03-2017, 02:05 PM | #1001 |
is the stage1 original tune on the oft 91 or 93oct?
i modified a 91oct stage 1 tune on romraider to get launch control, and it doesnt seem to want to pull as hard as the stage 1 original tune that came preloaded on the oft. |
05-04-2017, 11:21 AM | #1003 |
Drives: 2015 BRZ Limited MT
Doesn't the original OFT tune come with launch control enabled ?
05-04-2017, 11:55 AM | #1004 |
05-04-2017, 02:38 PM | #1005 |
btr.life
Drives: 2022 GR86
I am pretty sure they do not have launch control enabled by default. Mine did not, that is for sure (when loaded with OTS maps).
05-04-2017, 02:49 PM | #1006 |
Drives: frs
Weird, mine came with LC and was set to 5k rpm
05-04-2017, 02:56 PM | #1007 |
btr.life
Drives: 2022 GR86
Really? How did you activate/enable it?
Maybe I had it and just didn't know how to use it :p
05-04-2017, 03:01 PM | #1008 | |
TRACKBREAD
The ots maps are set to 5500 rpm, that might be why you haven't noticed. When under 6 mph the rev limit is lowered to the LC rev limit. Just push the clutch and gas to the floor, it should hold revs at 5500rpm, let the clutch go and you launch in a cloud of tire smoke and clutch dust. :P Sent from my iPhone using Tapatalk |
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
