Old 03-31-2015, 12:14 AM   #995
lamune
Drives: 14 WRB BRZ Limited MT
Originally Posted by PandaSPUR View Post
What do you mean by short side and long side?
You can install it inline either on the passenger side(short) or on the driver side (long)
Build:
"AWW YEA" < RIP
lamune is offline   Reply With Quote
Old 03-31-2015, 12:25 AM   #996
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
I'm not sure what you mean either...you are supposed to use both sides.
Phaedrus29 is offline   Reply With Quote
Old 03-31-2015, 12:35 AM   #997
lamune
Step 3: Unplug headlight connector on EITHER side.
Step 4: Plug new connectors inline on EITHER side, between headlight and vehicle harness.
Build:
"AWW YEA" < RIP
Old 03-31-2015, 12:47 AM   #998
Phaedrus29
Phaedrus29's Avatar
I just checked the install video again...he does say connect them on "either" side, but you are supposed to do both.
Old 03-31-2015, 12:56 AM   #999
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Yep.. we had the same issue earlier in this thread lmao.
Install both sides. See my pics a few posts up.
I wonder how many RMAs that slip up in the video has caused so far
PandaSPUR is offline   Reply With Quote
Old 03-31-2015, 12:59 AM   #1000
lamune
Just tried inline both sides, same result:
Build:
"AWW YEA" < RIP
Old 03-31-2015, 01:03 AM   #1001
kakarot1657
kakarot1657's Avatar
Drives: 2013 Subaru BRZ (Galaxy Blue)
Got my kit on Friday and installed. Everything looked good and it works as advertised.
kakarot1657 is offline   Reply With Quote
Old 03-31-2015, 01:08 AM   #1002
Phaedrus29
Phaedrus29's Avatar
Try to completely disconnect the connectors and then reconnect them. Seems like a crazy coincidence that you are getting the same result after only connecting one of the sides and then now connecting both. Take pics or video of how you have it connected on both sides and we can try to help out. Maybe it is defective, but just seems like only having half connected WAS your issue.
Old 03-31-2015, 08:25 AM   #1003
PandaSPUR
PandaSPUR's Avatar
Agreed. And take a look at the pins in the connectors when you reconnect, it was a tight fit for me because the pins refused to line up correctly on their own and I was afraid I'd misalign one of the pins.
Old 03-31-2015, 01:53 PM   #1004
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Glad to see some people are having everything working. Still waiting on my RMA to come through. To clarify guys... You need to connect them on BOTH sides. The instructions are pretty clear about that.
@kakarot1657 Lighting in your pics are really weird. Almost looks like the FRS blue.
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
kakarot1657 (03-31-2015)
Old 03-31-2015, 01:58 PM   #1005
kakarot1657
Gauging interest in Plug n Play option for BRZ Boomerang to turn ON with DRLs...
The color is GBS it's not WRB.
Old 03-31-2015, 03:25 PM   #1006
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
As I mentioned in an earlier post, I'm wondering if the BRZ needs to go through a few run cycles before the unit works properly. I had the identical same problem as shown in [Ron]'s video, but after a few days of driving, it suddenly started working, and has been working ever since.
I originally reported the issue to DD, and they immediately issued an RMA. I just received the new replacement unit yesterday, so I pulled out my DD unit (that now works fine) and put in this new one. However this new DD replacement unit did not work, and had the exact same problem I originally had! (as shown in [Ron]'s vid)
To test, with parking brake down I pulled the DD fuse out and replaced with stock, and the DRL's came on. I swapped back to the DD fuse, but still no luck. Drove up the street and back, shut the car and lights on/off a few times, and still no dice. Then I swapped my original one back it, and it worked fine! I left my original one installed in the car.
I'm scratching my head on this one... looks like I'll just return the new replacement unit that I had just received. For those of you that have experienced this same problem, have you tried driving the car with the unit installed for a few days to see if it eventually started working?
996garage is offline   Reply With Quote
Old 04-01-2015, 08:04 AM   #1007
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
Received mine.
.It's a JDM labelled (for non-USDM I suppose)
Works fine outside in the front but...
Lights up rear lights and all center dash is dimmed !
GPS turn to night mode and I can't see the clock anymore by day cause it's so darken !
Seems to be issues with EUDM...
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 04-01-2015, 08:28 AM   #1008
banane63
banane63's Avatar
Afer a quick check on G4400GE wiring diagram page 192-193, it seems that clearance lights (boomerangs) are always connected to rear lights...
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 04:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 03:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 10:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 10:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
