Old 03-07-2018, 12:38 AM   #995
christoc
christoc's Avatar
Drives: None
Much better link thanks!
christoc is offline   Reply With Quote
Old 03-09-2018, 09:04 AM   #996
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
As mentioned during the SSC Town Hall meeting, TR has created a central web page for SSC related topics that has just gone live:
https://www.tirerack.com/content/tir...s/SCCASSC.html
Direct link to suspension install instructions: https://www.tirerack.com/tires/tiret...jsp?techid=338
Baseline Set-up Recommendations: https://www.tirerack.com/tires/tiret...jsp?techid=339
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
The Following 4 Users Say Thank You to Imp For This Useful Post:
dowroa (03-09-2018), JakeRogue (03-09-2018), Open Loop (03-09-2018), ryejeff (03-09-2018)
Old 03-09-2018, 09:32 AM   #997
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
Thanks!
I had a shop install my set up and only knew about the roll bar settings. I did not know the shocks were adjustable. Can anyone explain that to me in more detail? I am nOOb
JakeRogue is offline   Reply With Quote
Old 03-09-2018, 01:29 PM   #998
Open Loop
2013 FR-S Whiteout / SSC
Originally Posted by JakeRogue View Post
Thanks!
https://www.koni.com/en-US/Cars/Tech...stment-Guides/
The shocks have an adjustable rebound. Compression is not affected by adjustment. Make sure you got at least one of the adjustment tools back from the shop where you had the install done.
Open Loop is offline   Reply With Quote
The Following User Says Thank You to Open Loop For This Useful Post:
Old 03-09-2018, 05:49 PM   #999
TrqlessWonder
Drives: 2014 FR-S
If they tossed the knobs, Tire Rack and/or Koni is quite good about getting you a replacement one. You'll want one with the riser/stadoff on it to make the rears easier to reach. Fronts, it really doesn't matter.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
The Following User Says Thank You to TrqlessWonder For This Useful Post:
Old 03-09-2018, 05:52 PM   #1000
JakeRogue
JakeRogue's Avatar
I found the adjusters. But I wonder was this black thing is:
Old 03-09-2018, 05:53 PM   #1001
blkwrxwag
Drives: DS FRS
The black thing is just a protective adjustment knob condom for packaging. Not needed when installed.
-Max H.
blkwrxwag is offline   Reply With Quote
The Following 2 Users Say Thank You to blkwrxwag For This Useful Post:
JakeRogue (03-09-2018), TrqlessWonder (03-12-2018)
Old 03-09-2018, 07:08 PM   #1002
Open Loop
I am interested in whether anyone has observations regarding the baseline alignment recommendations. Does anyone recommend any different settings based on their own initial experience? Thank you.
Edit: I am looking for the best baseline settings for autocross on a smooth asphalt course, and not concerned about additional tire wear or darty steering on highway.
Old 03-09-2018, 07:22 PM   #1003
Open Loop
Another question for y'all. Per the installation instructions at the Tire Rack website:
After the alignment is completed. The steering angle must be re-calibrated for the OEM stability control to operate normally. If this is not done, the stability control may interfere with performance driving scenarios. For this particular vehicle, the steering angle was -3.2 degrees off until re-calibrated.
How is this re-calibration performed? Thank you.
The Following 2 Users Say Thank You to Open Loop For This Useful Post:
H1C (03-12-2018), JakeRogue (03-09-2018)
Old 03-11-2018, 03:45 AM   #1004
christoc
christoc's Avatar
Drives: None
I found this (haven't done this myself, looks like Techstream can be acquired for cheap)
https://demos.starbase7.net/t3Portal..._rm_index.html
1. ROTATION ANGLE SENSOR INITIALIZATION AND TORQUE SENSOR ZERO POINT CALIBRATION
NOTICE:
Initialize the rotation angle sensor and calibrate the torque sensor zero point if any of the following conditions occur:
The power steering ECU is replaced.
The steering column assembly is replaced.
Steering effort differs between turning left and right.
HINT:
When rotation angle sensor initialization and torque sensor zero point calibration are performed, the rotation angle sensor value initialization and the torque sensor zero point calibration are performed at the same time.
(a) Inspection before calibration
(1) Turn the ignition switch off.
(2) Connect the Techstream to the DLC3.
(3) Turn the ignition switch to ON.
(4) Turn the Techstream on.
(5) Enter the following menus: Chassis / EMPS / Data List.
(6) Check the values by referring to the table below.
'16 FR-S SpecFRS.com
The Following 2 Users Say Thank You to christoc For This Useful Post:
H1C (03-12-2018), Open Loop (03-11-2018)
Old 03-11-2018, 10:38 PM   #1005
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
My second set of wheels won't be here in time for Dixie and my current set of Falkens are well into the wear bars after more than 100 runs. In the dry, they are *still* well-behaved, serviceable tires, but on the wear bars, they were pretty much useless in the wet.
I'll mount the new tires for Dixie, but I want to keep these old ones, mount them on the new wheels, and do some back-to-back testing once I get the new ones to 50-ish runs, just to try and quantify how resilient these tires are.
I think the Falkens were a great choice for a spec tire.
Twinz is offline   Reply With Quote
Old 03-12-2018, 12:11 AM   #1006
tony_r
tony_r's Avatar
Drives: '15 STX
Mine are done and maybe have 10 runs left in them. They're slicks, basically. Any I got about 120-130 runs out of them, which was about the same as the RE71R/Rivals. A little disappointed given their performance. At least they're cheaper.
tony_r is offline   Reply With Quote
Old 03-12-2018, 11:37 AM   #1007
chkltcow
Drives: 2013 FRS White w/ cone marks
I'm running 2.2 camber in the rear like Tire Rack suggests, and even though I've only done one event on them, I think it's too much. This was at ZMax which is perfectly smooth asphalt and pretty high grip. I'm just not even touching the last 1/2" of tread, even dropping the tires down to 28psi. In a few months, I'll take my car back to the alignment shop and I'll probably end up closer to 1.8 in the rear so I can use all of my tire back there.
Other than that.... looks good. I'm currently running zero rear toe, but I think their suggestion of 1/8" total toe in is probably more drivable for most people.... but... I like a loose car.
chkltcow is offline   Reply With Quote
The Following 2 Users Say Thank You to chkltcow For This Useful Post:
JakeRogue (03-12-2018), Open Loop (03-12-2018)
Old 03-12-2018, 04:24 PM   #1008
Imp
Bring out your dead
I hate the fact that you already have that many runs, and my parts are still in my basement, never mind has my car even seen a cone...
--kC
The Following User Says Thank You to Imp For This Useful Post:
Shark_Bait88 (03-12-2018)
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
