10-12-2022, 01:25 PM | #995 | |
Drives: 2022 MT Neptune GR86 Prem.
I would think that RTV in the oil may look like an inverse bell curve. |
10-12-2022, 01:34 PM | #996 | |
The bigger risk is the mechanical "chopping" off as the two mating surfaces are torqued together and thin the sealant out to the point that the oil flow can separate it. This is something that will happen quickly but sections that hold on should hold forever.
10-12-2022, 01:47 PM | #997 |
Drives: 2022 BRZ sport-tech
I found this very interesting, in Kevin Vo's FA24 tear down video, one of the bolts that was removed from the timing cover was caked with WET RTV! Below is the screen shot of the video.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
10-12-2022, 02:34 PM | #998 | ||
Drives: Crapcan
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
10-12-2022, 02:42 PM | #999 | ||
On some of the newer engines they are also starting to apply some kind of sealant stuff when sliding hoses onto fittings. Likely to increase seal longevity? |
10-12-2022, 02:48 PM | #1000 | |
10-12-2022, 03:52 PM | #1001 |
Resident Grannyshifter
Drives: 2022 BRZ w/ STI aero
Would love to see these available as a potential track upgrade, even if only for peace-of-mind. Thanks for supporting the platform!
10-13-2022, 06:56 PM | #1002 |
btr.life
Drives: 2022 GR86
I'm about 1k miles from pulling my oil pan a 2nd time and checking the pickup again. Curious to see how much more accumulates as well.
The Following 11 Users Say Thank You to justinco For This Useful Post: |
10-18-2022, 02:08 AM | #1003 |
Drives: 2022 GR86
So basically a pan drop at 1k, 5k, and every ~10k is the only way to sleep tight?
Follow the build thread for my GR86!
10-19-2022, 04:40 PM | #1004 |
FT86Club Official Vendor
Drives: 2023 BRZ
Another data point to add to the collection. 2000kms, 3 track days. 2023 Brz. As you can see from the oil pan, all of the excess rtv is still intact. However, the pickup still has rtv, which is likely from the timing cover. |
10-19-2022, 06:12 PM | #1005 |
Drives: 2022 GR86
10-19-2022, 06:46 PM | #1006 |
Drives: WR Blue Pearl 2022 Subaru BRZ
10-19-2022, 06:49 PM | #1007 |
Drives: 2023 BRZ
11-01-2022, 05:06 PM | #1008 |
Some design tweaks coming, but the fitment to the pickup is spot on. It's on there so well, I broke two, removing them :P
The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
