Old 04-09-2018, 02:20 PM   #981
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by enigma View Post
Well friends, if anyone is in the market for a Cosworth Supercharged 86, I just listed mine for sale: http://www.ft86club.com/forums/showt...42#post3069842.
The car has been absolutely wonderful, and it's been one of the most enjoyable cars I've ever owned, but I've got my eye on something else, and I unfortunately won't be able to have two toys.
NOOOOOOOOOOOOOOOOOOOOO
MS, CSCS, TSAC-F, CPT
Old 04-12-2018, 10:44 AM   #982
weederr33
weederr33's Avatar
@Matt@Cosworth
Matt, what all did you guys change out when you built your engine for the Cosworth FA20? I assume pistons, and rods, but did you switch the bearings and any valve train?
The Following User Says Thank You to weederr33 For This Useful Post:
nikitopo (04-12-2018)
Old 04-13-2018, 08:05 AM   #983
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
pistons, rods, head gaskets and valve springs
plus ported it
stock bearings
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
weederr33 (04-13-2018)
Old 04-13-2018, 10:00 AM   #984
weederr33
weederr33's Avatar
plus ported it
stock bearings
The stock bearings worked with no issues?
Old 04-15-2018, 05:03 AM   #985
Matt@Cosworth
no problem,
well so far anyway
nikitopo (04-15-2018)
Old 04-24-2018, 10:45 AM   #986
Ric Ng
Drives: 2013BRZ sold, Bougth 2018 BRZ
Matt@Cosworth
I am a Hong Kong 2013 BRZ Ex-owner, and 2018 BRZ Prospective owner.
I am looking for your supercharge for my car which most of the time are daily use, therefore durability is my major concern. Due to the track is far away from my place at mainland china, I only run on track fews days per year.
I read all 71 pages of this forum and i would like to ask about:
1. You / Your company provide services of ECU mapping for your SC? Any charges?
2. For different fuel map for different octane fuel? Because the China fuel is bad quality which different from Hong Kong
3. For fuel map changing, can be it a one touch key operation or need a computer to change it?
4. Is it not allow to install any tower bar after installed the Cosworth SC?
5. Do your company have the SC total weight?
Ric Ng is offline   Reply With Quote
The Following User Says Thank You to Ric Ng For This Useful Post:
nikitopo (04-25-2018)
Old 04-24-2018, 12:06 PM   #987
weederr33
weederr33's Avatar
Originally Posted by Ric Ng View Post
Matt@Cosworth
I think I can answer a few of those questions.
1. They do provide ecu mapping though you may need to buy the Cosworth ECUTek mapping kit.
2. Cosworth has done extensive logging of various fuel ratings all over the world. Given the quality of fuel in China/ Hong Kong you may need to data log it.
3. The stage 1 & 2 come with several maps. Simply pull the cruise control stalk and push up to select a map. It will be shown via the tachometer.
4. To my knowledge there are no strut towers that fit the kit since the intercoolers are rather larger (which is good!). Though you can always change the v-bars.
5. The weight I do not know.
@Matt@Cosworth can elaborate on anything I've said. As could @ajc209
Old 04-26-2018, 05:53 PM   #988
Matt@Cosworth
Hello
We have a few owners running our kit in China so hopefully I already have a map for your fuel
Summit racing do a brace that fits over our kit see here
http://www.gt86ownersclub.co.uk/foru...09_page71.html
I think the kit weighes in at 63 kg or therabouts
weederr33 (04-26-2018)
Old 04-29-2018, 12:50 PM   #989
gtengr
Drives: 2017 BRZ
lbs not kg
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
weederr33 (04-29-2018)
Old 04-29-2018, 01:25 PM   #990
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by gtengr View Post
lbs not kg
Are you sure? Their development UK car weights 1335kg (including performance upgrades). I don't know how much the performance parts add to the weight, but the UK (or European) cars are also known to be much lighter than the NA cars.
Old 04-29-2018, 04:01 PM   #991
weederr33
weederr33's Avatar
well 63kg (or 65kg) equates to 135-140lbs. Now I lift fairly frequently, but I can assure you, when I had received my kit a few years back, it was no where near that heavy. It honestly felt more like 50-60lbs.
nikitopo (04-29-2018)
Old 04-29-2018, 04:11 PM   #992
ajc209
Drives: GT86 Cosworth
My car with cossy sc and ohlins at the time weighted 1255kg on a hunter corner alignment rig.
Sent from my SM-G935F using Tapatalk
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
Old 04-29-2018, 05:37 PM   #993
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Ok. So, it looks that the weight of the development car was with a driver or something.
Old 04-30-2018, 05:42 AM   #994
ajc209
Must have been as I dont think Ohlins remove much weight at all, perhaps a kilogram or two. With a half a tank of fuel I think UK models come in around 1230kg, so 1255kg would suggest about 27kg which is about what I expected.
The heavy part; the intake and supercharger itself isnt that heavy as its aluminium. 15-20kg.
Then there 5litre of coolant ~5kg
Plus the intake bits (aluminium pipe and silicone bits), front mount radiator, pipes, pump and tank. ~5kg
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
