Old 03-23-2015, 06:37 PM   #981
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by was385 View Post
Received and installed my first replacement unit... and it came with a loose wire that makes the passenger headlight go in and out. Really disappointed in the quality control coming out of DD. I understand that they're trying to meet demand and fulfil orders but they obviously rushed this out to market.
Everything is being tested quite thoroughly before it ships, so I'm sorry to hear of the trouble. Sounds like a pin alignment issue in the headlamp connector, which isn't anything we could have prevented. Disappointing though, and I apologize.
Please just make sure all pins are straight before plugging it in, and you should be good to go!
John C.
Diode Dynamics
Old 03-23-2015, 10:06 PM   #982
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by kakarot1657 View Post
I only ask because of this post on 3/15/15
Probably were caught up. Seems like a lot of people placed new orders however.
As of right now, my RMA was pushed through March 20th and is currently showing as on backorder.
BRZoomTX is offline   Reply With Quote
Old 03-23-2015, 10:14 PM   #983
kakarot1657
kakarot1657's Avatar
Drives: 2013 Subaru BRZ (Galaxy Blue)
Well I just received shipment confirmation this evening that it shipped. So all is good also made an order to get the rear turn signals /back-up conversion kit last Friday so both are heading my way right now.
kakarot1657 is offline   Reply With Quote
Old 03-24-2015, 12:36 PM   #984
Diode Dynamics
We're shipping out a lot every day, if you have any delay at all, it should be shipped very shortly. Please also check your spam box for shipping notifications, thanks!
John C.
Diode Dynamics
Old 03-26-2015, 10:05 AM   #985
Burrcold
Drives: Subaru BRZ Limited
Installed mine today and they work perfectly. Exactly as advertised! Thanks DD!
Old 03-28-2015, 06:37 PM   #986
Agent 86
Drives: 2017 Cayman S
Received my replacement, and it's working perfectly! Covered the wires with split loom tubing, routed everything neatly and inconspicuously, then tied it all down with zip ties. Yeah, I did it right! Thanks DD.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 03-28-2015, 06:54 PM   #987
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
I originally purchased the DRL relay mod from @projek_01 which allows the FRS Monogram LEDs to run dimmed when the headlights are on. With the Diode Dynamics mod will this work on the FRS and does it allow the DRL to run when the e-brake is engaged?
Chad86 is offline   Reply With Quote
Old 03-30-2015, 09:04 AM   #988
aaronglass
Artist / Audio Nerd
aaronglass's Avatar
Drives: 2014 Subaru BRZ, Limited
Hey Diode Dynamics I reported mine working earlier in the week, now they are not.
I unhooked and rehooked everything, I don't get any lights on unfortunately. Appears to be with the relay. I'll call you later for a replacement if possible!
Audio Engineer, Production Artist for Major Labels
www.aaronglass.me
aaronglass is offline   Reply With Quote
Old 03-30-2015, 10:48 AM   #989
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Installed mine this past weekend, routed the wires along the front bumper and under the air box. Used some zip ties to make sure the wires stayed away from anything hot or moving (radiator fans). Will post some pics later, left it on my other PC.
Probably gonna go back in there with some 3M adhesive cable clips and something to wrap the relay in to waterproof it.
PandaSPUR is offline   Reply With Quote
Old 03-30-2015, 08:35 PM   #990
exfortuna
exfortuna's Avatar
Drives: 14 BRZ, 93 Cherokee, 94 Ninja 250R
Got my replacement set today. Looks like they sent me a returned item, the black box was not sealed and had electrical tape around it. Installed and worked properly though.
exfortuna is offline   Reply With Quote
Old 03-30-2015, 09:04 PM   #991
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Ordered both the Boomerang Always-On and the Tail as Turn Module yesterday.
Both modules are in stock when ordering it, but as soon as you complete the order (and pay $103.55 incl shipping to Canada) it is being marked as backordered.
Guru Woodman is offline   Reply With Quote
Old 03-30-2015, 09:13 PM   #992
PandaSPUR
PandaSPUR's Avatar
They need to fix that on their site... its weird, I just checked.
The listing when you're browsing multiple products shows it as "Special Order" but once you click it, it says "In Stock"
http://www.diodedynamics.com/store/l...-foglight.html < where it says "Special Order"
Anyway, I got mine installed this weekend like I said, here are some pics.
How I routed it:
I'm most worried about the wire moving around and touching the coolant lines or radiator fan. So I'll be getting some cable clips to hold it more securely to the frame.
And here's the result:
Old 03-30-2015, 10:54 PM   #993
lamune
Drives: 14 WRB BRZ Limited MT
*sigh* bad luck for me, will be contacting them for a refund tomorrow..
First one: no DRLs (requested RMA, I got the second one today)
Second one: If I use the short side, the passenger boomerrang doesn't come on. If I use the longer side, the DRL adjustment knob does nothing...
Build:
"AWW YEA" < RIP
lamune is offline   Reply With Quote
Old 03-30-2015, 10:59 PM   #994
PandaSPUR
PandaSPUR's Avatar
What do you mean by short side and long side?
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 03:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 02:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 09:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 09:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
