03-12-2016, 08:04 AM | #967 |
Drives: 2015 Raven FRS
Yes I did too. But the car is still giving fault codes and running rough below 1500 rpm. I sent new data logs to Zach at Delicious and he aid there are still vacuum leaks.
03-12-2016, 07:35 PM | #968 | |
Drives: 2013 FRS
My car did not have that problem exactly, but it did have low RPM issues. We changed the cam timing back to stock and most of the problems went away. Just a shot in the dark but maybe you guys could try it, it worked well on my car.... now I'm just hunting down a few more minor hesitation/smoothness issues... |
03-12-2016, 09:05 PM | #969 | |
03-12-2016, 11:10 PM | #970 |
Drives: 2013 FRS
Not sure if you saw my experience with the messed up manifold gasket earlier in the thread, but I did a low pressure smoke test which did not reveal the damage. I had to take it off to find it. I only mention it because it is much more common to have the issue you have with an air leak. Is your idle stable? Does it cycle RPMs up and down a bit at idle? Are the fuel trims at idle making significant adjustments? These could all be about an air leak. I can't see how it would hurt to go back to stock cam timing just to test though. The cam timing issue had us all fooled into thinking it was an air leak on my install, as you can read in the previous posts... Good Luck!!! |
03-13-2016, 12:08 AM | #971 | |
Pulling the supercharger and checking the gaskets will probably be next. |
03-13-2016, 07:54 PM | #972 |
Drives: Toyota GT86 euro version
I order a special tune from Delicious for 98ron (europe), flash my car, went to dyno and had perfect curve. I drive it everyday and everything is perfect. No low rpm probs or anything else. For me the tune from Delicious is delicious at 100%.
03-14-2016, 07:20 PM | #973 |
Boost Creep
Drives: 2016 HyperBlue BRZ
Ohi. Any lessons learned from install? Extra things not listed, what not to do, etc. Other than destroying my manifold gasket.
Planning on doing teardown on Wednesday night while I wait for the box to arrive, then buildup all day Thursday! |
03-14-2016, 07:54 PM | #974 | |
Drives: Scion FR-S (Hot Lava)
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
The Following 5 Users Say Thank You to Nitro22 For This Useful Post: | BigFatFlip (03-15-2016), CSG Mike (03-14-2016), Fever (03-16-2016), paiceyfan (03-15-2016), Uplink (03-15-2016) |
03-14-2016, 08:04 PM | #975 |
Boost Creep
What do you mean Subaru style? I've seen the longer ones but the actual popper piece is shaped exactly the same as the cheap ones you can buy off the shelf at Autozone. They just look like they may have a bit more leverage. Are the hose clamps included or should I stock up?
03-14-2016, 08:27 PM | #976 | |
03-14-2016, 09:12 PM | #977 | |
Fuel line tools are universal, but the nice metal 2-piece ones are much easier. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Nitro22 (03-14-2016) |
03-14-2016, 09:57 PM | #978 | |
Yeah, I tried a couple of universal brands from my local auto parts store with no success. I finally caved in and bought the Subaru specific removal tool and it released with ease. http://www.company23.com/subarutools/545 Last edited by Nitro22; 03-15-2016 at 03:09 PM. |
The Following User Says Thank You to Nitro22 For This Useful Post: | hmong337 (03-15-2016) |
03-14-2016, 10:13 PM | #979 | |
Long Distance Driver
-Using the 2 zip ties, find the two tabs (180degrees apart) on the inside of yellow/green quick connector, and push the flat part of the zip ties in to raise the tabs. -Pull the hose + quick connector out (yellow/green slides out with it)
The Following 4 Users Say Thank You to Sargy For This Useful Post: |
03-14-2016, 10:47 PM | #980 |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
