Old 06-17-2013, 02:54 AM   #967
invisage
Drives: Thunder Silver 86 GTS
Originally Posted by sw20kosh View Post
Non intercooled
Damn... was hoping intercooled so I would reconsider not putting my w/meth kit in.
invisage is offline   Reply With Quote
Old 06-17-2013, 03:55 AM   #968
nix
nix's Avatar
Drives: AVO BRZ
@sw20kosh how does it sound? Vids with audio pls!
Need you guys to help convince @Benn0r to get this kit over avo!
nix
nix is offline   Reply With Quote
Old 06-17-2013, 04:10 AM   #969
OrbitalEllipses
Drives: Attitude
Originally Posted by Pete View Post
I'm stoked to see what sw20kosh got out of it with wmi. Filthy tricksy NDA! The WMI route is more interesting to me, looks cleaner. I'm such a nerd for this.
Eh. I've always been wary of something like meth injection...it's just another point of failure. Catastrophic if something happens and you/your tune doesn't compensate/have a fail-safe feature of some kind.
Fast_Freddy (06-18-2013)
Old 06-17-2013, 04:40 AM   #970
robispec
Drives: Black frs project
Originally Posted by robispec View Post
Very easy and predictable to drive it's like we put a V6 in the car and you want to backend to step out just start adding throttle. but it's nice and predictable there's no nasty power surge there's no uncontrollable kick. That is because it's making boost right from idle. Linear is the power curve.
ok today at the track (WSIR big track) 100 degree ambiant temps
I ran a 1:34.7xx CSG Mike hopped into Dlckers car and poped off a 1:38.5
Yo from 86factory landed a 1:39.5
Everyone else in the 1:40's
Who CARES WHAT THE DYNO SAYS!
LAP TIMES SAY IT WORKS FANTASTIC!
(DELTA for this kit to NA was minimum FOUR SECONDS Even CSG Mike liked it! lol)
Radiator/oil cooler combo work just as expected
Both boosted Innovate cars ran sub 200 H20 and sub 230 oil temps!
(I ran mine with the AC on to simulate what a Front mount inter cooler would add to the system ) and because it was HOT out there ;-).
robispec is offline   Reply With Quote
The Following 4 Users Say Thank You to robispec For This Useful Post:
8686 (06-17-2013), JDKane527 (06-17-2013), TemeCal (06-17-2013), whataboutbob (06-17-2013)
Old 06-17-2013, 06:36 AM   #971
Calum
That Guy
Drives: 2013 asphalt FRS MT
(DELTA for this kit to NA was minimum FOUR SECONDS Even Mike liked it! lol)
Tires, suspension, setup, and driver can and did play a part in those numbers. And I care about dyno plots, the area under the curve can tell me a lot more then comparing two different cars with different drivers. Peak numbers don't say much, but looking at the whole curve certainly does.
Congrats on the great lap times.
Old 06-17-2013, 10:32 AM   #972
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
Scooby South is coming down to visit the shop today. I'll let him give his reviews after driving the car to lunch.
tom@kartboy is offline   Reply With Quote
The Following 2 Users Say Thank You to tom@kartboy For This Useful Post:
swift996 (06-17-2013), whataboutbob (06-17-2013)
Old 06-17-2013, 11:49 AM   #973
nonicname
Drives: it has 4 wheels and a motor
I CARE WHAT THE DYNO SAYS.
I can only judge what the car will feel like by looking at the graph.
telling me a car ran a track fast means nothing as I don't know anything about the track,weight reduction, suspension set up, tires good driver/bad driver etc.
nonicname is offline   Reply With Quote
Old 06-17-2013, 12:02 PM   #974
swift996
swift996's Avatar
Dyno will be awesome!
Robi is like 2.5k and some change lbs, full out suspension, and an experienced driver. Although the other group of characters are well experienced too and have equal mods (minus FI). I'm feeling pretty good about some dyno's showing up here in the next week or two.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-17-2013, 12:20 PM   #975
Opposed
Drives: 2013 Asphalt FR-S
People need to remember that he is running a 4.7 final drive as well...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
The Following 3 Users Say Thank You to Opposed For This Useful Post:
Calum (06-17-2013), King Tut (06-17-2013), Mr.Jay (06-17-2013)
Old 06-17-2013, 01:08 PM   #976
sw20kosh
Drives: 2013 Black FR-S
Do you plan on swapping a smaller pulley and running more boost with the meth? Very anxious to see your results.
Eventually yes, but I am loving this power output right now and plan on thoroughly track testing it to make sure the w/m is working flawlessly.
Big Willow yesterday was a good track to test the extra power. I got one session that was clean of w/m failsafe bugs and was happy to see coolant and oil temps stayed cool for the 20 min session. Oil never went above 230 deg. Outside temps were reading 101 on the course. I have a feeling my cooling is over kill right now. Robispec thick radiator + w/m injection cooling down the combustion chamber, heads, egts and twin screw.
Failsafe bugs were annoying and I will continue to tune the flow alarm limits. It was working perfectly on street testing it, but for some reason once I got on the track it would register more and more flow and trigger the bypass to open. It is either heat or G-forces that is causing moments of extra w/m flow. The only time I get this condition on the street is when I shift very quickly from 2-3. What I did is I kept slightly increasing the upper limit of the flow failsafe alarm, so I got 1 session where it was clean of alarms. The next session however saw a slight bump in flow again so I had to end it early to play around again with the failsafe software.
In the end my impression of the innovate kit itself is that it is fantastic all in all. It has terrific throttle response and gives a nice bump in power to the point where it feel seamless as if the motor is bigger but not heavier. Powering out of corners is.... FUN rather than lethargic.
While I didn't get many laps to try and achieve a fast lap time (my first time on Big Willow + failsafe bugs), Robi set some incredible lap times in his twin screw monster.
Will post video later today.
Here is a part throttle 3rd to 4th I think to show the water meth flow gauge and the supercharger whine =)
[ame]http://youtu.be/DIO6tGw_rPk[/ame]
The Following 9 Users Say Thank You to sw20kosh For This Useful Post:
colHolm (06-17-2013), Fast_Freddy (06-18-2013), JDKane527 (06-17-2013), mxsled (06-17-2013), nix (06-17-2013), Opposed (06-17-2013), robispec (06-17-2013), Sonolin (06-17-2013), Subzero (06-17-2013)
Old 06-17-2013, 01:39 PM   #977
Sonolin
Robi what times did you set a big willow?
I'm really itching for that time lol.
Sonolin is offline   Reply With Quote
Old 06-17-2013, 01:39 PM   #978
robispec
We posted a 1:34.736
IN THE 100 degree HEAT..
NO aero 235 nto1's
oooh dat SOUND!
Best feeling event of the day
I got behind a s2k coming through 9 and was able to pull alongside and pass him going down the straight as he saw my nose he glanced over and shifted and kept in the throttle. When I got even, driver to drive,r and was pulling him in a straight line he did this massive double take...lol
The Following 3 Users Say Thank You to robispec For This Useful Post:
8686 (06-18-2013), Sonolin (06-17-2013), whataboutbob (06-17-2013)
Old 06-17-2013, 03:30 PM   #979
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Glad someone said it.
Old 06-17-2013, 04:45 PM   #980
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Ok, I was tossing some numbers around and shoving them through my calculator and it seems to me that a base kit with maybe a little fiddling (headers?) should make this car accelerate at least as well as a stock STI (not counting AWD launch, so say, straightaway acceleration).
Would those that have driven a mostly stock car with an Innovate SC agree with that?
Because if so, that will be perfect, IMO.
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
