Old 12-18-2015, 01:16 PM   #85
Ashikabi
Ashikabi's Avatar
Originally Posted by Eighty 6 View Post
Ive posted some useful links, have a look.
I think everyone already discredited those. Got any more?
Ashikabi is offline
Old 12-18-2015, 01:30 PM   #86
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Itchi, Itchi ... Are you there?
Braces is offline
Old 12-18-2015, 01:34 PM   #87
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Originally Posted by Cole View Post
I feel like this dude is @zik reincarnated. Blindly trying to shove misinformation (remember how his car had a Tacoma(?) engine, but the pictures he took clearly showed an FA20?) down other's throats and not even having the courtesy to at least consider that others are right or at least admit to being a drunken fool.
Dude, that much was obvious when he thought @jawn was a girl.
I always suspected that he was just another Zik/GTX/Cedars reincarnation.
KR-S is offline
The Following User Says Thank You to KR-S For This Useful Post:
Cole (12-18-2015)
Old 12-18-2015, 01:38 PM   #88
Eighty 6
Newbie
Drives: Gt86
Have you got any links to discredit what I said? Im done here.
Eighty 6 is offline
Old 12-18-2015, 01:40 PM   #89
KR-S
Sporadic Member
KR-S's Avatar
They don't need any other links to see that the links you posted up come from biased websites.
KR-S is offline
Old 12-18-2015, 01:45 PM   #90
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
As the sediments are going through their transformation some particles tend to float near the bottom of the tank, and if you empty your tank enough there is a risk of those sediments going into your fuel system. Thats why you have to install fuel filters, otherwise why are they there?
Did I answer your question? And those sediments can sometimes be so fine that they go through that filter.
no because that is flawed logic, you said they tend to float near the bottom of the tank so whether there is a few inches of fuel(2-3) or a full tank (10-15 inches) then you suggest they will float at the bottom anyhow meaning there would still be that same residue at any given height in the tank the only difference would be concentration at that point since the full tank has more area for the residue to dissipate into vs the empty one.
That being said both would have residue at the same height which could possibly cause the issue whether the tank is full or not the concentration would only be lower in the full tank
here is a visual representation, the + being residue it would still be possible/likely that it would intake said residue just in smaller amount meaning that your logic is flawed since a full tank would also cause those same issues just at a slower rate or at with slightly less important consequences. (will take 2weeks to gunk up instead of 2 days or will completely block injectors vs will partially block them. In both instances there would be blockage though and since that is not the case your theory/hypothesis is invalid)
fumanchu1 is offline
Old 12-18-2015, 01:46 PM   #91
You like random internet stuff so much here you go (coincidently enough it says almost exactly what I said from the start)
http://www.bankrate.com/finance/auto...r-myths-1.aspx
Tcoat is offline
Old 12-18-2015, 01:50 PM   #92
fumanchu1
When you let your fuel level go down you raise the risk of those sediments getting through to your fuel system. Magic.
your logic doesn't stand up for that reason exactly, you previously had stated that there wasn't a risk with a full tank only with an almost empty one.
You also get a higher risk of getting hit by a car if you go outside, but there is no real direct link with going outside vs being ran over just like there is no real world effect of a full tank vs almost empty one (at least not since this millennium)
Old 12-18-2015, 01:52 PM   #93
But Dude, one of those links says in winter to wash your car using Pledge furniture polish. You do not get any more official than that!
Tcoat is offline
fumanchu1 (12-18-2015), KR-S (12-18-2015)
Old 12-18-2015, 01:52 PM   #94
fumanchu1
Arent you the same guy that stops his car uphill by using his clutch and gas in traffic instead of his handbrake? I wont bother.
Hum I use brakes and actually have enough dexterity to remove my foot from brake, while simultaneously applying throttle and releasing the clutch. Which btw is the proper way to do it. You want driving courses on top of your introduction to physics/chemistry 101?
Old 12-18-2015, 01:54 PM   #95
fumanchu1
@Tcoat it was written on the internet so according to him it must be true.
you should also put sugar in your gas tank to fight those residues
sandpaper on wiper to remove the ice
Mike probably has a great intake he could build for you
curb feelers? no wait these actually have a use so he wouldn't think of using them
The Following User Says Thank You to fumanchu1 For This Useful Post:
KR-S (12-18-2015)
Old 12-18-2015, 01:59 PM   #96
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Who's "Itchi"? You mean "ichi"? Yes, I'm here enjoying my popcorn
First part of concern is resolved, but cricket & gas debate is still going. If I miss some comment which breaking the rule, lmk.
ichitaka05 is offline
KR-S (12-18-2015)
Old 12-18-2015, 02:05 PM   #97
KR-S
Sporadic Member
KR-S's Avatar
@go_a_way1 suggested lighting a match to help burn off that residue in the gas tank too!
KR-S is offline
go_a_way1 (12-18-2015)
Old 12-18-2015, 02:06 PM   #98
fumanchu1
don't need links to discredit obviously biased marketing material with no sources. Also several people including @Tcoat have already provided links that mentioned the things you said claiming they were myths and had no supporting evidence to back up their claims.
