CANADA Canada
Old 10-23-2015, 09:09 PM   #85
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
Update:
Nextmod Markham has found out about my issue with Nextmod Mississauga. Peter from Nextmod was nice enough to call me and tell me that he will reimburse me the cost of both of my o2 sensors. Thank God.
He also was nice enough to ask and fix my issue as well. From this day, my issue has been fixed and haven't gotten a single code. I am going through gas more than I should be though. I'm not sure why.
But anyways, I just wanted to update you guys that Nextmod did help out and took responsibility with my sensors even though the headers that I got were second hand.
Thanks everyone for your help and advice!
ShibaYuki is offline   Reply With Quote
The Following 2 Users Say Thank You to ShibaYuki For This Useful Post:
Cole (10-24-2015), drewbot (10-23-2015)
Old 10-23-2015, 10:20 PM   #86
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
@Cole
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
The Following 2 Users Say Thank You to drewbot For This Useful Post:
Cole (10-24-2015), ShibaYuki (10-23-2015)
Old 11-24-2015, 03:18 PM   #87
Jayela
Drives: 2013 Nissan GT-R, 1985 Porsche 944
Originally Posted by ShibaYuki View Post
I just got a P0171, P2097 and a P219A code. And I have searched it up. It says I'm running to lean, but I can smell gas. Like I've been driving a gokart. ps: running catless headers and catless FP w/ stg2 uel oct91. So I think that's the gas smell.
I tried clearing the code with the OFT, but it came back after a while.
I wouldn't know how to check for leaks, or check if my MAF is dirty, check my o2 sensors or how to fix such things.
Any help would be greatly appreciated.
Didn't have time to read the whole thread, but i have a problem of the same kind, although my OFT doesn't allow me to read codes for some reason. So the problem i have is that the thread of front O2 sensor got destroyed. Hope this helps. I still have the rear CAT, but i smell gas as well.
Jayela is offline   Reply With Quote
Old 11-25-2015, 09:46 PM   #88
ShibaYuki
It's for sure a gas leak where the front o2 sensor. Replace the destroyed front o2 sensors, those are $250 w/o tax a pop. You should also try to use brand new gaskets. Make sure when you put in the sensors in, that they're snug. Don't force it. It should screw in by hand. Other than that, that was my problem and it was solved, by doing that. Hopefully that helps!
anyone have these installed? ft86me Cosmetic Modification (Interior/Exterior/Lighting) 3 04-05-2015 12:36 PM
KDT 925 installed. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 08-14-2014 04:29 PM
Scion installed vs dealer installed fog lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 10 02-16-2014 01:55 PM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 04:59 PM
Innovative SC Installed!!! Pics and dyno installed. uspspro Forced Induction 15 04-02-2013 01:09 AM
