Old 07-04-2015, 01:26 PM   #85
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Currently watching Hot Version Internationl Vol. 128.
There's a new Honda Fit with rigid collars, one of the drivers mentions that he feels that they are working and the car feels very rigid. I believe the car was on stock suspension.
The Following User Says Thank You to dem00n For This Useful Post:
civicdrivr (07-04-2015)
Old 07-05-2015, 05:00 PM   #86
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Should I buy the new and improved bolts when I install the rigid collars.?
SU003-05212 x 4
SU003-05213 x 2
SU003-05235 x 2
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
Zaneman (07-06-2015)
Old 07-05-2015, 08:32 PM   #87
SPCorBUST
SPCorBUST's Avatar
I'm about to order these - the code still appears valid.
Does it seem like you can use these with the tS STi parts?
Subaru 20176B STOPPER, UPPER
Subaru 20157E BOLT SUPPORT, SUB FRAME
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 07-05-2015, 11:47 PM   #88
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Received front and rear collars. Will be installed in a couple of weeks. I'm very curious...
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
SkAsphalt (07-06-2015)
Old 07-06-2015, 12:04 PM   #89
KoolBRZ
KoolBRZ's Avatar
SU003-05212 x 4
SU003-05213 x 2
SU003-05235 x 2
I wouldn't recommend it. These are sized for the stock bolt diameter to work correctly. You probably couldn't fit the bolts through the rigid collars.
The Following User Says Thank You to KoolBRZ For This Useful Post:
tonystewart (07-06-2015)
Old 07-06-2015, 06:48 PM   #90
Fastbrew
Drives: 2014 Pearl White BRZ
How do I get a set of these?
I went to the website in the UK - it accepted everything including the coupon code and paypal info but it would not allow me to pick a shipping method - so - no order was actually placed.
Fastbrew is offline   Reply With Quote
Old 07-06-2015, 06:53 PM   #91
juliog
juliog's Avatar
Drives: 86
They might have ran out of stock. I ordered a full set on 7/2 using the discount code posted on this thread, got them in the mail today.
juliog is offline   Reply With Quote
Old 07-06-2015, 08:20 PM   #92
tonystewart
They are backordered 10 days estimate, you received the last set
Old 07-06-2015, 09:53 PM   #93
Fastbrew
Tickler set for 10 days...
Old 07-07-2015, 12:08 PM   #94
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Then how would the rigid collars work on MY2015's then?
Createddeleted is offline   Reply With Quote
The Following User Says Thank You to Createddeleted For This Useful Post:
Hyper4mance2k (07-07-2015)
Old 07-07-2015, 03:07 PM   #95
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I didn't think the shanks of the bolts changed, just a larger shoulder, but I could be wrong...
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 07-07-2015, 06:33 PM   #96
Createddeleted
It is mainly a larger shoulder. I see no reason why the bolts wouldn't work.
Old 07-09-2015, 10:21 PM   #97
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Hoosier Daddy View Post
Ya, 6061 can elongates over 20%, which appears like what might be required for this to work, only has yield and tensile strength of 55 and 125 MPa respectively, and more importantly fatigue strength of 96 MPa. T4 heat treat is only marginally better but won't elongate as much without failure. What's stress on this part with 70 Nm of bolt torque?
20% Elongation?!? Where did you get that number from? ASM lists them at 12% at 1/16" thickness and 17% at 1/2" diameter. So basically 12% for this application. http://asm.matweb.com/search/Specifi...ssnum=MA6061t6
Old 07-17-2015, 08:08 AM   #98
tonystewart
Another 14 days back ordered, by the time they arrive the car will be unavailable, story of my life
Spoon GT86? c147258 Scion FR-S / Toyota 86 GT86 General Forum 67 04-27-2016 12:31 AM
No Spoon parts for the 86... twincamRob FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 81 06-02-2015 10:37 AM
Fs: brand new pbm subframe collars Guildjs Brakes, Suspension, Chassis 3 10-16-2014 08:54 AM
T1R Differential Collars Mikepage Engine, Exhaust, Transmission 0 05-01-2014 09:18 PM
