Old 02-03-2016, 01:22 PM   #85
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Yes, same here maybe 2-3 times in over a year. I've also had my volume knob stop working. In both cases, using a paper clip in the tiny reset hole in the front to restart the unit fixed the issue.
One thing that annoys me is I need to press the buttons on the front (ie GPS) twice before it will do anything after I first boot up. From then on the first press works.
Old 02-03-2016, 01:48 PM   #86
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Good to know it's not just my headunit then. So when you reset your headunit using the reset button does that reset any data that is saved on the harddrive? I don't want to delete any songs if it happens again.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 02-03-2016, 02:10 PM   #87
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
any idea if this would save you time on adapters and repining?
http://www.carjoying.com/joying-harn...ess-cable.html
lbroskee is offline   Reply With Quote
Old 02-03-2016, 04:28 PM   #88
B-R-Z
B-R-Z's Avatar
No, it just basically disconnects +12 constant as far as I can tell. I have music on an SD and that is unaffected as well as all of my settings.
Old 02-04-2016, 06:45 AM   #89
Neil_turbo
Drives: GT86 trd
Hi All
I have just sold my dashlinq4 as i could not get it to connect with my Defi smart bluetooth adaptor.
How has everyone found bluetooth connectivity on these, is it happy to connect to 3rd party devices OK?
Cheers
Neil
Neil_turbo is offline   Reply With Quote
Old 02-04-2016, 12:29 PM   #90
B-R-Z
B-R-Z's Avatar
Connects to my phone, gf's phone, and obd2 dongle without issue.
Old 02-06-2016, 03:26 PM   #91
lbroskee
lbroskee's Avatar
@B-R-Z
So to hook up the antenna adapter, I just tap the blue wire into the blue wire that gets repinned?
And the 3 blank wires on the harness, do I just ignore them (back/amp/brake)? Couldn't find info on this part
Old 02-07-2016, 08:42 AM   #92
B-R-Z
B-R-Z's Avatar
Are we talking about only the antenna adapter? If so, I think you only need to use what allows you to connect the antenna to the radio. Then you must connect the wire for the antenna booster (coming from car harness) to amp turn on wire on radio. Its been a while since I installed this so I'm not 100%.
Old 02-07-2016, 06:13 PM   #93
lbroskee
lbroskee's Avatar
any1 have trouble with the radio bezel fitting? theres a trim around the face that sits further back but its forward enough that my bezel doesn't clip on
Old 02-07-2016, 08:58 PM   #94
B-R-Z
B-R-Z's Avatar
You probably need to sit/screw the unit back further on the metal bracket before you slide it into the dash.
Old 02-07-2016, 10:05 PM   #95
lbroskee
lbroskee's Avatar
ok ill check into that then. everything looked pretty tight and bolts to remove HU fully seated.
also any way to get my iPod to work with this thing? the built in app just crashes (radio quality it total crap so need my tunes)
Old 02-07-2016, 10:36 PM   #96
B-R-Z
B-R-Z's Avatar
Fully seated doesn't matter. You need to make sure that the bracket is furthest it can go towards the front of the unit. If its not in the correct spot then you may have the issue that you're having.
Ditch iPod, get a 32 GB microsd for $10 and load your library on it.
Old 02-07-2016, 10:38 PM   #97
lbroskee
lbroskee's Avatar
hmm, ya im def on the right holes then. any apps to display track info like an iPod? from videos I've seen the built in one displays literally just the file name "song.mp3"
Old 02-08-2016, 05:42 AM   #98
B-R-Z
B-R-Z's Avatar
No, it displays tag info when playing, but you select the song by filename, IIRC. This is with the stock music player though. Find one on android that does exactly what you want and use that.
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
