Northwest AK, ID, OR, WA
Old 05-07-2015, 12:44 AM   #85
llawd
llawd's Avatar
Drives: series 10
I'd like to get in earlier if possible
llawd is offline   Reply With Quote
Old 05-07-2015, 12:49 AM   #86
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by digital_assassin View Post
Dang it. I need to just swing by and check out the progress on the place one of these weekends. Ever since moving to the West side I never get over to that side of town but I'll make a point of it.
Did you buy a new place?
Jmonty is offline   Reply With Quote
Old 05-07-2015, 01:50 AM   #87
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by kuya View Post
I autocross every once in awhile and would like to do track days eventually, so I got them more on function over form, all my research said they complemented the stock shocks and improved handling, plus I get rid of a little wheel gap.
no spacers, hoping the 20mm drop is little enough not to suck the wheels in to much
You'll want different wheels or spacers.
I know I do now at least. The wheel is fairly sunken looking.
Old 05-07-2015, 03:18 PM   #88
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Originally Posted by Ammunition View Post
I've been considering these for a long time - are you getting spacers, and did any thread(s) or images in particular help sway you to purchase these?
I've been on RCE yellows for a year now and over 15k miles. I'm still very happy with them. better ride than stock shocks on the freeway, better grip in the corners and the stock shocks are holding up perfectly. I run 17x9 et42 wheels and do not need spacers. I also run the stock wheels in winter without spacers and they're just as sunk in as they are at stock height. Once my shocks blow i'll replace with koni yellows or just move up to coilovers.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 05-07-2015, 06:27 PM   #89
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I second your 'happy with them' motion. I've had RCE yellow springs with Koni yellow insert struts/shocks for over almost 2 years. Wonderful springs and the Koni shocks have been great too. Full soft is a little more comfy than stock and the harder settings are less comfortable, but increase road handling feel quite a bit. I run 17x8.25 et35 which seems to be the best offset for being flush without going over the wheel well for a non extreme camber setup. I'm around -1.3 camber in front and -1.5 in rear. Handles great on the track and street. RE-11a tires (245/45R17) help significantly however though too.
stockysnail is offline   Reply With Quote
The Following 3 Users Say Thank You to stockysnail For This Useful Post:
Ammunition (05-08-2015), llawd (05-08-2015), RobertPaulson (05-07-2015)
2nd annual BeeRZ and BRZ's (and FRS') Laika NY / NJ / CT / PA 70 09-21-2016 05:52 PM
2nd Annual #teamguelphscion bbq jamies31 CANADA 52 04-28-2015 11:58 AM
2nd Annual 86 Day T-Shirts MoebiusStrip Southwest 99 08-10-2014 10:46 AM
ESR annual meet KAR NY / NJ / CT / PA 2 06-16-2013 12:36 AM
AZP Annual BBQ, Monday Sept 3 AZP Installs NY / NJ / CT / PA 3 08-31-2012 10:04 PM
