#85 | |
@torqdork
http://www.michelin.ca/tire-selector...p/tire-details link2 Why did you link a comparison chart without the tire in question? The Primacy HP on the Toyobaru is a summer tire, the only Primacy's in that chart are a different compound all-season. Going to the correct chart puts the Primacy HP at #1 in it's class: http://www.tirerack.com/tires/survey...ay.jsp?type=GT You can slap Hoosier R6's on a Geo Metro, that doesn't diminish the fact that it's a highly regarded racing compound. The primacy's are severely underrated around here, they're durable, relatively comfortable, and good to learn on. Last edited by strat61caster; 01-13-2015 at 05:31 PM. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Jond63 (01-13-2015), Ultramaroon (01-13-2015) |
#86 |
Drives: fast
#87 |
Drives: FR-S Firestorm 2013
slip 'n' grip = <3
#88 |
Drives: RV-7
@strat61caster, good catch, totally missed that.
What influenced me as much as anything was the test drive in the dealer demo with a willing salesman egging me on...at first. I took him to one of my favorite roads in the foothills a few miles away from the dealership and was surprised at how quickly the tires gave up grip on a dry, warm day. Based on my Prius experience with the same GreenX family of tire construction, I thought they'd be much worse in the wet so that's why I ordered the first set of replacements well before my car arrived. I don't see what the OEM Michelins could teach an aspiring driver except how effective the system nannies are to save themselves from overwhelming lack of dry and wet grip that give the car it's signature "loose" character. Nothing much to learn and a bit upsetting to have the car balanced at corner entry only to have VSC/TRAC clamp down on the fun factor, understanding that they can be disabled eventually. I think tires are the first thing that most twin drivers I've met change out and are glad they did. They're a good trading tool though. My local tire dealer gave me a generous trade allowance that made switching to a far better tire much better suited to the car very affordable. |
#89 |
Drives: 2018 Camry XSE V6
I find that out of all the Michelin tires that I've owned, they all give up traction at the slightest hint of moisture on the ground. Maybe Pilot Super Sports are better, but, I remember switching to Bridgestone Potenza RE970's and their wet weather traction was far superior to any Michelin product that I've driven on.
| The Following User Says Thank You to Demandred7 For This Useful Post: | torqdork (01-15-2015) |
#90 |
/dev/null
Drives: Uphill
| The Following 2 Users Say Thank You to Sarlacc For This Useful Post: | Demandred7 (01-15-2015), torqdork (01-15-2015) |
#91 | ||
Tires with a lower grip threshold allow you to learn the dynamics of the vehicle at the handling limit at lower speeds than with grippier tires. When your grip thresh-hold is lowered you must drive more carefully, more precisely, more gently to maximize your tires: smooth is fast. Higher grip tires can mask poor drivers inputs, I slapped some Dunlop ZII's on a few weeks ago, while someone sitting in a passenger seat would immediately notice I am faster than with the Primacy's I am realizing that my inputs are not optimal. Mistakes such as braking too early, turning in at the incorrect time or too aggressive/not aggressive enough are masked by the grip and result in some slight understeer due to the character of the car. But I know through my butt computer that I am not driving to the full potential of the grip and chassis I have. With the Primacy's those mistakes would be obvious, punished, and correct technique rewarded as I carry maximum speed through the corner and steer the car out with the throttle instead of realizing that I am not unwinding the wheel soon enough and I can just plant my foot to the floor but it doesn't matter because the car just goes where I point it. Not to mention managing non-optimal equipment is a good lesson for those looking at driving any vehicle that is not perfectly equipped at a high level (stock or classes with certain restrictions, endurance racing). Also sticky tires often don't break away progressively, once they hit the limit of adhesion they are gone and you're out of control, lower grip tires often lose traction progressively, you have time to correct mistakes and compensate, they communicate with you. A safer environment to explore the limits gives drivers confidence and confidence is the key to being truly fast. Sure, someone who wants to show up to a couple track days per year and never time a lap will instantly love the upgraded rubber and it will be great for the duration of their ownership. I want to learn to be better and the Primacy's offer that opportunity. I am not alone in this sentiment. http://motoringconbrio.com/2011/12/1...-on-the-track/ http://flyinghorseracing.net/tag/tires/ Number 1 on this list is easier obtained with the Primacy's than stickier rubber: http://jalopnik.com/ten-driving-tech...ster-837305612 This study was conducted testing the hypothesis, it contradicts my premise but it only covers step one of the process and the focus is on safety, not speed, over a very short time period (note it's a pdf): S. de Groot, JCF de Winter: The effect of tire grip on learning to drive a racecar From the "SCCA Solo II" book: https://www.tirerack.com/features/so....htm#drivetips Quote:
Edit: I am of course assuming the driver is at a level where they are comfortable driving without the traction control on. |
| The Following 8 Users Say Thank You to strat61caster For This Useful Post: | bcj (01-14-2015), Demandred7 (01-15-2015), Fly Guy (01-15-2015), juliog (01-15-2015), tahdizzle (01-14-2015), torqdork (01-15-2015), totopo (01-15-2015), Ultramaroon (01-14-2015) |
#92 |
Yeah, the Potenzas were supernaturally grippy in the wet (although, still breaking away progressively) and obviously even better in the dry.
#93 |
Drives: RV-7
@strat61caster, I understand your focus.
My strategy is to mount the grippier, and therefore safer, wet/dry tire and then proceed first to an auto-x to learn chassis dynamics at lower speed limits. As Bobby Rahal says, safe is fast. Then take those lessons and with a good instructor aboard, enjoy track days with much higher confidence and lower fear factor. The trouble with learning driving lessons with the OEM tire is that they may well happen unexpectedly on public roads, catching even an experienced high performance driver unprepared. At that point it may become a difficult or impossible situation to control with or without aids compared to a higher performance tire that has a better chance of regaining control compared to the OEM tire that once sliding tends to take much longer to regain traction. From my experience on an FR-S test drive and then on my FR-S over a mountain road I travel almost daily using three types of tires, OEM, high performance PSS and ultra-high performance RE-11A, IMO there's no question which tire is better suited for most drivers under all but snowy conditions, the PSS that can deal with anything from DD to SCCA auto-x to club track days. |
#94 | |
Drives: RV-7
| The Following User Says Thank You to torqdork For This Useful Post: | Demandred7 (01-15-2015) |
#95 | |
You're not the first person who has said they feel unsafe on public roads with them, I'm really curious as to how someone with this opinion drives as I did not feel unsafe hurtling through turn 1 into turn 2 at Laguna Seca at 100+ mph with only the OEM brakes to slow me down. To each their own.
#96 |
Drives: RV-7
#97 | |
![]() First day after all, was probably just barely under 2 minutes at the end of the day. ![]() Just more proof that different strokes for different folks. |
#98 |
Drives: RV-7
I've never run Laguna Seca but plan to this June. One of the classic tracks for sure.
| The Following User Says Thank You to torqdork For This Useful Post: | strat61caster (01-15-2015) |
| 2015 BRZ paint easily stained | einstein | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 05-12-2015 12:01 PM |
| Are BRZ .Blue Edition parts easily removable? | Stang70Fastback | BRZ First-Gen (2012+) — General Topics | 18 | 10-20-2014 09:23 PM |
| SLIPS, the Last Step Protection of the future? | LeftFootBrake | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 08-15-2012 02:30 AM |
| Handling a little weird? Pulls/slips while on freeway. | kuma | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 07-10-2012 06:18 PM |
