View Poll Results: What is the state of your 6MT gearbox?
Butter smooth and only getting smoother 187 58.62%
Problems, grinds, synchro issues, etc... 132 41.38%
Voters: 319. You may not vote on this poll
Old 02-24-2015, 12:54 AM   #85
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by T-Steve View Post
I waited until warm weather arrived to see if my transmission 2nd gear crunch improved. It has.
Below about 50 F I get the second gear crunch consistently. Now that it's warm it almost never happens. I've only got 3000 miles on my '14 BRZ so I'll let it keep on breaking in.
Give it another 5K for break-in. Not joking. Gets better.
chas3wba0 (02-24-2015), RobertPaulson (02-24-2015)
Old 02-24-2015, 04:01 PM   #86
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Voted "Smooth as Butter", but, after it is warmed up. This box definitely does not like to be cold. Tried the Motul 300, mainly for better quality at the track; no difference when cold.
Sleepless is offline   Reply With Quote
Old 02-24-2015, 06:05 PM   #87
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Originally Posted by Entroper View Post
The tolerances are tight with the AZ6. There is no mechanical fix for the 2nd gear crunch, the fix is your technique. Go slower when it's cold. Synthetic oils can make it a bit easier, but you have to slow yourself down. I've owned a 6-speed Miata, RX-8, and two 86 twins, all with some version of the AZ6, and all of them were tight going into 2nd when cold.
My buddy has ruined second gear in his rx-8 because he slams every gear shift like he's in a fast and furious movie.
as far as my twin, the usual notchyness with 1st/2nd when cold. My old service manager told me at 3000k miles when i complained about the transmission that i just needed to give her a real good rowing/thrashing once warmed up. Sure enough i did that, then changed the fluids and its been great since and only gets better with miles.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
The Following User Says Thank You to RobertPaulson For This Useful Post:
Ultramaroon (02-24-2015)
Old 02-24-2015, 06:54 PM   #88
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
there should be options added to the poll about difference AFTER switching fluid
Old 02-24-2015, 07:27 PM   #89
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by tennisfreak View Post
2nd gear when cold has always been notchy.
4th gear in high RPM's causes slight crunch.
Ditto. Motul Gear 300 (or just the tranny fluid change in itself) at 16k miles solved both these issues.
The only few times that I have ground the synchros in this car have been due to me releasing the clutch too soon (first MT car). Hasn't happened at all since I've become familiar with the car.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 02-24-2015, 10:10 PM   #90
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
No issues here, just a little notchy when cold, and its better than my other Subaru transmissions have been.
Replaced the fluid IMMEDIATELY when I purchased the car thats the best thing you can do for it.
Kostamojen is offline   Reply With Quote
Old 02-25-2015, 01:39 AM   #91
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Butter smooth.
30 year's of manual.
In my country it used to be almost impossible to get automatic and if you had one good luck to sale!
We get our driving license exam on a Manual. So if you make your gear grind you can go back for an extra 20 hours of teaching and register for next exam session.
Now a day's their are a few automatic specialy those double clutch stuff.
Mars2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mars2 For This Useful Post:
hmong337 (02-25-2015), Ultramaroon (03-29-2015)
Old 03-29-2015, 10:19 PM   #92
misooscar
misooscar's Avatar
Drives:
I was complaining too early...transmission is now butter smooth at 7K, and a fresh Motul Gear oil 300, 4th gear grind is gone
Sent from my SM-N900T using Tapatalk
misooscar is offline   Reply With Quote
Old 03-29-2015, 10:35 PM   #93
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I love the 6MT in the 86.
Only gripe is that the shift from 6 to 4 can be a bit awkward.
Also on upshift it can be a bit noisy. Hearing a slight clank noise. But normal on a cheaper car.
Wise is offline   Reply With Quote
Old 03-29-2015, 10:46 PM   #94
EvoPrecision8
Drives: 2015 BRZ Sport Tech
When my car sits for a few days, especially when cold(ish), I can literally barely get it to go into 2nd. It will grind no matter how gentle and slow I am. Sometimes I can barely get it to go at all. I'm hoping it will improve after I swap the fluid. I'm just waiting to get all the initial wear particles out because the car is only at about 1200km right now. After warm though, it's pretty buttery for the most part.
EvoPrecision8 is offline   Reply With Quote
Old 03-30-2015, 11:59 AM   #95
Pkush
I wanna re-vote. at 14k I'm getting grinds every time I downshift into 5th.
Pkush is offline   Reply With Quote
Old 03-30-2015, 12:14 PM   #96
PA-86
PA-86's Avatar
Drives: Scion FR-S Ultramarine, Triumph STR
I have to be very gentle with my 6th to 5th downshift or I'll get a rough grinding sound. Just started recently, currently running Redline in the trans and diff. Otherwise the gear box is great.
PA-86 is offline   Reply With Quote
Old 03-30-2015, 12:46 PM   #97
Pkush
Same Exact thing for me. Going to take it to dealer.
Old 03-30-2015, 05:02 PM   #98
PA-86
PA-86's Avatar
Let me know what they say.
Transmission problems M&W_FRS Issues | Warranty | Recalls / TSB 9 11-23-2014 10:29 PM
Transmission problems ofuts Issues | Warranty | Recalls / TSB 24 10-23-2014 11:44 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
Slow is smooth, smooth is fast B3ND3R Other Vehicles & General Automotive Discussions 43 03-21-2014 11:24 PM
Another PNW Car meet? Vote on a date and vote on what to do! NickFRS Northwest 45 01-07-2013 07:23 PM
