View Poll Results: Which is your pick?
Moton 5 15.63%
Sachs 4 12.50%
AST 3 9.38%
JRZ 13 40.63%
MCS 7 21.88%
Voters: 32. You may not vote on this poll
Old 08-29-2014, 04:13 PM   #85
I still don't know your driving experience, and what your obcession is with comparing the car to a Carrera and Cayman...
Do you actually have any experience at the track?
CSG Mike is offline
Old 08-29-2014, 04:40 PM   #86
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Springs are typically specified by spring rates only. In other words, the amount of force necessary to compress a given spring a given distance. Different brand (and even model in some cases) respond to the initial impulse differently, and while the spring rate may be the same, the rate of response is not. For example, a 1000lb/in hyperco and 1000lb/in swift spring will both take the same amount of force to compress one inch, but the amount of time they take to react to the force and compress that one inch is different. We're talking fractions of a second, but when it comes to dampers, this is a significant amount. To put it in perspective, if you drive over a small bump at 70mph, how much time does it take for your suspension to compress and decompress as it goes over that bump? A tiny fraction of a second.
When we custom valve dampers, we have to account for the specific spring being used to properly match the damper curves to the spring. A lot of vendors offer "spring upgrades" to less expensive dampers, without actually knowing if the dampers match the spring upgrades well. Sometimes they get lucky and the combination happens to work well, and other times they're not.
Interesting... Maybe I worded my question poorly, but I'm curious what the difference is between the two. As in, do the swift spring tend to react quicker to load changes or slower or some other way? That difference does not sound insignificant, the way you guys are describing. I'm guessing this would impact how the high speed damping would have to be valved. (Wild guess) would this deference will be apparent regardless of how much it is compressed?
Has anybody documented this difference. Maybe a link to someone talking about this?
solidONE is offline
Old 08-29-2014, 04:50 PM   #87
Yui-Chan
Drives: Toyota
Yes it would. Now your aero balance would be heavily understeer biased. (Rear wing?) If you only added a front lip spoiler, then you've be a bit oversteer biased, depending on model. Experience will affect how much this is weighted into a recommendation.
Yes..but idk if slight under/over bias from marginal aero still would change CO selection. More spring rate selection sounds like.
Experience? Just a couple times, rarely and haven't been much since the 90s. Mostly tagging along with friends who competed in shifter karts in the late 90s and random trips with bone stock street cars until I became less interested, moved on, while they continued to pursue their professional racing and bigger indy type cars.
Yui-Chan is offline
Old 08-29-2014, 05:03 PM   #88
Yui-Chan
Drives: Toyota
My "stock" cars back then were very lightly modified (only coilovers or upgraded springs/shocks) CRX Si, Del Sol DOHC and SW20.
Yui-Chan is offline
Old 08-29-2014, 05:06 PM   #89
The rate of reaction to a given force is the difference.
I don't think there's any documentation I can publicly post... sorry
CSG Mike is offline
Old 08-29-2014, 05:12 PM   #90
Yui-Chan
Drives: Toyota
Why are the single adj MCS, AST, JRZ not recommended though?
Is it because they are too much for what you get(only 1way)? (As compared to a 2way SRC or V3 or T2 for a similar price)?
Yui-Chan is offline
Old 08-29-2014, 06:08 PM   #91
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
http://www.ft86club.com/forums/showp...6&postcount=75
dradernh is offline
Old 08-29-2014, 08:53 PM   #92
BRZgirl
BRZgirl's Avatar
Drives: Subaru BRZ Silver Limited AT
Check out my build thread, just got my AST 4150 installed!
http://www.ft86club.com/forums/showt...t=34783&page=3
Race proven too! https://www.facebook.com/M1cheleAbbate
BRZgirl Subaru BRZ Silver Limited AT
Pages:BRZ & FR-S Girls
Current Builds: Mann Stainless Steel Brake Lines, OEM Audio+, Speedline & Mann Engineering Type-25 Coilovers
Tune by:
Mann That's Delicious Future Builds: Brembo 4-Piston BBK
BRZgirl is offline
Old 08-29-2014, 09:47 PM   #93
Yui-Chan
Drives: Toyota
Girls rule!
Yui-Chan is offline
Old 08-29-2014, 11:09 PM   #94
Racecomp Engineering
I really like JRZ RS1. More than JRZ RS. It is tough to compare to a 2 way and there some cases where I'd prefer the 2 way. But for me, its JRZ RS1, if they're properly valved from the start.
- Andy
Racecomp Engineering is offline
Old 11-15-2014, 06:08 PM   #95
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
Probably not my place for my input, as there are many more experienced individuals here that have already answered.
If it was me, I would just go for Bilstein B16 with Camber plates. It is under $3000, and is similar in construction to Ohlins and Sachs (inverted monotube, 1 adjuster)
Is it the BEST suspension, that depends. A properly set up suspension would be the BEST suspension even if the suspension is STOCK
One way adjusters is the way go unless you know how to match spring rates, then 2 way adjustable coilovers may be for you.
CyberFormula is offline
Old 11-15-2014, 07:32 PM   #96
Hoosier Daddy
Drives: '13 Denali, '15 Volt, soon a BRZ?
Penske Shocks can custom make some 7500 series for *around* $3000. Add another $250 for Hyperco springs.
Hoosier Daddy is offline
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
Sachs coilover teaser pic Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-23-2014 06:48 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
Vorschlag/AST/Moton Hands On BRZ oneday BRZ First-Gen (2012+) — General Topics 72 03-16-2012 04:54 PM
