#85 |
Drives: '13 Subaru BRZ Limited WRB
I wish you luck - I took mine to the dealer with the same issue and they made a big deal that they had tightened the belt up using the idler pulley adjustment. It didn't change anything. If you want it fixed, you'll have to be forceful.
#86 |
Drives: SWP BRZ Limited MT
I saw that you are from Boston as well. Mind if I ask you the name of the dealer?
#87 |
Señor Member
Drives: 2013 SSM DZE BRZ
Call Subaru. For the benefit of not only you but the community at large we need to make sure issues like this one are addressed.
#88 | |
Thanks for the advice. What is the protocol for this? Is SOA looking for technical issues, or are you suggesting I comment on my lack of satisfaction with the service I received? |
#89 |
Señor Member
Both. I don't know exactly how dealers operate, but Subaru may not be aware of the A/C issue. Since others, myself included, are experiencing this problem, it appears to be some sort of design or assembly flaw. Making sure that higher-ups are involved increases the chance of a resolution for you, including a potential TSB.
#90 |
I have the first legitimate failure in this thread:
My power trunk opener just died. Both the button in the car and the one on my keyfob. I'm pretty pissed, I had every electric motor in my G35 die on me. I'm already starting to wonder when the window motors and power door locks will fail! |
#91 | |
#92 | |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
#93 |
Odd noise the other day from I think the drivers side front dash speaker area. Sounded similar to a blown speaker. I turned the radio off and the noise was still present. Unplugged my iPhone, no change. Went away the next day. Weird.
#94 |
Thanks for this... I didn't realize there was a switch. That's probably the problem.
#95 |
Sure enough, my golf club must have pushed the button. Big relief. Thanks gents.
#96 | |
#97 |
Drives: 2015 CWP Subaru BRZ Series.Blue
Am I the only one noticing that around highway speeds air gets underneath the hood and pushes it up and makes it look like it's floating around?
#98 |
^^^You sure your hood is closed all the way?!
