#85 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Has anyone run the new V2 sandwich plate with a Grimmspeed intake? Trying to get 100% confirmation it clears.
#86 |
Drives: 2019 Toyota 86
Are there any good installation videos? I have a 2019 manual transmission 86 and I've never installed anything like an oil cooler before, let alone take the front bumper off a car before.
Also does Jackson offer a warranty for the cooler if it fails and causes further engine damage?
#87 |
Drives: GTS 86
Have had this cooler/radiator in my car for about 6 months. So far no issues whatsoever. The oil temp sits at a comfy 90 degrees celsius and goes slightly higher (just above 90) when I punch it on the mountain fun!
Totally recommend it. Next is getting a supercharger from these guys! |
#88 |
Is there anything that needs to be specifically done for oil changes since there's gonna be some oil left in the radiator?
The manual said to change oil and filter every 3000 miles instead of the usual 5000 miles too.
#89 | |
While the system capacity is larger, the amount you fill and drain doesn't change. |
#90 |
Drives: 2013 FR-S 10 series [755]
Q: Do I need to add more engine oil with the oil cooler kit?
A: Yes, an additional quart of engine oil is required when installing the Jackson Racing Engine Oil Cooler Kit. Does this mean I need to put 6.8 Quarts instead of OEM 5.8 Quarts?
IG: @rearwheelclub
#91 | |
Drives: Subaru BRZ
For future oil changes, you will not be able to drain the oil from the oil cooler or oil cooler lines, and the car will usually take about 6 quarts of oil. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | FR-Sky (04-09-2019) |
#92 |
Should I change my oil change interval from 5000 miles to 3000 miles?
#93 |
Drives: 2014 GT86
Ryan GT86: i'd shorten or not oil change intervals more in relation if car is tracked or not, not so much if it has or hasn't oil cooler/larger capacity.
| The Following User Says Thank You to churchx For This Useful Post: | CSG Mike (04-09-2019) |
#94 |
#95 | |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Big rocks are a valid concern. I've had to replace three windshields over the years. |
#96 | |
My recommendation of a Jackson Racing oil cooler being the bare minimum for a car driven hard is based on a stock engine. Modified engines may need **more** cooling. |
#97 |
Well, then I guess I should reconsider. The Perribn is still new in the box.
#98 | |
Drives: 2014 BRZ - WRB
Since you consider this oil cooler to be bare minimum for track driving, would that mean that the JR dual cooler is better suited to canyon/autocross driving? I seem to remember reading that the dual cooler didn't lower temps quite as much. Thanks! |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Oil Cooler kit for FI applications, getting one? | JoeBoxer | Forced Induction | 84 | 01-20-2013 10:48 AM |
