#85 |
Think i'm going to be taking these out today... I'm all for NHV most of the time but god damn these are intense. Maybe its just a combination of the other driveline modifications but its loud. Probably keep them for auto cross though since its a really simple install.
#86 | |
Back to the drawing board, going to uninstall the Forced Fab and re install the differential bushings. There's a good noticeable difference when taking the differential bushings out. The car felt more solid and quicker off the line with them in. |
#87 | |
Off Topic
#88 |
Got the ForcedFab transmission insert out and the differential bushing re-installed. NO WHINE WHATSOEVER!
Figured out where the vibration was coming from, no crush gasket on the over pipe so there was a phat exhaust leak. Kinda spaced on that one Getting things back on track,,,,,, about to go down and get me some corn juice and try my new OFT. Maybe cause some more headaches |
#89 |
Drives: Scion FR-S 2013 Raven
Whiteline differential insert bushings review
Then if we remove the 2 bushings on the front of the diff, we will remove the clunk and the gear sound?
Maybe the 2 bushings on the back are enough to tight the diff? I wonder if with this setup we can't damage the 2 front oem bushing at long term? Can we have an expert opinion here? @Racecomp guys? Or anyone who have an expertise into this... Thanks!
o= FR-S =o |
#90 | |
The solid feel is still there and I personally cant feel any difference after I took the fronts off. Last edited by Brinks; 08-12-2014 at 11:14 AM. |
| The Following User Says Thank You to Brinks For This Useful Post: | Mikepage (08-12-2014) |
#91 | |
I've gotten used to the sound, which was never really that bad to me anyway, and it's a pain to go under the car and take them out so mine are staying in. |
#92 | |
#93 |
Need feed-back from Guys how have the Diff brace only? Which type of noise you have? Does it clunk? Do you have gear whine?
o= FR-S =o |
#94 |
Drives: Toyota 86 TRD Version AT
Before I installed the outrigger bushings, I had the brace only. I had a slight clunk. After the bushings were installed, I could now hear slight gear whine with a more pronounced clunk during sudden deceleration.
| The Following User Says Thank You to Tye300 For This Useful Post: | Mikepage (08-13-2014) |
#95 |
Drives: '14 FRS White
I have the brace only (and the whiteline trans insert). Slight clunk, slight whine. The whine is barely barely there. Windows up radio off listening closely. lol. Feels great though.
| The Following User Says Thank You to DriftHappens For This Useful Post: | Mikepage (08-13-2014) |
#96 |
Drives: GTS 86
I had these in for quite some time. I also have the Transmission insert bushing and HAD it coupled with Perrin. The sound was way too loud for me and took it out.
But about a month ago I started to hear a humming metal kind of like a grind or something coming from the dif, but I am not sure if it is caused by these. It comes up especially when I am in 5th and 60-70 km/h (38-43 mph) it usually goes away after 5 minutes of driving! Not sure what it is really and I am thinking taking these off and see if the noise is still there! Any advice? |
| The Following User Says Thank You to Hawk77FT For This Useful Post: | Mikepage (08-13-2014) |
#97 | |
You mean you have the rear diff brace and you hear a gear sound?
o= FR-S =o |
#98 | |
What is the brand of your brace?
o= FR-S =o |
| DIY - Whiteline Rear Crossmember Mount Insert Bushings | F1point4 | DIY (Do-It-Yourself) Guides | 91 | 01-17-2021 03:23 AM |
| Whiteline crossmember bushing insert review | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 11-09-2016 04:30 PM |
| Rear Shifter/Transmission Mount Insert Bushings | TheseColorsDontRun | Mid-Atlantic | 7 | 08-30-2013 11:29 AM |
| Whiteline diff bushings and trans mount insert. | Simmons | Transmission and Driveline | 7 | 06-09-2013 09:45 PM |
| WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 5 | 01-16-2013 06:15 PM |
