Old 07-23-2014, 10:40 PM   #85
jng
jng's Avatar
Drives: Toyota 86
Would have preferred to get the header ceramic coated, but no one here does it for a reasonable sum of money unfortunately. The oil cooler is a HKS one, so I think the sandwich plate is from the HKS kit as well. It's pretty effective, starts circulating in the high 80/low 90 (degrees centigrade). Have never broken past 115 degrees centigrade so far.
After a couple of hours of driving, I think this cold air intake would be a great pair with an unequal length header as it would deepen the boxer Rumble.
jng is offline   Reply With Quote
The Following User Says Thank You to jng For This Useful Post:
MINOCIN (07-24-2014)
Old 07-24-2014, 08:10 PM   #86
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Thanks for the info. I'm still trying to decide between this and the Perrin intake.
I have the Innovate super charger w/ intercooler, ceramic coated headers and an oil cooler with the Mocal sandwich plate (same one used in the Perrin oil cooler kit). The temps that I see are similar to yours. So far I have not gone over 240 degrees Fahrenheit (~115 Centigrade) as well.
My concern is that the elbow on the Mishimoto intake pipe looks like it runs a little too close to the oil cooler sandwich plate. The stock air filter box already rubs against my sandwich plate fittings. I guess if it doesn't fit I can always switch to the HKS sandwich plate. According to their website, Mishimoto doesn't appear to sell just their oil cooler sandwich plate.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 07-27-2014, 05:11 PM   #87
nelsmar
Guess what folks! You can install and inspect your filter without removing bumper! I'll tear the car down this week and take some photos of how I did everything. removing the tbar gives enough room!
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
FR-S Matt (07-27-2014)
Old 01-11-2015, 04:45 PM   #88
pepe
Drives: gt86
Hello !. Place the air filter on the end of a longer tube does not cause the motor to perform more work to breathe?
pepe is offline   Reply With Quote
Old 01-31-2015, 04:34 PM   #89
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
It appears to make it easier for the engine to breathe. I'm guessing that the better filter makes up for any added difficulty from the longer tube.
JohnJuan is offline   Reply With Quote
Old 02-14-2015, 11:37 PM   #90
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by wparsons View Post
The pipe diameter isn't what makes it need a modified tune, it's the MAF housing diameter. IIRC, this one uses a stock diameter MAF housing and close to stock MAF location so you don't have to re-scale the MAF in the tune. The Perrin big MAF intake has a larger diameter MAF housing which means you do need to re-scale the MAF.
Thank you! I was needing to find this out, as with the Innovate kit it must be 3" all the way.
Chad86 is offline   Reply With Quote
Old 12-03-2016, 07:22 PM   #91
brz.bros
Drives: blue brz
does the 3inch inlet hose need a tune or just the 3inch big maf intake
brz.bros is offline   Reply With Quote
Mishimoto Needs Your Help With Our BRZ/FR-S Intake! Mishimoto Engine, Exhaust, Transmission 10 03-31-2014 10:30 AM
FS: MISHIMOTO INTAKE TUBE BlackyRose Engine, Exhaust, Bolt-Ons 4 03-09-2014 05:17 PM
Testing Our New Vortech Cold Air Intake @ Pure Automotive Performance! Dyno's Inside! Pure Automotive Forced Induction 24 10-21-2013 12:29 AM
AMR Performance: Cold Air Intake System - BRZ/FR-S/GT86 AMR Engine, Exhaust, Transmission 10 04-11-2013 12:37 PM
*Pure Automotive Performance: Project Whiteout FRS Build Thread* Pure Automotive Member's Car Journals 6 01-18-2013 12:34 PM
