#85 | |
Drives: 13 BRZ WRB
Is your overpipe front piper resonated with the Hemholtz?
#86 |
It had a cat with the Hemholtz, it's up for sale now in the classifieds. I was tempted to cut the hemholtz off and weld the pipe shut to see if it would help . My guess is that it would probably just add rasp.
EDIT Just sold the downpipe with the hemholtz. Going to purchasing a non resonated downpipe in about three weeks, so ill update then. Last edited by Brinks; 08-14-2014 at 11:46 PM. |
#87 |
Drives: t
anyone got leaks at the manifold flange? we tightened the nuts to 50 ft lbs, using the OE gasket, and see some leak at the flanges using a smoke machine.. also the usual leak at the overpipe/header.. using all namless parts.. 2.5 op/fp combo.. we used their 3inch gasket with vibrant 2.5inch gasket..
#88 |
Drives: 2013 Frs
Finally had time to dent the pipe after 3k kms of it being on. Tried the mallet first and nothing happened regardless of how hard I hit it. So I ended up using a small hammer. Good news is that no more contact with the engine. Bad news is the grey spot in the middle of the dent. This is where the engine made contact with the pipe previously. Sadly, it looks like a small portion of the engine piece melted on the pipe... Engine looks fine as it was only a extra piece.
#89 |
Drives: '13 FR-S, '12 CBR1000RR, 10 Cayenne
Is this an indication to avoid the one pipe from nameless. I assumed toyota design this two pipes for a reason.
'13 FR-S Blue (Daily Driver)
'12 CBR1000RR (Weekend toy) '10 Porsche Cayenne S (EVOMSit tune)- Hauling toys '10 BMW 550i (Burger Tuning) - church & late dinner car '10 BMW 335i FBO (Sold) and many other cars.... |
#90 | |
Drives: 2025 BRZ, ex-2012 GT86
#91 | |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Anyone hear anything about a fix for this other than denting the pipe? I'm not trying to buy a pipe I have to modify and I'm damn sure not shifting the engine for it. I guess I'll just go with Motiv/Berk.
#92 |
Drives: 13 SWP BRZ Prem
Yeah I wouldn't recommend it.
My second pipe I received had better fitment (At least so I thought) When I installed it, it was all peachy (albeit very close, it wasn't touching.) I had my car's tranny replaced under warranty, and now I hear a slight rattle at times, I think it's when they reinstalled the pipe or the tranny something shifted and I no longer have the clearance I use to. I need to go under and see if I can get more clearance. I wouldn't recommend the Nameless Combo pipe. I would either just get their Front pipe and grab someone else over pipe or go with a different combo all together.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
#93 |
Drives: 13 FRS
I hope they resolve this issue soon...
Current: FRS(Daily), Cayenne(Weekend), 1000RR(Fun), 650Maxim(Fun).
Recently Sold: 13 Boxster(Crash), 08&10 335i, 08 M3, 12 A4, 97 NSX.... |
#94 |
Drives: Slow...
I had this exact issue...contacted them on FB and they seemed to dance around the issue without trying to come up with a solution. I'll probably be ditching mine soon as i'm already looking at alternatives...
#95 |
Drives: '13 LR BRZ Limited| '07 Jeep GC
I also had fitment issues and the rattle from the resonator which they are fixing. I did find this though. The flange for the header isn't perfectly straight which then puts the rest of the pipe on a bind.
'13 Lightning Red BRZ
Mods: Grimmspeed Cold Air Intake|FT86SpeedFactory Stage 2 Tune|FT86SpeedFactory Catted header|Nameless Catted and Resonated OP/DP|Perrin Resonated Cat-back| |
#96 |
Drives: FRS-Raven-MT
Nameless header + overpipe fitment issues
Delete
#97 |
Drives:
When I first got my nameless axle back and op/dp combo and install it. I remember I had to lift up the engine to get the op/dp to for. It was fine and now recently I can hear it rattle in the front when I'm at 4k rpm. Is this may be a leak issue or something else?
#98 |
Update: I sent the pipe back to nameless because of the rattle on the resonator. They were able to fix the flange and the resonator. Everything fits perfectly now and it sounds amazing.
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Sold | Yamaha_R6 | Engine, Exhaust, Transmission | 0 | 03-03-2014 08:28 PM |
| Overpipe fitment? | IAmNotTheDriftKing | Engine, Exhaust, Transmission | 14 | 10-05-2013 02:45 AM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 04:34 PM |
| Is this what they mean by panel fitment issues? | ahquit | Issues | Warranty | Recalls / TSB | 7 | 08-21-2012 04:19 PM |
