Old 10-05-2014, 07:14 PM   #85
kodyo
Drives: Scion FR-S
Alright, so here's the scoop. I got sick of waiting a week+ in between emails with Spence at Weir Performance, so I went about finding an alternative gear solution. Based on some stuff I was reading, I decided to buy a set of Motive Gears for a V6 toyota (People were saying that pretty much any 8" ring/pinion for a toyota would fit). I went with the V6 over the 4 cylinder version because it had the correct tap size for the ring gear attachment bolts. Here is the link if anyone else wants to go that route.:
http://www.jawsgear.com/Ring_And_Pin...s-Toyota-8-V6/
That being said, after a quick comparison, it is quite clear that the Weir Performance pinion gear has MUCH thicker teeth than the Motive Gears. Probably on the order of 20%+ if I had to put a number to it. So if you want to go higher power than stock, I think that is probably the safest route. For a stock-ish FRS, I'm guessing the motive gears will work just fine.
I put the OEM differential back in yesterday so I could choose not to rush this rebuild (the car feels hella slow now). I bought a 12 ton press from harbor freight, which made the process go so much faster. If you don't want to buy a press, there is a trick for quick setup. What you do is you take an old/scrap pinion bearing and sand down the ID so it can be easier to put on/take off. Use this bearing for setup and then once setup is done, use the new bearing to get final position and for install.
Here is the progression of pattern I saw as I went through setting up the gears. Measured the backlash to be .011 (.007-.009 being preferred), so I will be buying new shims along with new seals (noticed some diff oil on the under side of the car upon removing the 4.56 diff last).
First Setup:
Second Setup:
Final Setup:
(180deg from first image)
After correcting backlash, I'll recheck mesh again before install. Relatively happy with where it sits right now.
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
civicdrivr (10-06-2014)
Old 10-16-2014, 10:54 PM   #86
kodyo
Drives: Scion FR-S
Got the Motive Gears setup and in the car. I've basically become an expert at getting the differential in and out, haha. Took me 2 hours to get old one out and new one in this time, a new record.
Anyways, no more whine from the gears, so I think they are setup right this time. Going through a more extensive 100 mile break in (20 miles at a time, no speeds above 60 mph), then no heavy acceleration for 500 miles with an oil change at the end of that.
I did kind of figure out the difference between the Motive Gears and the Weir Performance Gears. See the drawing below, but basically the motive gears are positioned further into the ring gear than the weir performance gears, and thus, operate on a smaller tapered section of the cone defined by the pinion gear. What this means is that the ring gears are basically identical, but the teeth on the pinion will appear smaller on the motive gear than on the weir gear since the gears are designed to operate at a different depth relative to the ring gear. What this means for the actual strength of the gears is anyone's guess. I'm not sure now if that necessarily means one set is inherently stronger.
Old 03-22-2015, 08:41 PM   #87
Joeyk
Drives: It runs
I was trying to call/e-mail Spence @ weir but no reply or phone calls getting thru.
when I call it goes straight to voicemail.
Should have bought the set when I could get in touch with him.
going to get the 4.8 gear set.
Joeyk is offline   Reply With Quote
Old 04-20-2015, 06:44 PM   #88
Joeyk
Drives: It runs
Got the 4.88 gear from weir. Can't wait.
I love the added tq feel on my s2k after the 4.7 Fd.
Waiting on the Tomei LSD to get them all installed at same time.
Old 04-20-2015, 10:17 PM   #89
kodyo
Drives: Scion FR-S
Manual or auto?
Old 04-20-2015, 10:57 PM   #90
mrk1
Drives: Sterling BRZ Ltd
I finished my 4.44 install the other day with MFactory gears and Weir install kit. I am getting a slight whine, I mean no radio, windows down, stock exhaust, and listening for it slight. If it persists past break in I maybe concerned but for now its not on my mind.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-21-2015, 09:24 AM   #91
mrk1
I contacted MFactory about the slight whine I'm hearing, here is there response.
"whine is normal due to the different tooth angle on the final drive."
The Build Thread
Old 04-21-2015, 05:54 PM   #92
kodyo
Drives: Scion FR-S
I got whine on mine, as you can read earlier in the thread, from a poorly setup gear mesh. I'm not saying that is the issue you are getting, but once I got a new set of gears and meshed them correctly, I had no issues. So if you had a shop set it up, it might be worth contacting them about. I have hard about aftermarket final drives whining due to the tooth angle. It all comes down to how loud it is. Mine was fairly loud and was on decel only.
Old 04-21-2015, 10:18 PM   #93
Joeyk
Drives: It runs
Mine is Manual.
little whine can occur since you are turning more per rev now and is not used to the sound. Too much whine can occur from improper set up.
Weir seemed like he knew what he was doing so I doubt its the install error.
Old 04-21-2015, 10:53 PM   #94
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I have 4.88s from Weir in mine and it makes no noise at all.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
CSG Mike (04-22-2015)
Old 04-28-2015, 09:06 AM   #95
Joeyk
Drives: It runs
What speedo calibrator are you guys using?
Old 04-28-2015, 10:11 AM   #96
mrk1
I built this diff myself so thats why I asked the manufacture and they said it was the tooth angle. I bet if I reinstalled my back seat I wouldn't even hear it, its that quiet.
On a side note I've been taking the long way to work just because its so much more fun to drive this car now.
The Build Thread
Old 04-29-2015, 12:01 AM   #97
kodyo
Drives: Scion FR-S
No speedo calibration needed. Speed is taken at the wheel sensor.
Joeyk (10-10-2015)
Old 08-26-2015, 10:47 AM   #98
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
@Dustin @kodyo where you able to measure the pinion depth spacer?
GT86drifter is offline   Reply With Quote
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
Considering going to 3.727 gear/pinion in 6MT HotLavaMann Engine, Exhaust, Transmission 83 01-10-2015 10:34 AM
3.9 final gear - ring and pinion PantsDants Engine, Exhaust, Bolt-Ons 5 11-08-2013 03:06 AM
MFactory Ring and Pinion Sets JMPoole Engine, Exhaust, Bolt-Ons 14 07-31-2013 12:09 PM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 05:12 PM
