Old 02-12-2014, 12:59 PM   #85
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Yomny, if you can consistently get 93, totally go for it. Car was designed for 93 octane if I remember what the inside of the gas flap says correctly
Zach3794 is offline   Reply With Quote
The Following 2 Users Say Thank You to Zach3794 For This Useful Post:
Sportsguy83 (02-12-2014), yomny (02-12-2014)
Old 02-12-2014, 01:35 PM   #86
Zach3794
To add to that, you should not only get more power but better fuel economy on 93 octane. When testing maps specifically designed for lower octanes, it was noted that power and fuel economy both suffered. (Referring to 87 and 89 octane specific maps)
The Following User Says Thank You to Zach3794 For This Useful Post:
yomny (02-12-2014)
Old 02-14-2014, 04:50 AM   #87
FR-S Matt
Originally Posted by DeliciousTuning View Post
Hi, would this in regards to the completely stock tune on the vehicle, that it drops to 500 RPM's? Yes even my car does that and I have not looked into that much as of yet, but I will. I will need to look at this a little more closely to see exactly what is causing it and take a look at it.
All pricing is on our website.
But it is something I will look at a little more as it is a common problem in every vehicle.
Cheers,
William Knose
From what I've seen, the idle is just slightly bumped up in rpm to keep it from dipping. The flash at the dealer does the same thing. My car did the same thing for a while, but after break in, I didn't see it. When I got a tune, they stated the idle dip issue was "addressed".
Old 02-14-2014, 02:51 PM   #88
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
The flash upgrade from the dealer was performed when? Just would like to know as we purchased our development car near the end of 2013. But we still have the dip, every so often.
Cheers,
William Knose
Old 02-14-2014, 02:57 PM   #89
anajri
Drives: GT86
I had a similar problem and then all of the sudden the car would not idle at all.
checking after checking found that under the engine cover are some vacuum hose check them becasue ever sine i fix that i have had no idle issues anymore.
even with Williams tune
regards
ALfredo
anajri is offline   Reply With Quote
Old 02-14-2014, 05:07 PM   #90
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
regards
ALfredo
I'm having a similar problem but i have no vaccum issue. All hoses are plugged in.
carlossanchez89 is offline   Reply With Quote
Old 02-14-2014, 06:29 PM   #91
FR-S Matt
Cheers,
William Knose
I would have to look at the TSB's again. I want to say it was late last year, around August/September.
Found it in the TSB thread:http://www.ft86club.com/forums/showthread.php?t=21868
Looks like it was November.
Old 02-14-2014, 06:55 PM   #92
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
The tsb was released December 2013. I just had it done. The only way they would do it is if the cars "problem" could be replicated. Fortunately my rpms dipped and they noticed.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-16-2014, 12:51 PM   #93
carlossanchez89
2Supras1FR-S
Bill I emailed you my logs.
Car idle is unsettling in the 91 map. Daily driver here!
Please get back to me!
Old 02-17-2014, 01:06 PM   #94
yomny
yomny's Avatar
@DeliciousTuning - Just out of curiosity does your tune correct the infamous "tip-in" knock seen around youtube? I recall having this back in 2012 when ecutek and visconti were the only thing around and no one had a clue. It has been said that some cars have this even with oem tunes(the knock sound when sharply slapping the gas pedal).
Old 02-17-2014, 01:12 PM   #95
Zach3794
While I'm sure that can be fixed, why are you slapping the gas pedal? Roll onto it..slamming the pedal is never a good idea imo
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Old 02-17-2014, 03:02 PM   #96
yomny
yomny's Avatar
It's just a figure of speech to try and describe getting on the pedal hard. When you're shifting quick most people just stomp the gas which is what I refer to by "slap" the gas pedal. This isn't happening to me but I see around the web that the tip in knock is popular. The description is a means to an end not the problem here so lets direct back to the point.
The Following User Says Thank You to yomny For This Useful Post:
Sportsguy83 (02-17-2014)
Old 02-17-2014, 04:28 PM   #97
jamesm
It can be eliminated with a custom map (timing comp, rpm or load vs throttle delta). I usually don't mess with it though since it's not much of an issue. Save the custom maps for more useful projects .
The Following User Says Thank You to jamesm For This Useful Post:
yomny (02-17-2014)
Old 02-17-2014, 06:01 PM   #98
yomny
yomny's Avatar
I remember having this with my first visconti map back in 2012. I thought it was just me back in the days but i see a few people are having this issue years later. Thanks @jamesm
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
