Old 07-22-2014, 09:30 PM   #85
lucid215
i did a log today on my 13 brz. im running the oft stage 1 map and my mods are takeda intake, invidia over pipe, invidia catless front pipe, and jdm trd exhaust. just thought i let you guys see how the car runs with mods and the stage 1 rom
http://www.datazap.me/u/lucid215/sta...g?log=0&data=1
lucid215 is offline   Reply With Quote
Old 07-24-2014, 06:56 PM   #86
lucid215
did another log but i switched to a different rom (same stage) and i dont think the car fully learned it yet
http://www.datazap.me/u/lucid215/sta...data=1-9-10-12
Old 07-26-2014, 09:50 AM   #87
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
so on the OFT when it says KC learned what do you want those numbers to be at ? i just flashed and drove home only about 14 miles but the numbers under WOT jumped to around 4 isn take a look if you can read data logs =)
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 08-07-2014, 12:25 PM   #88
joshb86
Drives: '13 FR-S
Here is a log from my Vortech Supercharged FR-S. Curious to get a second opinion outside of my tuner... I guess I honestly just felt like it would take longer to get a solid tune and expected to feel a little more power?
http://datazap.me/u/joshb86/log1?log=0&data=5
joshb86 is offline   Reply With Quote
Old 08-08-2014, 08:26 PM   #89
JB86'd
JB86'd's Avatar
Drives: JAWS
I came in here to post my datalog and just tripped the F*&# out. good name you got there. @joshb86
http://datazap.me/u/joshbustos86/frsaug8?log=0&data=1
Old 08-11-2014, 10:43 AM   #90
wparsons
wparsons's Avatar
OFT 2.0b 93, stage 1
http://www.datazap.me/u/wparsons/aug...data=1-5-11-12
flickr
Old 08-11-2014, 12:04 PM   #91
lucid215
OFT stage 2 uel 93, takeda intake, OFH, invidia over/front pipe, JDM TRD axle back
http://www.datazap.me/u/lucid215/sta...0?log=0&data=1
Old 08-15-2014, 05:27 PM   #92
Wepeel
Drives: '13 BRZ Ltd
So I see it in my logs and in other people's logs - ltft seem to have a shift point on WOT runs as it crosses right around 5k rpm. I know on a previous platform I had experience on, the LTFT of the highest airflow range was applied during open loop WOT runs, so it would be constant. What is the logic for applying LTFT to the WOT runs on the BRZ? Are there two different values it uses from the closed loop airflow ranges?
Wepeel is offline   Reply With Quote
Old 08-17-2014, 09:17 AM   #93
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Recent test 75F
http://www.datazap.me/u/tonystewart/...log=0&data=1-7
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-17-2014, 12:15 PM   #94
Wepeel
Drives: '13 BRZ Ltd
Originally Posted by tonystewart View Post
That's in interesting jump in engine load at 6k rpm.
Old 08-17-2014, 12:49 PM   #95
tonystewart
What causes that?
AFR begins to drop at 6K
Old 08-20-2014, 09:12 AM   #96
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Can someone please comment on this. I think it's running rich but I'm no expert. Custom Map A is my AEM wideband hooked into the ECU. Kraftwerks, 91 octane tune. It just seems richer than it needs to be.
http://datazap.me/u/postbreak/kraftw...0&data=5-25-34
post_break is offline   Reply With Quote
Old 08-31-2014, 11:17 AM   #97
jester04
Drives: Subaru impreza STI, subaru BRZ
Post up a log of a pull!
You are concerned with daily driving afr or wot fueling?
jester04 is offline   Reply With Quote
Old 08-31-2014, 04:35 PM   #98
post_break
post_break's Avatar
I stopped running this tune because it stalled on me a few times.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
