Old 08-30-2013, 07:05 PM   #85
Racecomp Engineering
Your alignment ideas are good....-3 front and around -2 rear. I think we're at -2.2 or so and it's good.
- Andy
Old 08-30-2013, 07:36 PM   #86
BRZ NA
Drives: WR blue
Ride height 2"drop all around shouldn't be too low?
BRZ NA is offline   Reply With Quote
Old 08-30-2013, 08:03 PM   #87
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Racecomp Engineering View Post
I would like to dyno them myself.
The compression adjuster doesn't seem to be doing much in the low-speed range and is basically just moving the knee. Big effects on mid and high speed. Yes you can feel that but there isn't a huge amount of benefit. Honestly they're only "digressive" in compression when they're cranked way up.
- Andy
The dyno on their standard digressive valve looks more normal than their "ultra digressive". On the "ultra digressive" they ramp up from 1 in/sec to about 3 in/seconds before it starts to flatten out. Maybe there is a reason it was done that way.
Old 08-30-2013, 08:06 PM   #88
My ideal track set-up....hmmmmm.....
Coilover: JRZ motorsports 4 ways (with JRZ Bryan Hise helping us with set-up)
LCAs: Don't care, something with quality pillowballs
Other components: replace all bushings with pillowballs. Front roll center adjustment. Lowering camber plates. Lowering rear top mounts.
Alignment: -3.5 degrees front, -2.2 degrees rear camber, or in that ball park depending on spring rates and tires. Toe to suit driver. Caster to suit track
That would be pretty nice. Pinch me.
RCE T2 clubsports would be the realistic choice but if we're dreaming....
Seriously, I really like our RCE T2 clubs. For the money it's hard to beat. Replace the JRZs with our stuff and you're still sitting pretty and your wife/husband/SO won't stab you because going out to dinner now means peanut butter jelly time.
- Andy
Well shit, if we're going infinite budget... I was just listing our current setup
Old 08-30-2013, 08:09 PM   #89
Originally Posted by solidONE View Post
What about these guys?
The digressive valving looks pretty decent with really broad range of adjustment, though not quite sure how digressive rebound damping is beneficial to performance. I'm used to seeing just digressive comp damping in some premium grade dampers (penske ohlins). I think AST are going double digress ive with their new 4150 line as well. Fortune seems to offer different valving to match whatever spring rate you order. This is much better than a lot of other brands who only offer the same damping curves for different spring rates. Seems like the components they use to build their dampers are really good quality as well.
What do you guys think?
It's the same picture they use... I'd like to see application specific. I've never seen substantiated results from FA.
They've claimed SCCA/NASA wins, but when that win is from being the only car in class and/or from just showing up to the most events, I don't buy it.
Old 08-30-2013, 08:11 PM   #90
IMO, it's too low. I'd recommend getting the Ground Control front mounts to regain some lost bump travel, and @Robispec rear mounts, again, to regain lost bump travel, as well as Robispec arms to correct roll center.
Old 08-31-2013, 12:39 AM   #91
BRZ NA
Drives: WR blue
I was thinking if I use robispec arm so I don't need camber plate to adjust camber, is that right?
Old 08-31-2013, 01:00 AM   #92
BRZ NA
Drives: WR blue
How about 1.25" to 1.5" drop? will it lost bump travel? so what's the Max can u lowered so that it won't need to regain lost of bump travel?
Old 08-31-2013, 02:28 AM   #93
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by TheseColorsDontRun View Post
Ok so I know we have all experienced the drivetrain slop in these cars. Lots of transmission and diff bouncing
[rant]
I'm sorry but I don't know what you are talking about. I have asked in another thread for this slop to be explained but I can not pick it. I was expecting after having rear subframe bushes (not inserts) and diff carrier bushes (inserts) fitted there was going to be some huge revelation. I (ymmv) couldn't tell the difference. Same with TiC alloy rack bushes. Maybe there was a difference. Then again it may have been placebo.
[/rant]
Old 08-31-2013, 03:08 AM   #94
whataboutbob
AutoX-10/10ths every run
I was just thinking about how it might be useful to characterize the camber/toe changes that result from various levels of suspension compression. Thoughts?
Build thread:Here
Old 08-31-2013, 10:07 AM   #95
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Curious about using the @robispec arms to adjust camber in front as well...in addition to correcting roll centres and adding caster.
Also curious to know whether being able to have more than 2degrees of camber up front will increase front grip on street tires (driven on street, autoX & track).
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-31-2013, 10:27 AM   #96
Dezoris
Dezoris's Avatar
I have been on sticky 225 and 235 RS3 with -1.5 up front on stock suspension and even heavy autocross I can correct wear with pressures.
I think -2.0 might be too much for street but will be great for track and ok for autox. That is what I will be running soon to test
Old 08-31-2013, 10:30 AM   #97
Dezoris
Dezoris's Avatar
So 15mm drop is this magic number thrown around where did this come from? Is that the farthest you can go on stock suspension geometry without negative effects?
Old 08-31-2013, 11:01 AM   #98
ft_sjo
Drives: GT86
Both the STI & TRD springs, and I believe the Ohlins recommendation is -15mm..
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
