Old 06-06-2013, 11:51 AM   #85
FAER
Drives: Silver BRZ
Any word yet on whether this will cause fitment issues with the AVO turbo kit?
Money in hand
FAER is offline   Reply With Quote
Old 06-06-2013, 11:55 AM   #86
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Money in hand
I will try it next week (already have it sitting in the garage), so keep an eye for my review.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Mr.Jay (06-06-2013)
Old 06-06-2013, 11:56 AM   #87
FAER
Drives: Silver BRZ
Sweetness...
The Following User Says Thank You to FAER For This Useful Post:
Sportsguy83 (06-06-2013)
Old 06-06-2013, 12:51 PM   #88
OrbitalEllipses
Drives: Attitude
Originally Posted by Brzzee View Post
Web surfing the other night and came across an Oem oil/water cooler Subaru mounted on 08-11 WRX & Sti EJ257 & EJ255. Mounts between block and oil filter. Haven't had a chance to find the dimensions of the adapter threads. If they match FA20 threads then this might be an alternative. The EJ filter mounts on the bottom of the engine. this cooler would mount on the FA20's top without the need for a spacer.
Any thoughts?
Yeah, that's technically an oil HEATER. Gets it to temp faster.
I just don't like the idea of using hot coolant to cool hot oil. I am buying the Full Blown oil cooler this week.
You want to be using thermostatically controlled coolant coming FROM the radiator before going to the engine, which is how I thought the @robispec total cooling solution works. Note: his might not be thermostatically controlled, but that would be "best".
Old 06-06-2013, 03:54 PM   #89
wootwoot
Drives: FRS
If you did that wont you be heating up your coolant before it goes into the motor? That would be good for the oil but bad for the coolant. I was under the impression you want to tap the water coming out of the engine. This works, I thought, because of the difference in optimum temperature between the two liquids. Coolant around 185F, oil around 220F.
wootwoot is offline   Reply With Quote
Old 06-06-2013, 04:07 PM   #90
OrbitalEllipses
Drives: Attitude
The Impreza one does function as a heater mainly because I think the "cooler" itself isn't big enough to cool shit.
EDIT: Just thought about it. With a heat exchanger that cools using coolant, like the @robispec solution, doesn't the unit have its OWN coolant loop, separate from the engine coolant loop? That would solve the problem you brought up. Add thermostat to the loop and it's even better!
Old 06-06-2013, 04:18 PM   #91
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
I want to install mine already!!! but I should just wait until I get hoses..
RD1428 is offline   Reply With Quote
Old 06-06-2013, 04:23 PM   #92
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would definitely wait till you get hoses.
Old 06-06-2013, 04:23 PM   #93
wootwoot
Drives: FRS
The heat exchanger is so small on the wrx unit that it won't effect the coolant temp too much. The cusco cooler is essentially the same thing. With a proper core I think you would have to place it on the hot side of the radiator to preserve coolant temps.
Old 06-06-2013, 05:52 PM   #94
FAER
Drives: Silver BRZ
I think i'll just get a ram air hood and a regular air/oil cooler and mount it like a top mount IC :P
Old 06-06-2013, 06:29 PM   #95
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Waiting until I get my hoses is what I'm going to do.
TRD_07 is offline   Reply With Quote
Old 06-06-2013, 06:51 PM   #96
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Damn! Went to pick up my rad and just when I got home got a message saying my hoses just arrived.. ahh got to wait till next weekend now
Hopefully we can make a list of FI options this rad works for and which it doesn't as well.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 06-07-2013, 12:44 AM   #97
robispec
Drives: Black frs project
Both fluids cool the engine.
Most engine builders like to keep these temperatures as close together as possible And as cool as possible.
Reality is thermal limits generally run the water somewhere between hundred and 80 and 200 ° in a Race motor. And oil temperatures run just over 212 °
Water returning from most radiator system is over cooled.
You want the delta or the difference between any two fluids to be as high as possible in order to achieve the maximum thermal efficiency in transferring heat from one fluid to the other.
This is especially important when you're trying to transfer heat from a fluid that has a high thermal capacity like water or coolant or oil and fluid like air has a very low thermal capacity and must make up this lack by using tremendous CFM to keep up with the high thermal fluid capacity fluids.
So a typical delta for air to liquid would be over 100 Degrees.
When you have to like fluids of thermal capacity like oil and water the Delta can be significantly closer.
And most of these systems see about a 50 to 60 ° Delta.
That's why you want to you run the oil heat exchanger in the cold side tank because the water and except as much thermal energy from the oil as possible while not overheating the water because only so much can be shed before it's returned to the engine
robispec is offline   Reply With Quote
The Following User Says Thank You to robispec For This Useful Post:
Brzzee (06-07-2013)
Old 06-07-2013, 12:58 AM   #98
mashal
DADA
mashal's Avatar
Drives: 2013
Originally Posted by FullBlown View Post
Will do buddy. It shipped, I will get a tracking tommorow. Thanks
Still waiting on a quote
mashal is offline   Reply With Quote
Where are the aluminum driveshafts? post_break Engine, Exhaust, Transmission 22 04-01-2013 05:31 PM
Black Friday @ CMS - Coilovers - Exhaust - Radiators - Suspension - Gauges + More! Circuit Motorsports Announcements, Contests, Giveaways 1 11-26-2012 05:43 PM
Why no aluminum??? epson1 Engine, Exhaust, Transmission 41 08-01-2012 01:18 PM
Steel Vs Aluminum in the FT86 blur Scion FR-S / Toyota 86 GT86 General Forum 72 06-08-2011 03:35 AM
