#85 |
Drives: Nissan 350Z (sold) 13' Whiteout FRS
not sure if this has been asked already, but estimated price?
#87 | |
| The Following User Says Thank You to Raceseng For This Useful Post: | whataboutbob (11-11-2013) |
#88 |
The bearing housing is offset 1/4" from the centerline of the plate which yields about 1/2 degree of positive caster. You can get an additional 3/16" of caster travel by sliding the camber plate backwards.
#89 |
Drives: 2013 SWP BRZ
Price?
#90 |
Drives: Mazda 3
question about adding bump travel: Does adding bump travel mean losing droop travel of the shock? I'm curious if it is the case and if it doesn't matter on our cars...
If shocks are designed to work at a certain ride height, does adding bump travel - moving the shock shaft up beyond the designed working ride height of the shock. Does this matter or is the shock happy at higher heights just not lower? Also, will you make a set of plates that work with stock shocks and stock spring size while keeping the stock ride height? |
#91 | |
But... If you somehow increase/add bump travel, you might lose droop travel because the coilover can only extend itself out so far. If you have any other questions, please feel free to email me - jarrett (@) raceseng.com Thanks much |
#92 |
AutoX-10/10ths every run
Front: http://www.raceseng.com/cascam-caste...subaru-brz-724 $595
Rear: http://www.raceseng.com/shock-top-20...r-s-subaru-brz $325 (for KWv3)
#93 |
Hey Jared I saw you had support for the MCS shocks for the rears, do the fronts work as well without any special sleeves/nuts? What about the upper perch?
#94 |
Drives: '13 BRZ
Just placed an order cant wait for this masterpiece
400+whp
| The Following User Says Thank You to slowmo For This Useful Post: | Raceseng (11-20-2013) |
#95 | |
Depending on the coilover, we might already have the parts to make the MCS coilovers work! There is a downloadable form on the product page which you can fill out and send to us. We provide a spring perch with the CasCam, they are available for 2 1/2", 2 1/4" and 60mm springs. Please email me directly if you have any other questions - jarrett@raceseng.com |
#96 |
Just got a set of these intoday. Will have them on display at 86Nation. Very very nice pieces!
| The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post: | Raceseng (11-20-2013) |
#97 | |
Cool. I am Phil I emailed you the MCS CAD diagrams some time ago. They work with the stock BRZ tophats in the front, the top of the shaft is identical to stock, so if you know what combination works with the stock struts it would work with the MCS ones in the front. Same goes for the rear. |
#98 |
Drives: 2015 WRX
| The Following 2 Users Say Thank You to Malt For This Useful Post: | Raceseng (12-14-2013), whataboutbob (01-06-2014) |
| Tags |
| billet, billet aluminum, caster adjustment, caster camber plate, raceseng |
| Tein Flex Z Coilovers | Evasive Motorsports | Brakes, Suspension, Chassis | 54 | 07-16-2017 02:21 AM |
| Raceseng | Billet Aluminum Engine Pulleys | Raceseng | Engine, Exhaust, Transmission | 174 | 07-24-2014 01:24 AM |
| Raceseng | Lightweight Billet Aluminum Tow Hook | Raceseng | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-27-2013 02:48 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-28-2013 12:38 AM |
| SRP Billet Aluminum Door Sills | pedalpusher | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-20-2012 07:44 PM |
