Old 08-11-2013, 09:02 PM   #85
Yruyur
Yruyur's Avatar
I think it looks sexy as hell. May be the way that I end up going. Even though 280 is more than I wanted. Can wait to see the details.
Sent from a Motorola DynaTAC 8000X
Old 08-11-2013, 09:12 PM   #86
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
sounds too good to be true... I hope they use the stock box or at least some form of intake box! I like preserving OEM as much as possible. Also hope I can keep the hood heat shield
Pablitomarrero is offline   Reply With Quote
Old 08-11-2013, 09:18 PM   #87
Shit Luck
Drives: red frs
Originally Posted by RaLo View Post
My guess is they are using a C30-74 Rotorex supercharger since they use that for all of their other kits.
http://www.alfaclub.pl/Rotrex%20C30.pdf
280whp sounds about right... the questions I have are what fuel did they tune on (tired of seeing e85 tunes, need real-world pump gas maps), and what supporting mods was the tune done on (exhaust parts, fuel pump/injector upgrades).
I was thinking this maybe 30-94 unit but who knows till they tell us.
Shit Luck is offline   Reply With Quote
Old 08-11-2013, 09:56 PM   #88
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by FRSRAVEN View Post
Was he talking WHP or HP numbers? 280 WHP is a pretty strong showing, especially compared to the HKS unit, with is also Rotrex based. 280 engine hp puts it in line with all the other supercharger kits.
The Rotrex material I've seen usually shows crank HP, but that seems kind of low.
Old 08-11-2013, 11:38 PM   #89
wootwoot
Drives: FRS
Not exactly an OEM looking kit.... Anyone ask them about CARB approval?
wootwoot is offline   Reply With Quote
Old 08-12-2013, 01:42 AM   #90
ft_sjo
Drives: GT86
Originally Posted by Shit Luck View Post
i really want a rotrex unit..
just need someone to make me a bracket to move it to where the ac currently resides so i make the plumbing work for me.
You can't easily as the typical model you'd want to use only spins the wrong way.
Old 08-12-2013, 01:55 AM   #91
NoppyNop
NoppyNop's Avatar
Drives: 2017 Subaru BRZ, 1994 Mazda Miata
Here are the pictures I took from Jackson Racing's booth. As far as CARB goes, I'm sure they are going to go the same route as other kits and get it CARB certified.
NoppyNop is offline   Reply With Quote
Old 08-12-2013, 02:36 AM   #92
FRSRAVEN
So we are talking about 260WHP and 185 ft/lbs of torque at 9 psi. That is on par with the Vortec and Innovate units, and makes more sense then the 280whp number that was mentioned earlier.
How I got my estimate
+54% of 200hp = 308hp (crank) - 15% for driveline loss = 260whp
+45% of 151ft/lbs = 219ft/lbs of torque (crank) - 15% for driveline loss = 186ft/lbs
Rough estimates of course...
Also, it uses a dedicated oil cooler for the Rotrex unit. Without additional knowledge, I'm assuming this is standard for Rotrex supercharger units? Anyways, it should increase reliability for track scenarios. I always wondered about the self contained oiling systems in these superchargers. That oil has gotta get pretty hot on the track...
FRSRAVEN is offline   Reply With Quote
Old 08-12-2013, 03:31 AM   #93
sw20kosh
Drives: 2013 Black FR-S
It is the same unit that does this on a 8th gen civic...
God I wish our motors rev'd that high!
Old 08-12-2013, 03:36 AM   #94
ft_sjo
Drives: GT86
It's much the same as Litchfield's convesion: http://www.ft86club.com/forums/showt...ght=litchfield
.. but I believe Litchfield and Rotrex are working together to create something bespoke, so may be better than the Jackson offering.
Old 08-12-2013, 08:39 AM   #95
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Why didn't you get a Civic?
You can still swap in a K series motor and make your 86 rev that high
(I keed)
Old 08-12-2013, 08:50 AM   #96
Foobar
SLO NO MO
Foobar's Avatar
The oil cooler is necessary in a Rotrex due to its use of traction drive planetary rollers instead of gears. There's a lot friction generated and the special oil plays a pivotal part in this. From what I've read, overheating oil is generally the most common failure.
According to Rotrex, these things aren't rebuildable, but aside from changing the traction fluid and filter every 50K/2 years, sounds like it should last a long time.
I like how this kit is completely bolt on - No Grinding, No Drilling, No Tapping. I also had good experiences with Jackson Racing from my old CRX days - nice to see them in this arena.
For anyone who saw this in person, was there a heat shield around the air filter?
Old 08-12-2013, 08:52 AM   #97
Skyllz
Drives: Something fun.
Any details on fueling? ECUTek i'm guessing?
Skyllz is offline   Reply With Quote
Old 08-12-2013, 08:55 AM   #98
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Did anyone get pics of where the SC Oil Cooler is mounted? Hopefully the charge pipe coming off the SC leaves enough room for engine oil cooler lines to run from a sandwich plate and there is room in front of the intercooler for both the SC oil cooler and an engine oil cooler. That will be crucial for track cars.
Enjuku Racing - Installs Vortech Supercharger Kit Enjuku Racing Forced Induction 9 03-12-2013 01:32 PM
Anybody catch this? Stout Racing SCCA Scion FR-S w/ TRD Supercharger at SEMA BK025 Scion FR-S / Toyota 86 GT86 General Forum 68 01-30-2013 03:29 AM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
FRS Jackson MS execoll Southeast 0 09-18-2012 09:53 AM
SWP BRZ at Jackson, MS Dealership execoll Southeast 0 09-15-2012 07:17 AM
