#85 |
Drives: Black 2013 FRS
I can't, but I remember reading somewhere that it is necessary to prevent interference with the purple spring cup and the rubber of the whiteline mount. It's a beveled washer which ensures that only the centre of the bearing is in contact with the strut.
#86 |
Drives: Attitude
Only required if you're not using the OEM upper spring seat/perch/black thing.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | ATL BRZ (06-07-2013) |
#87 |
Drives: White FR-S
So is the answer to these problems in the washer? Can someone in-the-know tell us which washer we should be purchasing?
Thanks much. |
#88 |
Drives: Attitude
Read my post. The washer is for those NOT using OEM size springs (RCE Yellow, Hotchkis, Eibach, most any lowering spring). If you have a threaded body coilover, you need these.
#89 |
Drives: White FR-S
Right, I have coilovers. Just wondering what the washer is called so I can order a couple.
#90 | |
Drives: Attitude
I see you're in Canuckistan, not sure if your P/Ns are the same or not. |
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | whataboutbob (08-05-2013) |
#91 |
It is the same. a little pricey at 10 bucks each though.
#92 |
Drives: 2013 FRS Asphalt
After almost 300 miles and 8 runs on a autocross course sunday everything is still fine.
2013 Scion FR-S AT Picked up 5/30/2012
| The Following User Says Thank You to feldy For This Useful Post: | Calum (06-11-2013) |
#93 |
Drives: FRS
Sweet! Keep us posted.
#94 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
mine are fine. but the drivers side just makes all kinds of noises.
#95 |
Drives: FRS
Well then they are not fine... Are they?
Noise is an issue. They should not make any noise over stock IMO. |
| The Following User Says Thank You to wootwoot For This Useful Post: | Calum (06-14-2013) |
#96 |
Drives: Toyota 86
My warranty replacements are coming from Australia.
I wonder how can I manage to install them successfully at this time. |
#97 |
For the sake of collecting data, I had a set of the early model (non-Koyo bearings, no dust covers) last about 9k miles, and they just recently went kaput. Getting a new set under warranty.
#98 |
How long is the warranty on these?
| upgraded mounts? | 7thgear | Engine, Exhaust, Transmission | 19 | 01-12-2013 12:31 AM |
| Buyer Beware: Motor Mounts | cobrabyte | Engine, Exhaust, Transmission | 5 | 01-04-2013 09:14 PM |
| Autocross Camera Mounts? | fritzy | BRZ First-Gen (2012+) — General Topics | 7 | 08-03-2012 11:48 PM |
| SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports | Font Motorsports | Interior Parts (Incl. Lighting) | 2 | 07-03-2012 07:43 PM |
| Dash Mounts for gadgets | smbrm | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-28-2012 08:07 PM |
