Old 05-30-2014, 08:39 PM   #85
luv85
Drives: Grey GT
As I have stated, I dont recommend it because my way is just the work around it.. Too much effort for making window roll up on lock to work. =_=;
Basically I got window roll up kit from ebay, get the wire to passenger side.
Detect +ve from motor on both sides, etc all according to instructions.
Then whenever window rolls up, I used relay and rectifier diode to send +ve to ACC.
This step is necessary and is really important.
And added switch to toggle the function, so I can option to lock window with window open.
One more relay is used to control window-roll-up only works when the car is off.
Else window would roll up when lock button is pressed while driving.
I could only find cheap kits when I did this early last year. Maybe there are better kits available now.
luv85 is offline   Reply With Quote
Old 05-30-2014, 10:21 PM   #86
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
As complicated as that sounds, it's progress, which (hopefully) means there's a good chance this project is entirely possible.
Deathalo is offline   Reply With Quote
Old 06-02-2014, 08:11 AM   #87
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Yes progress! Any kind is good. I look forward to the day I can remotely roll the windows down before getting into the car to vent all the hot air out. Summers are brutal here in Texas, so please make this happen.
CarzCarzCarz is offline   Reply With Quote
Old 06-02-2014, 10:57 AM   #88
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Make it a plug and play you will have lots of customers
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-02-2014, 05:47 PM   #89
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
Couple questions:
1. Did you tap the up/down relay into the window switches on the driver's door?
2. What would be the effect if someone were to use an interior switch at the same time but in the opposite direction that the remote windows are going?
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
Old 06-02-2014, 11:23 PM   #90
Deathalo
He's not kidding, all the fellow 86ers that I know would be all over this.
Old 06-03-2014, 04:41 PM   #91
kiichiro
Originally Posted by scottmcphee View Post
Couple questions:
Scott we need you to make this
You ask the right questions know how to put diodes etc to make this safe for our car and safe for the masses
Why not get a field input of what folks would pay? Here in az you got my $200 or less for this product. Need testers lmk
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 06-03-2014, 04:51 PM   #92
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Id pay 200 for that aswell
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 06-03-2014, 06:15 PM   #93
Deathalo
Likewise
Old 06-04-2014, 08:54 AM   #94
kiichiro
Well there is your tester group and r&d costs!
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 06-04-2014, 03:25 PM   #95
scottmcphee
The AutoWindow Classic Universal Fit has all the inputs, logic, processing, and output controls needed for this to work. It lacks the output interface with car windows. In other cars, but not the twins, we use DEI530T module as the output interface to the car windows.
The DEI530T provides four things in the solution.
1. it supplies power to windows when the car is off
2. it has two input lines for window control, a line for up, a line for down
3. it manages conflict resolution of interior switch use while lines are being controlled
4. it has pinch protection / end of travel / stall protection
Sadly the DEI530T was determined to be not compatible with the twins window motor/controller combo.
If you're curious, most VW group cars have this interface built-into the car so no DEI530T add-on is needed. The car has two lines, one for up, one for down, that AutoWindow ties into directly. It manages power while off, it has pinch protection, and it resolves conflict of interior button use.
So, if you can find, build, or make a window interface that provides those 4 things that DEI530T performs, then AutoWindow is a drop in component for a remote control window solution. And all the features and options of AutoWindow, heat venting, rain sensor, night sensor, etc... would also all be available.
Pretty sure, it would be very hard to get this to be truly plug and play. There would be panels coming off and wire cuts or tapping going on.
Want to know the sad thing? All this capability is sitting at the fingertips of the on-board computer that is already in the car. And just a stretch guess, the software for doing remote window control might be sitting in there, but is simply not enabled. Probably the same or very similar software that is installed in all Toyota, Lexus, and this Subaru. On Lexus, the feature might be enabled. I don't have the tools to hack car controllers, but they're out there. Hacking the computer via OBD port, CANBUS is probably the best bet at plug and play.
Old 06-04-2014, 05:46 PM   #96
DC2R
Drives: 2014 Scion FR-S
I heard claims that some FRS models have the ability to control Windows via factory fob. Haven't gotten any proof though. Sat shown with Toyota tech and saw that the options in Techstream were greyed out.
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 08-04-2015, 05:59 PM   #97
philooo
Drives: 13' Scion FRS Track car
any news on this ? I would LOVE to HAVE key fob window up and down !!!
philooo is offline   Reply With Quote
Old 11-30-2015, 02:54 AM   #98
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Ordered and one day hoping this is a possibility.
Chad86 is offline   Reply With Quote
EcuTek Tuning advancements unleash unlimited possibilities Visconti Engine, Exhaust, Transmission 27 03-03-2013 03:27 PM
