Old 12-05-2012, 02:11 PM   #85
2forme
Originally Posted by Frostyman View Post
I have the AFE intake, which was making me run lean, and the perrin crank pulley. So my guess is overcompensation after the lean CEL that popped over the weekend.
Luckily, the issue doesn't show up until 3k+ rpms, so I can at least drive it home from work and get it fixed.
It sounds like they haven't adjusted the MAF interpretation for the AFE. I never ran lean with AFE on either an aftermarket tune or stock tune.
Old 12-05-2012, 02:13 PM   #86
Frostyman
Drives: 2013 Raven FRS
It's FA20Club, but you know how it goes with mail order tunes. Lots of back and forth to get it right.
Frostyman is offline   Reply With Quote
The Following 2 Users Say Thank You to Frostyman For This Useful Post:
2forme (12-05-2012), JoeBoxer (12-05-2012)
Old 12-05-2012, 02:34 PM   #87
2forme
Yup! Make sure you get a dyno after it's corrected.
Out of curiosity, what were the numbers?
Old 12-05-2012, 02:54 PM   #88
Frostyman
HP peak was 154.73 at 6400(worse than some people's stock pulls) torque peak was 141.35 at 4700. But since the AFR was below 10 (bottom of the graph) it was just acting like an old lady crossing the street.
I made a new thread so we can get off of this one.
http://www.ft86club.com/forums/showthread.php?t=23694
Old 12-07-2012, 01:04 AM   #89
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
Fuel gauge is definitely wonky. Thought I was running on fumes trying to get to an e85 station. Got stuck as a train was crossing 100 feet from the station. Waited 5 minutes thinking it was going to die. Looked down and I had half a tank. Topping off confirmed it.
Sent from my flux capacitor using Taptalk
Did anybodies fuel gauge start working right. Mine has been probably as low as it can go all day. It jumped to half a tank earlier today but then it started going back to empty quick.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 12-07-2012, 01:06 AM   #90
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Mine was buried under E then I topped off and only got 6 gallons so yeah it is definitely an issue. Going to go by the trip meter now.
JoeBoxer is offline   Reply With Quote
Old 12-07-2012, 01:37 AM   #91
Yruyur
Yruyur's Avatar
Does this tune have the racerom gauge stuff. Wasn't that what was causing this on the other tune?
Old 12-07-2012, 09:13 AM   #92
bgibbsunc
bgibbsunc's Avatar
Yea only thing driving me nuts.
San Antonio TX
Old 12-07-2012, 09:45 AM   #93
2forme
Disconnect your negative battery cable for 2 minutes to fix your fuel gauge.
Old 12-07-2012, 09:48 AM   #94
xjohnx
Grip>Slip
xjohnx's Avatar
does the radio retain your presets when you do this? (not sure if they're stored on the radio itself, or if it stores the config on the SD card)
Old 12-07-2012, 09:50 AM   #95
2forme
Unfortunately, no, it does not retain them. But you'll have a working fuel gauge!
Old 12-07-2012, 09:50 AM   #96
Frostyman
No, radio presets will go boom.
Old 12-07-2012, 09:53 AM   #97
JoeBoxer
JoeBoxer's Avatar
sweet i'll give it a try
Old 12-07-2012, 10:00 AM   #98
2forme
Let us know if it works for you. I know it works on Viscontis tunes.
APEX-i SMART Throttle Controller - preliminary test. Moto-P Engine, Exhaust, Transmission 33 05-24-2015 07:01 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 04:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
FA20CLUB.com E85 Goodness FA20Club.com Engine, Exhaust, Transmission 45 11-13-2012 01:05 PM
Tunehouse BRZ Tuning program preliminary details Hachiroku Engine, Exhaust, Transmission 42 06-25-2012 07:40 PM
