Old 10-24-2016, 03:21 PM   #85
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
Hi Andy, could you provide location and phone for the FA20club?
neilvosko is offline   Reply With Quote
Old 12-23-2016, 05:03 PM   #86
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Kab Customs is great. They're in Sunrise, FL, and did my clutch, flywheel, bearings, bushings, shift springs, and fluids in roughly an hour at a great price. I haven't driven it long, but they seemed to know what they're doing, and everything is spot on.
"Chasing speed with patience"
MurderousPandas is offline   Reply With Quote
Old 03-12-2017, 02:24 PM   #87
fourdegrees
Drives: None
Anyone have experience with Universal Motorsports in Warner Robins, GA?
fourdegrees is offline   Reply With Quote
Old 03-15-2017, 06:46 PM   #88
Scion_Swine
Drives: 2017 Subaru BRZ
so im guessing there is no shop in miami, kendall, or homestead?
Scion_Swine is offline   Reply With Quote
Old 03-16-2017, 11:28 AM   #89
MurderousPandas
Not for our cars. The closest shop for our cars down here is Kab Customs, but they do good work. They're in Broward. I used to live in Homestead, now Key Largo, but the drive is worth it. They swapped my clutch, flywheel, plate, bearings, bushings, shift springs, and fluid in roughly an hour. Including disassembly and reassembly.
Old 03-16-2017, 09:20 PM   #90
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
Shop Name: FA20Club
Phone: 888-657-1444
from previous poster
ShawnP19 is offline   Reply With Quote
Old 03-20-2017, 06:13 PM   #91
Scion_Swine
well im having a lot of the common problems on my FRS.
I need to change my coil pack and my throw out bearing or it could be the release fork and pivot ball. I havent had an expert look at it. so i figured id just change the whole clutch while i was replacing the bearing (if its the bearing). im sad that I have to do this at 44k miles already.
how much did they charge you for the clutch, parts and labor?
Old 03-20-2017, 08:51 PM   #92
MurderousPandas
Coil pack you can do yourself. It's a tight fit, but no where near as bad as the spark plugs, i had to do one of mine as well.
As for the clutch, it's probably the bearing, but it could be a dry fork. The parts i bought myself, i replaced everything with the Exedy OEM kit, MTec springs, Perrin and Whiteline bushings. My flywheel was good, but if you're dropping the tranny, might as well go for it, otherwise you'll have to pay for the same labor if you decide to change it later anyways. Labor was $350 in total, which is may sound like a lot for an hour, but they had 3 guys doing it as well, and an hour is damn quick. Really good guys, they specialize in FRS/BRZ/86 and S2000.
Old 04-08-2019, 02:54 PM   #93
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by Ignore Your Doctor View Post
Hey guys, I've seen a few posts asking for shops in metro Atlanta area. I can't say enough good things about AllPro. The owner is a former Classic SUbaru master mechanic and has done a full tune on my brother in laws 06 STi and all the work on my 15 BRZ. Much better prices than dealership.
Please provide the owner's name and address. I need brakes done on my daughters car
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-08-2019, 05:36 PM   #94
FenderBender
Drives: Imaginary so far
I've been seriously considering buying a '17 BRZ in Pensacola, FL. However, I live far out of state. Can anyone suggest a good shop/mechanic that would be willing to do a pre-purchase inspection on the car?
I've tried searching for "Pensacola" in this thread, but couldn't find anything. Thanks for any help!
FenderBender is offline   Reply With Quote
Old 08-31-2022, 04:12 PM   #95
Mhaley777
Drives: 2022 GR86 Neptune Base AT
Tint Pros in pensacola did my tint and my front end PPF. They were really easy to work with and fair on pricing. I am really happy with the result. Had one small issue with a PPF bubble that I had to cut. The sharp angles on the front are apparently tough to get right. You can't even tell I cut it unless you get super close and know where to look. Overall a great value. They got it done quickly and I have been happy.
Mhaley777 is offline   Reply With Quote
Old 08-31-2022, 04:13 PM   #96
Mhaley777
Looking for vinyl
So I'm in between Mobile and Pensacola down on the gulf coast. (Foley) and I would love to find a good vinyl installer that could wrap my roof for me. Does anyone know of one without having to drive for hours on end? Thank you
Old 12-13-2022, 02:34 PM   #97
e_lunatic
Drives: 2015 Scion FR-S
any recommendations for a maintenance shop in the greater Nashville area?
I used to do all the maintenance myself but i've already been yelled at by my apartment complex about working on my car.
Also in need of a good alignment shop.
e_lunatic is offline   Reply With Quote
alabama, arkansas, florida, georgia, kentucky, louisiana, mississippi, north carolina, south carolina, tennessee
Any good shops you recommended in SoCal? Tylub Southern California 3 12-10-2012 10:55 PM
new car club southeast texas- la chris's fr-s Southwest 0 12-03-2012 08:03 AM
Recommended body shops in Monmouth County NJ? GregV NY / NJ / CT / PA 4 11-11-2012 08:47 AM
New moderators in the Southeast Region Sportsguy83 Southeast 8 11-08-2012 04:34 PM
Southeast sound OFF! OldSkoolToys Southeast 133 05-25-2012 12:31 AM
