Old 09-06-2014, 07:06 PM   #85
arvidj
Drives: '93 MR2 Turbo
Originally Posted by F1point4 View Post
people have asked how I got the escort smart cord in here. Not perfect but it'll do. enjoy
20130614-ProjectCleanupElectricals-055 by VictorN07, on Flickr
20130614-ProjectCleanupElectricals-060 by VictorN07, on Flickr
Ok, I am to the point in the install where I mount the concealed display but have no clue about how to get the 'cubby hole' [sorry for the technical term, I don't know what Scion actually calls this thing] out.
Any suggestions would be appreciated.
Thanks,
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
Old 10-17-2014, 06:09 PM   #86
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
My hardwire setup just stopped working anyone have an idea? The fuse is still good but no power to my scanner anymore
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 12-08-2014, 07:48 PM   #87
VeryBRZOwl
Drives: 2013 Subaru BRZ
I hate for this to be my first post but....
I made my own invisicord/wire/dealio. I have a BRZ WITHOUT the auto dimming mirror. I tested the newly made cord on my dome light and it was successful..when i opened the door. This made me chuckle but now I am trying to tap into the cable for the auto dimming mirror. No luck with powering the radar. I tested to see if the there was a current. Nothing. I am not an electrically inclined so I know I might be overlooking something.
ADD Version:
BRZ without auto dimming mirror/homelink
Radar is Beltronics V10
Trying to get power though dome light
VeryBRZOwl is offline   Reply With Quote
Old 12-09-2014, 01:22 PM   #88
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
ADD Version:
I am not either so I went the easiest route and not cut anything. I got this cord.
[ame="http://www.amazon.com/gp/product/B006G1PHLY/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1"]Amazon.com : Long Power Cord for Beltronics / Escort / V1 Radar Detectors : Valentine One Cable : Car Electronics[/ame]
Ran the cord to the cigarette lighter in the glove compartment. This took all of 5 minutes. Its clean, easy, and no messing with wires hahaha
fantah is offline   Reply With Quote
Old 12-12-2014, 04:41 PM   #89
VeryBRZOwl
Thanks for the help, I tried about everything to get this circuit to work. Ill be ordering my long cable and moving on to my next project.
Old 12-23-2014, 12:04 AM   #90
afoust50
afoust50's Avatar
Drives: 2014 Scion FR-S
This was so easy I literally did it while waiting in line at the drive through for Chick-fil-A today.
afoust50 is offline   Reply With Quote
Old 03-19-2015, 01:51 PM   #91
oTaGGeDo
oTaGGeDo's Avatar
Drives: Currently driving a 2013 turbo Tc
Used this DIY last night to hardwire my escort passport 9500ix in worked great
oTaGGeDo is offline   Reply With Quote
Old 03-27-2015, 01:48 PM   #92
VeryBRZOwl
It's easy if you have that auto dimming mirror. If you have a stock mirror, upgrade or get the long cable on Amazon.
Old 03-27-2015, 02:34 PM   #93
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I'm pretty sure the connector for the powered mirror is there regardless of whether or not your mirror is actually powered. So even without the powered mirror you can still use this DIY.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 10-29-2015, 12:08 AM   #94
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
Originally Posted by mainstream View Post
Great guide, I used this with post from others to hardwire my Passport MAX radar detector
Just some clarification for those FR-S users that don't have the auto dimming mirror or even if you do, you can make the connections on the male (car side) and not the mirror side.
I bought my direct wire cable from ebay for $8.95 with inline fuse
http://www.ebay.com/itm/Escort-Radar...item2c7252d817
find the mirror connection cable to right once you remove the light housing
mine was taped down (I guess to prevent noise)
turn the now loose mirror cable so that the gray wire is on the left...
feed the red wire into the left slot where the gray wire is... feed the black wire from the direct wire cable into the middle slot of the mirror power where the black wire is.
When you feed the wires in depending on how you do this they should be snug so it may take a few attempts.
I secured it using a rubber band, you might want to use a small tie wrap or electrical tape. That way when you tug on the cord when moving your radar connector these connections won't come loose.
Result:
Just wired up an x50 with these instructions. worked perfect. thanks!
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 12-11-2015, 04:53 PM   #95
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
does this guide work if i dont have autodimming mirrors?
slyphen is offline   Reply With Quote
Old 12-11-2015, 05:24 PM   #96
xxatsayxx
Drives: 2015 WRB BRZ
Yes you should still have the plug in there.
xxatsayxx is offline   Reply With Quote
Old 12-30-2015, 08:59 PM   #97
Beechnut87
Drives: White 2015 Series Blue BRZ SC
ADD Version:
I am having the same problem with mine! I had originally wired it to the dome light and of course it worked with the 12V constant but when i try to wire it in through the rear view mirror i have nothing. It has no power going to it and im trying to figure out where the missing connection is. Is there a separate fuse for the Homelink Mirror? I want to keep from having to run wires all through the car and this would be great if i could figure it out!
Beechnut87 is offline   Reply With Quote
Old 01-05-2016, 02:20 PM   #98
2013GTRNate
2013GTRNate's Avatar
Originally Posted by speedracer38 View Post
This is pretty straightforward and fast thing to do.
**This was done on a BRZ with an auto dimming rear view mirror**
I am NOT responsible for any modification you do to your own car! I am just showing how I modified mine
First off you need to order a product called 'Invisicord' - http://www.invisicord.com/order.html (Check the installation page to see if your radar detector is supported). I ordered a 12" cable without fuse which I thought would be long enough but it barely was. I would highly recommend ordering at least a 16" cable.
Here is what it looks like (Picture credit - Invisicord)
1 - Start off by removing the dome light fixture
2 - Unplug cord running to dome light
3 - View of what stock wiring to auto dimming mirror looks like
4 - View of stock harness for auto dimming mirror above dome light (I already have the Invisicord wired in photos)
5 - This is the connector you are looking for (front view)
6 - Plugin the prongs from the Invisicord as pictured (RED wire bottom right, GREEN wire bottom center) Look how I am holding the piece so you don't do the inverse of my directions -
7 - Simply plug everything back in and tuck the harness the furthest away from the windshield and on the driver side -
8 - Reconnect the dome light wiring and put it back in position -
9 - DONE!!
If done properly your radar detector should now turn on when the vehicle is started and power down when you turn your car off. Best of luck!
Thank you! I followed these directions and it worked perfectly. Took me 1-2 minutes and I was done. My installation is superbly clean now and i coupled it with this mount. [ame="http://www.amazon.com/PerformancePackage-Mirror-Mount-Detector-Bracket/dp/B0063N7UGA"]Amazon.com : PerformancePackage Mirror Mount Radar Detector Bracket - V1 Radar Detector : Valentine One : Car Electronics[/ame]
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
diy, radar detector, speedracer38
Direct wire radar detector Kieranz Electronics | Audio | NAV | Infotainment 25 11-02-2015 12:01 AM
Mounting a radar detector Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 24 02-06-2014 12:39 PM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 01:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
Mounting radar detector video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 10 06-07-2012 11:29 AM
