Old 03-27-2012, 08:22 AM   #85
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by old greg View Post
This is a function of spring rates, not damper rates.
yes correct,
but the dampers are there to control that oscillation
so while you can solve the initial problem of 4 corner balance by simply installing the correct spring, in the real world most people just buy off-the-shelf units which are tuned for some median chassis/wheel weight and not your specific case.
in effect, you can use a damper's adjustability to compensate for that incorrect spring rate to some degree in addition to overall tuning.
Old 03-27-2012, 12:51 PM   #86
trackmagic
Drives: 1994 BMW 318i
Old Greg, Oregon State. You?
trackmagic is offline   Reply With Quote
Old 03-27-2012, 02:11 PM   #87
old greg
Rocket Surgeon
Drives: PSM GGA OMG
USF. If you're with GFR, you may remember me as the shitfaced guy in the "I Like Turbos" shirt at the California party last year.
old greg is offline   Reply With Quote
Old 03-30-2012, 01:19 AM   #88
trackmagic
I was with GFR, but I graduated in 2005. That would have been before my time. Sounds like a good story though
Old 05-01-2012, 08:16 PM   #89
Dimman
Kuruma Otaku
Dimman's Avatar
Bump for more questions...
Regarding the wheel rate/frequency calculations, I've been using the assumption that the front MacStrut has a 1:1 ratio.
But looking back at the MotoIQ suspension sticky and article, the amount that the strut is offset and a comment Mr Kojima makes about it.
Pic:
And he says:
Another interesting point is that the front strut is mounted unusually inboard so the front suspension motion ratio is pretty high. This means that a pretty stiff front spring will be needed.
So I came up with this...
If this is correct, this would make the motion ratio/leverage appear to be closer to the rear multi-link...
Thoughts? Corrections?
Because titanium.
Old 05-01-2012, 08:45 PM   #90
fatoni
Pic:
And he says:
im not certain but i dont think that changes the motion ratio at all but that depends on if you are adding length to ac and ab or just ac
Old 05-01-2012, 08:49 PM   #91
Dimman
Kuruma Otaku
Dimman's Avatar
It was what he said about the motion ratio that got me thinking, everywhere else seems to treat MacStruts as just 1:1
Because titanium.
Old 05-01-2012, 08:55 PM   #92
fatoni
i dont have the deepest knowledge of suspensions but im pretty sure you still would even with an inboard strut like you posted.
Old 05-01-2012, 11:25 PM   #93
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Distance inboard doesn't affect motion ratio in strut suspensions (well, it does affect motion ratio progression a little). Only the angle of the line of action of the spring/damper matters.
Old 05-01-2012, 11:31 PM   #94
Dimman
Kuruma Otaku
Dimman's Avatar
The mounting angle affects the fitted rate and changes a little as they cycle, correct? So inboard/outboard can have an effect on how the angle changes, only (which isn't huge)?
So what the hell is Kojima talking about?
Because titanium.
Old 05-01-2012, 11:47 PM   #95
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Yep. Moving the upper mounts inboard will create a progressive motion ratio, but we're talking an order or two of magnitude below the static MR.
Maybe he's just fallen prey to a misconception.
Old 05-01-2012, 11:54 PM   #96
Dimman
Kuruma Otaku
Dimman's Avatar
Thanks.
So if I came up with Front 1.5Hz and Rear 1.35Hz (RCE says 185 lbs/in f&r) would I be in the right ball park?
Because titanium.
Old 05-02-2012, 12:18 AM   #97
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
He's confused. Mac Struts' motion ratio is almost always about 1:1. The only thing that changes it is their angle vs. vertical. This is why in practice most Mac Struts motion ratio is about 0.98:1 or there about.
Sounds like you're in the ball park. Do you have the exact motion ratio of the rear suspension [of the Impreza]? It seems Toyobaru may be slightly overdamping the rear end to account for the otherwise under-sprung rear suspension.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 05-02-2012, 12:20 AM   #98
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Seems reasonable.
D-4S Thread WingsofWar Engine, Exhaust, Transmission 85 03-31-2020 04:25 PM
AZ bs thread sfwg Southwest 185 09-11-2012 03:11 AM
Intoxicated thread #87 Off-Topic Lounge [WARNING: NO POLITICS] 46 04-27-2012 07:17 PM
The Diet Thread Maxim Scion FR-S / Toyota 86 GT86 General Forum 126 06-14-2011 05:47 AM
The Music Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 13 03-28-2011 11:35 AM
