Old 07-08-2014, 02:17 AM   #85
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Anybody got pics with LED side markers, head lights and Day time running lights?
Carlitoz3 is offline   Reply With Quote
Old 07-08-2014, 03:03 AM   #86
cywinr
Drives: DGM BRZ MT
To everyone who is having a hard time snapping the sidemarker back into place, there is a thread here. Maybe the OP can put it on the first post?
I got a pair of vice grips and a small cloth to squeeze them together.
Put a small cloth between one jaw of your vice grip and the sidemarker so you don't scratch it. Make sure the jaw is flat against the sidemarker so when you squeeze the pressure is spread out. If you put too much pressure using only the tip of the jaw then the side marker can crack.
The other jaw of your vice grip should be on the metal tab. Squeeze the two together until you hear a loud click.
cywinr is offline   Reply With Quote
The Following User Says Thank You to cywinr For This Useful Post:
chanomatik (07-08-2014)
Old 08-06-2014, 11:34 PM   #87
frsgal
frsgal's Avatar
Drives: 2014 FRS, Ultramarine Blue!
@F1point4 thank you very much for this guide and pics! I was able to do this in about 15 minutes with the help of my roommate. (I pushed in on the clip while he pulled on the sidemarker, hehe.)
frsgal is offline   Reply With Quote
Old 02-08-2015, 09:55 PM   #88
MaxRED13
Novice Autocrosser
MaxRED13's Avatar
Drives: Scion FR-S Red//MT
thanks worked great. Good alternative to the other one. Very detailed pics appreciated.
MaxRED13 is offline   Reply With Quote
Old 05-04-2015, 05:19 PM   #89
calidus
Drives: 2013 SWP BRZ Premium
I am not sure if I have these snapped into all the way.
calidus is offline   Reply With Quote
Old 05-04-2015, 05:24 PM   #90
lxsedan
Drives: 2013 BRZ SWP
When mine went all the way in the foam should no longer be visible. That doesn't look to be in. Rather then slowly starting to push it in I had it all lined up and kinda banged on it with my fist for a quick impact and mine snapped right in.
lxsedan is offline   Reply With Quote
Old 05-15-2015, 09:57 AM   #91
DarkSunrise
DarkSunrise's Avatar
Originally Posted by b rawr z View Post
The drivers side was annoying to pop out and back in.
Tip: for people having difficulty popping it back in. Get a tiny flat head and try to push the clip towards u by inserting the flat head from under.
This worked for me, except I wedged a tiny screwdriver into the clip from the bottom (once it was through the bracket on the bumper) and shoved it towards the engine.
Quick pic for reference (not my pic):
As others have said, you'll feel it click into place. Nothing else I tried work, including brute force, quick rabbit punches, roundhouse kicks, etc.
2022 BRZ Build
2013 FR-S Build
Old 07-23-2015, 04:03 PM   #92
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
geez - i'd hate to be a prude. But where do y'all buy the clear side markers at?
which vendor is valid and preferred? I live in Alaska.
mixedjuice is offline   Reply With Quote
Old 07-24-2015, 12:12 AM   #93
DarkSunrise
If you want a genuine OEM part (perfect fit, no leaks), I used this vendor and was happy.
http://www.ft86club.com/forums/showthread.php?t=57650
2022 BRZ Build
2013 FR-S Build
Old 08-18-2015, 09:11 PM   #94
swftbrz
Drives: Dark Gray BRZ Premium
Really quite frustrating. The A-clip is a huge problem. It was loose on driver's side and stayed in when the side marker released. Then after 30 minutes trying to get the Helix side markers flush I learned they may not have the correct gap from the manufacturer!
My passenger side came out easily and went in flawlessly. I still have to redo my driver's side as it the A-clip is broken.
swftbrz is offline   Reply With Quote
Old 04-07-2016, 12:05 AM   #95
Wired86
Wired86's Avatar
Drives: 2016 Subaru BRZ, Limited, MT, CBS
Just did mine with the helix dark smoke side markers and amber LED's underneath. It was pretty easy thanks to this guide. Honestly though, after doing my driver side with the wheel turned the way it is in the picture (and hardly being able to get an angle to see what I was looking at) I tried it on the passenger side without adjusting and it was so much easier. So, in other words, turn the wheel the other way and you can get a better line of sight with your head further back by the rear side of the wheel. So turn the wheel in when taking the phillips clips/scew things out, and then turn the wheel the other way to pry the marker off. Worked like a charm.
Also instead of using a philips screw driver, use a philips bit. You need almost no pressure so it is easier to just use a tiny little bit in your fingers when twisting the liner screw clips off.
Originally Posted by softgrip View Post
Last night I took a corner that would have given me a 4 wheel power slide in the WRX. The BRZ hunkered down and massacred the corner with no loss of traction or speed.
Wired86 is offline   Reply With Quote
Old 11-23-2021, 07:20 PM   #96
ymshulman
Drives: '17 BRZ
Wondering if this is a good place to ask, since you’ve looked at this so carefully…
I lost my stock passenger side marker (amber lens, 2017 BRZ) when someone left me a nice scratch and a loose side marker as a present, and it was not as secure as I thought. Must have popped loose on the next drive.
Does that mean I need to order clips as well as a side marker? And does anyone who has replaced their side marker have a stock one they’d be willing to send me?
ymshulman is offline   Reply With Quote
Old 11-24-2021, 10:10 AM   #97
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Typically side markers will come with them. Otherwise you can order them separate. https://86speed.com/sidemarker-clips-pair
BigTuna is offline   Reply With Quote
clear side marker, diy, jdm
DIY side marker blinkers boonFRS DIY (Do-It-Yourself) Guides 112 06-08-2020 02:45 AM
clear side marker part number NOBROWS Cosmetic Modification (Interior/Exterior/Lighting) 34 09-11-2017 10:12 PM
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 11:24 AM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 07:07 PM
Raven blacked out side marker before and after Roadstercycle FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 11:52 PM
