Old 06-28-2021, 01:49 PM   #85
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by irax View Post
Fair enough.
What retainer kit did you get ?
I got the Denstoj kit.
https://denstoj.com.au/collections/f...r-retainer-kit
Old 06-28-2021, 04:09 PM   #86
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
FB25 short block $500
Having your FA heads and timing cover cleaned and prepped $800ish
FA20 OE forged crank $400
FA20 aftermarket con rods $300-600
FB25/FA24/FA20 custom sized pistons $600+
ARP head studs $250
FB25/FA24 HG $100~
So you really are only at like $3500 or so in extras before the normal cost of a rebuild which can be like $3500 or so.
So like $7k
Can you do a full K swap for $7k And have boost ready internals?
You forget to mention you're still left with an extremely flawed engine that has massive oiling issues which will become especially apparent at high power levels. K's are popular for a reason, and the couple downfalls are solved with extremely simple and cheap remedies (type S oil pump, oil pan baffling).
This is all assuming the FB25 will work. If you're forced to run the FA20 block those prices increase a ton.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 07-06-2021, 10:55 AM   #87
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Me to! I just ordered it on Sunday
irax is offline   Reply With Quote
The Following User Says Thank You to irax For This Useful Post:
NoHaveMSG (07-06-2021)
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
