Old 06-15-2011, 04:53 AM   #85
Giccin
Giccin's Avatar
Originally Posted by Clode View Post
Toyota says they have taken the cayman as a reference point
I don't see how "Best Car" magazine says Toyota has taken the Cayman as a reference point but, it does sound damn interesting.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 06-15-2011, 07:58 AM   #86
AaronCompNetSys
AaronCompNetSys's Avatar
Drives: 01' S2000; 05' WRX
Originally Posted by WingsofWar View Post
On a side note, I wonder if Subaru, being somewhat new to RWD will adopt a form of active rear steering.
That is called traction control off easy button, and a torsen diff. Duh.
AaronCompNetSys is offline   Reply With Quote
Old 06-15-2011, 12:11 PM   #87
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
The Cayman was always on top of my best handling best setup best Sports Car I can Buy list. It's nice to see that it's being benched Mark against the Cayman(um I don't think it's confirmed but that white cayman always around is a good indication) sigh6 months till we get a really clear picture, and I hope it's not fully like that magazine page with the camo removed the face look so "Herp Derp!" to me ;/
Old 06-15-2011, 01:01 PM   #88
bigbcraig
Drives: 2013 BRZ / 2015 WRX
Iv encountered that same thing too with Subaru suspensions. I suppose it has to do working with AWD.
I hope not. Subaru's current rear multilink suspension is great, with the exception of being miscalibrated for height (LOTS of droop available and not much bump, good for raised rally cars but not so good if you want to lower)
Subaru likes to mess around with diffs... I seriously doubt the normal version would have something fancy though. WRXs are still all dumb diffs, when they have them at all (08's and forward doesn't have a rear LSD just center).
For the STI, a variable-lock and/or active torque vectoring in the diff would be badass.
bigbcraig:
When you are talking about the Subarus losing camber in corners, is that because of the big squishy rubber top mounts of the struts? Would proper bearings fix this?
(My Legacy's only a daily, but I'm accumulating some WRX/STI bits that may or may not fit. So far I've got some GD WRX struts and springs, and some STi front aluminum LCAs with the 'good' mounts/ALK part, whatever that meant...)
Perhaps stiffer upper mounts would help a little, but they should really just add precision and crispness. If they are loose /soft enough from age that you can wiggle the tops around then that would cause unpredictable camber change at load.
The loss of camber is almost exclusively in the Strut-type suspension: And I'l tryo to explain without pics because the internet in China is awful slow.
With a double-wishbone suspension, the hub is held in place with two sets of articulating arms. When you compress a bump, both of these move in arcs which means that overall, the alignment of the hub remains close to what it was. I hope that makes sense.
Struts only use a bottom articulating arm, that is stiffly connected to a 'strut', a heavy duty spring/shock combo that goes up to the top of the tower you're familiar with. On most struts and specifically subarus, the hub is hard-bolted to the strut and the strut aligns it. For instance, a camber plate that would replace your rubber mount will have adjustability to bring the top of the strut in towards the engine, so the struts and therefore the hubs are leaning in more... voila, negative camber.
When the strut compresses, the control arm ("wishbone) moves in an arc. Because we're in a relatively low passenger car, the arm is very nearly horizontal normally. In a bump, then, the outer point of the arm where the hub is mounted moves up and IN.
So, we have the strut compressing and straightening, as the bottom moves inward towards the vertical plane of the shock towers. This is where camber is lost.
The possible solutions are to raise your car or the control arm mounting points so the arms are below horizontal normally and actually move out a bit, adding camber under bump. But this is hard to do and people don't like the look of a raised car.
The other option is to increase (positive) caster. This makes it that when you turn the tire, it will actually also tilt inwards to the turn. This means that when you're turning and really need camber, the outside tire gains negative camber which is good. Too much can be goody but on a Subaru at least, you'll never really be able to get too much.
I'm not really familiar with what the ALK does in the older-style suspension (Legacy and 08+ Impreza ALKs are different), their main purpose is to change the tilt of the control arm around the axis of the axle (If that makes sense to you, I'll be suprised. Wish I had the time to make visual aids). This changes behavior under braking and acceleration that is complex but makes for the car to drive better in many ways. The new ones allow caster adjustment, and I think the old ones add some caster too. I'd have to look it up.
If you head over to motoiq.com, there's timely article about it that should still be on their front page as part of a 'ultimate handling guide' or something like that.
If you used to read SCC, a lot of the staff and friends are there writing the good technical / nerdy articles I used to love SCC for.
bigbcraig is offline   Reply With Quote
Old 06-15-2011, 01:42 PM   #89
Random_Art
professional smartass
Random_Art's Avatar
Drives: 16 speed mountain bike...
I miss Sport Compact Car mag. Of all the import tuning magazines they seemed like the only ones that were focused more on performance than on appearance of both the automotive and female model kind.
Goodbye Celica, you served me well.
http://artsofrandomness.blogspot.com/
Random_Art is offline   Reply With Quote
Old 06-15-2011, 03:34 PM   #90
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by bigbcraig View Post
original gold? sorry
Otherwise, I agree, things like upgraded suspension and audio are best done by the aftermarket... But if there was a way to get a high quality shock that was actually an aftermarket model and not a "made-by" then I'd jump on it. In the aftermarket, I'd be looking at something like KW at the very least, in terms of quality. Even if it means I can only afford to do KWs, tires on the stick rims, and basic brake upgrades with homemade ducting, and stripped interior.
At Atlanta Region SCCA Solo, theres a guy with an E36 (don't remember if its an M or not) that's really fast. His Motons are supposedly about 2/3 the money put into the car.
Sorry, I was referring to Ohlins Suspension. I haven't seen the top of the line Moton 4 way c/o'ers have 16 clicks for rebound and comp and I believe are piston and shim type shocks.
Ohlins TTX which has 40 low speed and 50 clicks for high speed for both rebound and comp and is $$$ just like the Moton. The problem is that they don't have too many applications for autos.
http://www.ohlinsusa.com/us/
Old 06-15-2011, 04:08 PM   #91
Levi
Drives: Toyota
Ohlins are my favorite, I hope they'll be available for the FT-86.
Levi is offline   Reply With Quote
Old 06-15-2011, 05:58 PM   #92
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
ohlins!!! that's baller..
i thought toyota using the cayman as a benchmark was old news? best car's prob getting their info from this site..
cyde01 is offline   Reply With Quote
Old 06-15-2011, 06:45 PM   #93
RRnold
2 wheel member
RRnold's Avatar
They all start ramping up once you get into 4 way adjustible, remote reservoir, high and low speed compression and rebound etc; 10K+ easily!
Take the STI for example when comparing their entry level suspension.
Moton Clubman are about $4700 (7 clicks each for rebound and compression)
Ohlins Road & Track are about $3500 (12 clicks for rebound and compression)
I'm a bit partial to Ohlins since I've used them in my bikes; PR and TTX rear shocks and 25mm cartridges in the forks for my motorcycles. The craftsmanship, the quality, the suspension feedback and the service is hands down the best!
Old 06-15-2011, 08:40 PM   #94
Allch Chcar
Drives: N/A
...The possible solutions are to raise your car or the control arm mounting points so the arms are below horizontal normally and actually move out a bit, adding camber under bump. But this is hard to do and people don't like the look of a raised car...
PRE-RUNNER!!!!
There, I said it first .
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 06-15-2011, 10:17 PM   #95
bls
Drives: 1999 toyota celcia
when will it be in usa???? anyone have an idea on price thanks
bls is offline   Reply With Quote
Old 06-16-2011, 12:14 PM   #96
Riff Raff
Drives: Mitsubishi Eclipse
Hi,
I follow the FT-86 Blog since beginning and now I've registered here to tell you what.
German Licenseplates have a simple structure.
Normaly its white with black letters (xxx xx nnnn) the first 1-3 letters stand for the Location (Zulassungsbezirk) the next 1-2 letters including the 1-4 numbers can be chosen by the driver and are in that combination unique.
The Licenceplates in the Video are white with red letters wich are special plates for Car-Dealers or something like that. With that plates you can drive a car for testing reasons and so on without having an insurance for the specific car. The structure is similar to the normal licenseplates, xx 0nnnnn, the two letters are also for the Location the first to numbers can be 03, 04, 06, 07 followed by a random number.
Why I tell you that?
The licenceplates (called redplates) of the testing car have to belong to a Car-Dealer (number starts with 06 what stands for Car-Dealers) near Mainz (MZ), I live in Mainz and I just know one new huge Toyota-Dealer and just one small Subaru-Dealer here. I think I'm going to visit them, maybe I find something out. ^^
Riff Raff is offline   Reply With Quote
Old 06-16-2011, 02:45 PM   #97
Random_Art
Random_Art's Avatar
Originally Posted by Riff Raff View Post
Hi,
Good luck! though, it would be odd for a dealer to be testing the car instead of the manufacturers.
Old 06-16-2011, 06:58 PM   #98
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
This is going to get interesting.
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
First Video of Scion FR-S / Toyota FT-86 / Subaru BRZ Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 11-15-2011 10:21 PM
FR-S/FT-86/Subaru Coupe Video of interior close up + in depth sound DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 36 06-21-2011 03:33 AM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 11:27 PM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 10:22 AM
First video of Subaru 086a test vehicle from the Nurburgring + interior spy pic Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 22 11-21-2009 04:20 AM
