Old 12-20-2013, 12:42 PM   #85
dkx64
Drives: 2014 Frs
Well when I bought the wheels from Aspec it said they fit the frs and brz. I have been basing my fitment from this guys build. So I know the wheels will fit just fine with 1 inch drop.
http://www.ft86club.com/forums/showthread.php?t=16385
The same guy has another thread here.
http://www.ft86club.com/forums/showthread.php?t=14232
I'm just hoping everything clears with the stock suspension left alone as I don't want to worry about suspension for another couple months as funds are always a little tight around the holidays. I will either do eibach pro springs in the next couple months or wait a little longer and get some decent coil overs. Not sure which one though as I can't lower more than an inch here in California without scraping all over the place. It damn sure looks good though.
Do you know what offset the wheels are on the blue brz? Are those volks?
dkx64 is offline   Reply With Quote
Old 12-20-2013, 12:47 PM   #86
dkx64
Drives: 2014 Frs
I got the same exact wheels as nofear99. +45 offset. He runs 235/35/18 but those are a really difficult size to find and I'm not buying pirellis. Worst tires that anyone in the family has ever owned.
My question is whether the 245/35/18 would fit. It can't be too much more than 1/8th added to either side of the tire. Can't seeing that being too big of a problem. But then again. I won't be lowering for a couple months. If I need to get springs right away I will. I can't afford coils right away though. And buying springs will just prolong me getting coils, if I even decide to go that route.
Old 12-20-2013, 01:14 PM   #87
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
The Bronze ones are Rota Grids.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 12-21-2013, 02:46 PM   #88
dkx64
Drives: 2014 Frs
Do you know what offset?
I threw on a wheel and everything checks out. Ordered some tires from Americas tire. They said if it's the wrong size I can exchange no problem. So I went with bridgestone re760 245/35/18 and now we wait. They should be ready to put on, Tuesday. I'll check fitment and go from there.
Old 12-21-2013, 08:09 PM   #89
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
44
φφκα
Old 12-23-2013, 11:13 AM   #90
dkx64
Drives: 2014 Frs
Awesome. Thank you!
Old 12-25-2013, 09:33 AM   #91
4bstr4ct
Drives: Toyota 86
Any update on this? Did it fit? No rubbing issues?
4bstr4ct is offline   Reply With Quote
Wheel Directory: XXR 521 18x8.5 +35 Iddoit2er Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-05-2016 11:53 PM
Wheel Directory: Varrstoen ES1 18 x 9.5 +34 MenoSkyz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 07-07-2015 04:47 PM
Wheel Directory: BBS CH 18x8.5 +30 Spaceywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-02-2015 01:05 PM
Wheel Directory: BBS LM 18x8.0 +50 stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-08-2013 07:55 PM
Wheel Directory: BBS RE 18x8.0 +50 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-25-2013 08:49 PM
