Old 03-12-2019, 04:37 PM   #85
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
Originally Posted by ka-t_240 View Post
You have to go to the dealer that sells the brand. Can't take a Scion to Subaru or Subaru to Scion etc.
I posted on a crosstrek page on FB, nobody even replied about this recall besides a dude I know that is a Subaru tech basically saying the issue is tech inflicted. His dealer is doing 2-4 of these a week across the subaru brand, no issues
Thanks for responding dude!
This has me freaked out now, especially since they haven't contacted me at all. I really hope I can get mine repaired or maybe, mine just won't be as conflicted.
sofrsnsokleen is offline   Reply With Quote
Old 03-13-2019, 07:38 AM   #86
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
no reason to get it repaired now. Wait a few months. The only problems they have reported it causing is some stalling. I don't remember seeing it cause anything major. And reportedly if anything happens it is in the first 5000 miles or so.
The Following User Says Thank You to why? For This Useful Post:
Teseo (03-13-2019)
Old 03-13-2019, 07:57 AM   #87
It stalls because a spring breaks and the engine is probably toast.
As you said though the reported spring failures are rare and early.
At the rate things are headed there will be more reported failures after the fix than there were prior to it.
I have looked but can find no reference to post "repair" failures in the other 375,000 cars affected that have different engines but used the same springs. Would appear at this point the failures are restricted to the FA20.
If not in California where the repair is being forced then I would either wait or not bother at all.
nikitopo (03-13-2019), Teseo (03-13-2019), why? (03-13-2019)
Old 03-13-2019, 08:34 AM   #88
gravitylover
I was wondering about Crosstreks and Imprezas and how they are doing through this and what failure rates they're seeing. The FB engine isn't much different at all.
Old 03-13-2019, 09:29 AM   #89
Ragin Gti
Drives: '15 Subaru BRZ
There is no engine disassembly on the non-twin engines. Remove the engine, remove the valve covers. They made special tools to remove the springs without any further disassembly. The tools won’t work on the twins due to the differences in the engines.
Ragin Gti is offline   Reply With Quote
The Following 2 Users Say Thank You to Ragin Gti For This Useful Post:
ermax (03-13-2019), Gunman (03-13-2019)
Old 03-13-2019, 09:37 AM   #90
ka-t_240
Yes, but do we really feel that the spring work/head disassembly is the root cause of most of these failures, or is it workman ship on cleaning the sealant and reapply the sealant. If the engines were having failures related to the heads/cams vs spun bearings I would for sure be thinking this was a bit more suspicious.
ka-t_240 is offline   Reply With Quote
Old 03-13-2019, 09:52 AM   #91
It is without a doubt the sealant issue. There were engines spinning bearings due to sealant straight from the factory so even a slight misapplication of sealant can cause an issue. The oil channels and ports on the FA 20 are very, very close to where the sealant is applied and it only takes one small piece to get into them to toast a bearing.
Dadhawk (03-13-2019), nikitopo (03-13-2019), Teseo (03-13-2019), why? (03-13-2019)
Old 03-13-2019, 10:02 AM   #92
ermax
ermax's Avatar
The FB engine gets pulled then only the valve covers are removed. A tool is installed that goes over the top of the cams and under the rockers and compresses the springs. Once the springs are compressed the rockers are pulled out. Using this method avoids the need to remove the cam caps and cams. So the only packing they have to mess with is in a few spots on the rubber valve cover gasket. So there is WAY less to mess up on the non-Twin recall. It's a shame this method couldn't be used on the FA but the springs are buried under the cams leaving no easy way to get a compressor on them.
The Following 4 Users Say Thank You to ermax For This Useful Post:
Gunman (03-13-2019), ka-t_240 (03-13-2019), Tcoat (03-13-2019), why? (03-13-2019)
Old 03-13-2019, 10:45 AM   #93
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Not doing it, didn't show up to my scheduled servicing.
I don't know how you guys who had their FRZ/BRZ broken by your dealers aren't losing your shit right now.. i guess you're made of money
RickyRacer is offline   Reply With Quote
Old 03-13-2019, 10:47 AM   #94
They are losing their shit. They should be losing their shit. They will continue to lose their shit until Toyota/Subaru do right by them.
Dadhawk (03-13-2019), DarkPira7e (03-13-2019), MuseChaser (03-13-2019), why? (03-13-2019)
Old 03-13-2019, 01:17 PM   #95
msaikhan
Drives: frs
Yes, everyone is losing their shit and calling toyota dealer and corp day and night, including me.
msaikhan is offline   Reply With Quote
The Following 2 Users Say Thank You to msaikhan For This Useful Post:
Dadhawk (03-13-2019), Tcoat (03-13-2019)
Old 03-13-2019, 01:19 PM   #96
Yea, if I was a victim (or somehow become one) much shit would be lost.
qcbaker (03-13-2019), Tcoat (03-13-2019)
Old 03-13-2019, 01:54 PM   #97
Well thanks to tanner we have info that includes more than just what is on this forum. As I see it the situations is not quite as dire as the picture here appears.
Dealer accept responsibility and fix - 10
Dealer says no way - 2 (both modified)
Under investigation/ have not heard yet - 15
We still have no clue how many were done with no issues (or where issues have not shown up yet).
Old 03-13-2019, 01:57 PM   #98
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Don't forget the people with successes and failures who aren't even aware of this forum's existence, and thus likely also unaware that this is even a topic outside their own individual vehicle.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
dkdnt232 (03-13-2019)
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 06:21 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 12:10 AM
engine valve spring recall done but giant oil leak msaikhan Issues | Warranty | Recalls / TSB 1 02-24-2019 06:18 PM
valve spring recall-engine oil leak TYinhouse Issues | Warranty | Recalls / TSB 13 01-17-2019 11:09 AM
My engine blew up four years ago, now they recall the valve springs Obsidiank Issues | Warranty | Recalls / TSB 12 01-02-2019 01:47 PM
