09-03-2013, 10:39 AM | #85 |
Drives: 13' Subaru BRZ Limited SWP 6MT
FYI, the BRZ comes with a lighter crank pulley than the FRS (1lb), so IMO BRZ owners are better spending money elsewhere.
FRS owners will see a slight performance improvement for the $. |
09-03-2013, 10:50 AM | #86 | |
Add lightness!
Drives: 17' WRX
I really recommend anyone doing their flywheel and clutch to get it balanced as a unit so it doesn't vibrate under load at speed. All things considered, I really couldn't careless about chatter at idle. |
The Following User Says Thank You to industrial For This Useful Post: | 37 (09-03-2013) |
09-03-2013, 01:14 PM | #87 | ||
degrees
Drives: 6MT BRZ
If this is your car then I can hear what sounds like gearbox rattle.
[ame="http://www.youtube.com/watch?v=__fWrW7_mDU"]AE86 3sge Beams @ Ruapuna Christchurch NZ 21/12/12 - YouTube[/ame] Quote:
Viscous engagement? Not sure I follow. This article explains why a lightweight, single-mass fly can rattle. The TRD uses a single-mass design so it'll be interesting to see if your results are any different. http://www.uucmotorwerks.com/flywheel/gear_rattle.htm Quote:
The rattle doesn't bother me, either. It sounds like a proper gearbox. . Last edited by 37; 09-03-2013 at 02:23 PM. Reason: Added video, moved some thoughts around |
09-03-2013, 01:54 PM | #88 |
slide to unlock
Drives: 2013 FR-S Raven Black
wow really? care to post the info on where you learned this? i thought both engines are the same?!
09-03-2013, 03:58 PM | #89 | |
Drives: AE86, 2x GT86, TE27
Agree on your comment on getting the unit balanced as a whole. To be clear, wasn't dogging the act unit. Have not used or looked into whether they're good/bad. |
09-03-2013, 04:01 PM | #90 | |
I thought the noise you can hear was the exhaust resonating/vibrating at a certain rev point. You could be right though. I'll definitely review the trd unit once its arrived. |
09-03-2013, 04:49 PM | #91 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
So I love my ProLite flywheel. There's a lot of gear rattle, but I'll put up with it. The engine revs a lot faster, rev-matching/double-clutching is easier. It's funny because while my downshifts have become smoother due to better throttle blips, my upshifting took some time to adjust because of thefaster fall-off. And it's not that much easier to stall either. Seriously, this is how the car should have come from the factory. Aside from the noise, there's no reason not to go with the ProLite. I wouldn't even bother with the StreetLite.
The CF driveshaft is butter smooth as well. My mechanic managed to nail the proper clocking first try. No humming or vibrations. |
09-03-2013, 05:02 PM | #92 | |
http://ft86speedfactory.com/perrin-b...black-124.html "The PERRIN Performance Crank Pulley is 4-pounds lighter (5-pounds for Scions!) than the stock crank pulley. Last edited by mwjcyber; 09-06-2013 at 09:11 PM. |
09-03-2013, 10:34 PM | #93 | |
Seņor Member
1974 TA22 Celica
2013 86 GT |
09-04-2013, 04:08 AM | #94 |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
no issues here....
i just have the light weight water pump pulley and alt pulley... crank pulley isnt on yet i had trouble gettin it to break loose.... any advice on how to get it off? |
09-04-2013, 08:08 AM | #95 | |
Drives: Hot Lava FR-S
There is a good DIY write up here some where. |
The Following User Says Thank You to Hiding For This Useful Post: | NYCsubaruBRZ (09-04-2013) |
09-04-2013, 10:54 AM | #96 |
Drives: FRS
09-04-2013, 07:57 PM | #97 |
09-04-2013, 08:15 PM | #98 |
prices on a light weight flywheel?
what did you pay for yours shipped to your door? brand? model? thanks 4 the help |
Similar Threads | ||||
Aftermarket Crank Pulley Install | Enigmus | DIY (Do-It-Yourself) Guides | 305 | 02-04-2019 11:37 PM |
Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 06:45 PM |
Agency Power Crank Pulley / Clutch Masters Flywheel | vividracing | Engine, Exhaust, Transmission | 67 | 11-07-2012 02:35 PM |
Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 03:47 PM |
