Old 12-05-2018, 08:27 AM   #85
Lantanafrs2
Drives: 2013 frs red
So out of the box, the itbs didn't give overwhelming results?
Old 12-05-2018, 09:12 AM   #86
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Without tuning, out of the box. No
Dr. BRZ is offline   Reply With Quote
Old 12-05-2018, 10:16 AM   #87
StraightOuttaCanadaEh
Wes
I think it's been long enough since the last time I posted this but if you want to see ITBs with individual trumpets and a MoTec to manage them, look at @zerobreau on instagram. He's had pretty good gains and the car sounds phenomenal.
https://www.instagram.com/p/BkiMud_D...ns_share_sheet
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
gtengr (12-05-2018)
Old 12-05-2018, 11:24 AM   #88
Lantanafrs2
Of course they require tuning. I'm asking about the runner/plenum configuration.
Old 12-06-2018, 01:41 AM   #89
steve99
Creative solutions are needed to tune trumpets, when both your MAP and MAF sensor are gone
Interesting will need to be creative if no maf or map sensor used. What are they going to use for metering Air into engine with no pressure or flow data.
http://greddy.com/products/Special+V...rtnum=11910200
The info here suggests its compatable with stock intake so appears you could use maf, then second option was ecutek speed density which wouod use map pressure and temp.
So whats the advantage of using neither maf or map. ?
lutfy (12-06-2018)
Old 12-06-2018, 12:57 PM   #90
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
This kit doesn’t have open trumpets to air, so why couldn’t a MAF and/or MAP be used? Even if it was open to air, isn’t it the norm to tap into each TB manifold and run lines to a distribution block that connects to a MAP sensor?
It is cool, but Motec plus ITB hurts the wallet for those gains. I feel like if he went Motec then maybe more plans are in the works, maybe to do a built high compression and stroked motor running E85. 300whp all motor would be pretty sweet to see.
Old 12-06-2018, 01:04 PM   #91
AxisPower
Drives: 23 GT4RS
Can't use just a map sensor for itbs because the signal isn't very good at partial throttle. Most standalones will use a combination of map and throttle position (alpha n).
AxisPower is offline   Reply With Quote
Old 12-06-2018, 01:18 PM   #92
Wes
Nah we don't have E85 in Canada. Seeing as it's his track car and he competes, he might be able to get a hold of it but I highly doubt it. He did do his baseline on a different dyno, but the new one reads lower than the old one, so his gains are at around 60 whp, which - even if 30 of those could be attributed to his catless header - is mighty impressive
Instagram: @gt86ws
Old 12-06-2018, 02:04 PM   #93
churchx
churchx's Avatar
Drives: 2014 GT86
Impressive especially because with "classic bolt-ons" there is somewhat diminishing returns limit of ~ +40whp, that is hard to get pass. If ITBs will further enable getting more NA gains, even with bad price/performancy, they still might be desirable product imho, even if their sound or throttle response is not primary wish of potential customers. Expensive? Yes. But then again, NA tuning in general is expensive, nothing suprising. If they will deliver that is.
Old 12-06-2018, 03:21 PM   #94
Lantanafrs2
No way you get 20 horsepower out of these things. Especially with stock redline.
Old 12-06-2018, 05:57 PM   #95
RayRay88
Drives: 2017 86 860 Special Edition
I doubt it's 20 but probably close to 10whp/10wtq. He's hitting nearly 180ft/lbs... all this on shitty canadian 91. I imagine 93 would be close to 15/15 over a decent header.
All speculation till we have a more thorough analysis.
RayRay88 is offline   Reply With Quote
Old 12-06-2018, 06:29 PM   #96
Dr. BRZ
Dr. BRZ's Avatar
20/20 would be on e85. Best fuel all around.
Old 12-06-2018, 07:24 PM   #97
Lantanafrs2
E85 gives 20 on it's own.
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Irace86.2.0 (12-06-2018)
Old 12-06-2018, 07:46 PM   #98
Irace86.2.0
60whp gains? Dyno before n after?
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
Delicious Tuning RallySTI User/Vendor/Sponsor Reviews, Feedback, Comments 2 12-02-2017 05:19 PM
Delicious Tuning needs your help! DeliciousTuning Off-Topic Lounge [WARNING: NO POLITICS] 0 08-14-2017 09:33 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
