Old 11-04-2018, 10:02 PM   #85
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Originally Posted by Sportsguy83 View Post
Damn! I'm waiting to hear your feedback on it.
New banjo bolt in, line bled and drove it every day this weekend. The clutch releases in the first 1/4 of the pedal now and resistance is perfect for what I want. It might be a bit too heavy for driving in heavy stop and go city traffic, but its not bad at all. The design of the 7/8 MC is slightly different than the 3/4, the reservoir space sits slightly higher, hitting my recess- it works but not ideal, will be revising the design of the MC recess for future versions.
Also- I can now get reverse while the car is running, however it takes a good bit of effort and the car moves a touch when it does, I think the slave cylinder or clutch may be a bit worn.
Had my wife drive the car for the first time with the new engine, she was smiling and laughing on the back roads launching hard and sliding the rear around corners.
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
Sportsguy83 (11-04-2018)
Old 11-04-2018, 10:05 PM   #86
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by spitsnaugle View Post
New banjo bolt in, line bled and drove it every day this weekend. The clutch releases in the first 1/4 of the pedal now and resistance is perfect for what I want. It might be a bit too much for driving in heavy stop and go city traffic, but its not bad at all. The design of the 7/8 MC is slightly different than the 3/4, the reservoir space sits slightly higher, hitting my recess- it works but not ideal, will be revising the design.
Thank you for the review!!!
Old 11-04-2018, 10:28 PM   #87
all4spl
I just wanted to confirm. did you end up using the second hold for the engine mounts or did you move it to the third one? Also gto or Fbody shifter?
all4spl is offline   Reply With Quote
Old 11-05-2018, 07:25 AM   #88
spitsnaugle
I used second mount holes. Attempted third but didn’t want to hammer the trans tunnel much. Second hole only needed minor hammering around a few points. It’s a GTO shifter, I might replace it with sikky gto replacement shifter.
Old 11-05-2018, 11:41 AM   #89
all4spl
Perfect Everything works in that hole then? is it still required to remove the fuel line shield?
Old 11-05-2018, 11:48 AM   #90
spitsnaugle
I had already removed it and made my own bracket. With some bending it might clear from the second hole, but its tight.
Old 11-08-2018, 12:42 PM   #91
all4spl
When will the new clutch master brackets be done?
Old 11-09-2018, 10:40 AM   #92
spitsnaugle
I'll be working on it some more this weekend, after finding the 7/8 MC is taller than the 3/4 I need to move the MC position down within the recess.
Old 11-12-2018, 05:39 PM   #93
Merc
Drives: Subaru brz 2013 LS1 swap
Quick question in post 67 there's a pic of a red transmission mount didn't see it in your parts list happen to recall which it was. Also thanks for the reverse switch and other such tunnel info really helped cx doesnt show all those little spots.
Merc is offline   Reply With Quote
Old 11-12-2018, 09:38 PM   #94
spitsnaugle
Prothane 7-1604 Transmission Mount Kit -- $27 via amazon. (i'll update my parts list)
And thanks, I was trying my best to document things as I came across them.
Merc (11-12-2018)
Old 11-15-2018, 12:19 AM   #95
spitsnaugle
The engine bay was hot when cruising around. Fixed that.
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post:
CatDaddysBBQ (11-16-2018), ILLSMOQ (12-03-2018)
Old 12-02-2018, 03:55 PM   #96
vijay.dy06
Drives: Red BRZ
Picked up the driveshaft. Got the radiator filled up. Went to install the driveshaft and realized this spot interferes with the U joint.
So I'll be dropping the exhaust tomorrow and cutting that out.
Only other remaining to-do's:
Vacuum Lines
Install lightweight battery (waiting on it to arrive)
Did you end up cutting that part out or will a hammer help give the driveshaft some clearance?
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 12-03-2018, 03:22 PM   #97
spitsnaugle
I cut two straight lines front to back on it, and used a harbor freight spot weld cutter bit on the middle, leaving the very sides in tact, but removing most of it.
You can kind of see the line here. Looking at the top of the trans tunnel around the shifter should also give you an idea to what height the trans should be (roughly) for proper driveline angles.
Old 12-07-2018, 02:37 PM   #98
CokeZero
CokeZero's Avatar
Drives: 2015 brz
What did you do for the wire melting on header? And did the electric fans fix the overheat?
What oil pan are you using?
CokeZero is offline   Reply With Quote
cx racing, ls swap, ls2, pure automotive
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP ILLSMOQ Engine Swaps 172 11-24-2022 08:01 PM
LS2 swap by KAB Customs with Pure Automotive Motec Sportsguy83 Engine Swaps 254 10-17-2018 01:45 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 12:10 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 05:21 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 02:03 AM
