Old 01-05-2018, 03:26 PM   #85
Originally Posted by nickdd6237 View Post
Yes the gtx2860r but they have two different size A/R for it. Im not sure which would be better for my goals.
Do you know what your goal is?
Tcoat (01-05-2018)
Old 01-05-2018, 04:14 PM   #86
nickdd6237
Drives: 09 vw gti
Yea i mentiond it early in the thread but now seeing that i can make more power with e85 280-300tq 350-380hp
nickdd6237 is offline   Reply With Quote
Old 01-05-2018, 04:27 PM   #87
So if your goal is defined, why are you asking about A/R? Your goal should determine your turbo choice.
Old 01-05-2018, 04:30 PM   #88
nickdd6237
Drives: 09 vw gti
Because that turbo comes with 2 different a/r options.
Old 01-05-2018, 04:34 PM   #89
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
I'm not sure you fully understand what A/R is...
It affects spool speed and shifts the power band in the rev range
mjanmohammad is offline   Reply With Quote
The Following 2 Users Say Thank You to mjanmohammad For This Useful Post:
Cole (01-05-2018), CSG Mike (01-05-2018)
Old 01-05-2018, 04:45 PM   #90
nickdd6237
Drives: 09 vw gti
Well here are the sizes for the same gtx2860
COMPRESSOR WHEEL: 45.7 / 60 mm (GTX 11 Blades Billet, Blue Color)
COMPRESSOR HOUSING: Anti-Surge 3" inlet (76 mm inlet) , 2" outlet (51 mm outlet )
BACK PLATE: Blue Color
TURBINE WHEEL: 47.1 / 53.8 mm, (9 Blades) Trim 76
TURBINE HOUSING: 0.72 A/R High Inconel Turbine Housing
BEARING: Arashi Ceramic Ball Bearing
COOLING: Water Cooled System
FLANGE: V-Band
Or
TURBINE HOUSING: 0.57 A/R High Inconel Turbine Housing
FLANGE: V-Band
Old 01-05-2018, 05:26 PM   #91
mjanmohammad
FLANGE: V-Band
Or
FLANGE: V-Band
If you don't know how the basics of how a turbo works, i would highly recommend not building your own turbo kit.
the .72 A/R will spool slower but allow for greater peak power. the .57 will spool faster and shift your power band lower.
The Following 6 Users Say Thank You to mjanmohammad For This Useful Post:
CSG Mike (01-05-2018), JazzleSAURUS (01-12-2018), nickdd6237 (01-05-2018), Summerwolf (01-06-2018), TachyonBomb (01-08-2018), ThatAsianBradah (01-10-2018)
Old 01-05-2018, 10:45 PM   #92
nickdd6237
Drives: 09 vw gti
Think i can reach 350hp with the .57 A/r? Id be happy with that.
Old 01-05-2018, 11:03 PM   #93
redhalo
Drives: MY20 Hakone Toyota 86
Isn't 350 the advised point when you should go with a built engine?
redhalo is offline   Reply With Quote
Old 01-05-2018, 11:06 PM   #94
nickdd6237
Drives: 09 vw gti
Apparently not if u go e85.
Old 01-05-2018, 11:13 PM   #95
ExpertZero
Drives: FR-S 2015 Halo
Nick, can you just buy a turbo kit for everyone's sake.
ExpertZero is offline   Reply With Quote
The Following 9 Users Say Thank You to ExpertZero For This Useful Post:
Alltezza (01-08-2018), arkanist (01-15-2018), Barefootdan (01-07-2018), gtengr (01-06-2018), JazzleSAURUS (01-12-2018), mjanmohammad (01-06-2018), Pete156 (01-07-2018), Summerwolf (01-06-2018), TachyonBomb (01-08-2018)
Old 01-05-2018, 11:51 PM   #96
nickdd6237
Drives: 09 vw gti
lol
Old 01-08-2018, 03:49 PM   #97
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
To the OP.
How much money do you think you will save i'm curious. I know you've talked about saving money to get exactly what you want and how people tell you, you wont. But i have yet to see some real numbers being thrown around.
It sounds like you want to stick under 5000$...Thats fair. But i also saw that you are trying to piece together various parts from various kits. The customization itself is going to take a toll on your budget. Think in the thousands easy. You claimed earlier that you are already 2k in with the turbo, and the manifold. You are almost halfway through with your budget and you dont even have the important parts that will allow your car to even start up much less run properly. You want E85 too? Thats already going to cost you anywhere between 600-800$ depending on who does your tune. If you dyno tune expect to spend another 250-500$. So now you are 3k in from your 5k budget. Ok so piping? Thats another 300$ if you go with a cheap ebay option. Oil cooler? Theres 600$ minimum right there. How about a boost controller? Or maybe something to gauge your boost to make sure you arent over boosting? Thats almost another 700$ right there. And this is assuming you are installing everything yourself. Oh can we mention we havent even finished building your turbo kit yet?
So now you are 5k into your 5k budget, you dont have a complete turbo kit and you've left no room to purchase the other small items you need or to pay for the custom fabrication you are going to need to get all the parts to fit.
And yet you dont want to buy a JDL V2 kit which can be custom to your specs and WITH a Flex Fuel Kit you will be out the door just under 5k. Assuming you install everything yourself.
There hasnt been anything in this thread that has convinced anyone that you know what you are doing. Hell I dont even really know what i'm doing and i still know that buying a kit is not only going to be more cost effective in the short AND long term. But i also know the kit will legitimately work.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 5 Users Say Thank You to Xxyion For This Useful Post:
Cole (01-08-2018), JazzleSAURUS (01-12-2018), Logikal Reazon (01-14-2018), Tcoat (01-08-2018), ThatAsianBradah (01-10-2018)
Old 01-08-2018, 07:01 PM   #98
Cole
Not a troll
Cole's Avatar
Originally Posted by Xxyion View Post
To the OP.
I mean, that's entirely ignoring the fact you can buy an SBD kit for what, 3k?
The Following 2 Users Say Thank You to Cole For This Useful Post:
sid94 (01-13-2018), TachyonBomb (01-08-2018)
Mod ideas? _anthonygd BRZ First-Gen (2012+) — General Topics 42 09-08-2015 07:28 PM
New Here Need Ideas FRStrent Scion FR-S / Toyota 86 GT86 General Forum 30 07-10-2014 11:22 PM
In Need Of Ideas!! bh7990 Scion FR-S / Toyota 86 GT86 General Forum 28 05-19-2014 01:14 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 10:57 AM
Need ideas for possible (new-to-me) used car suprachica79 Other Vehicles & General Automotive Discussions 66 02-20-2012 07:42 PM
