Old 05-30-2017, 09:22 PM   #85
Originally Posted by angadam View Post
I work on heavy equipment and what they do is have a red flashing light that gives you 30 seconds before the engine shuts down. Basically oil pressure, coolant temp, or coolant level it give you 30 seconds.
It may be difficult to incorporate this into our dash without complaints though.
http://www.partdeal.com/murphy-swich...FQgMaQodIPwBuw
Heavy equipment as in highway vehicles or heavy equipment off road?
Old 05-30-2017, 09:33 PM   #86
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
I'm glad things worked out for you. It reminded me of when I had my NB miata years ago, pre FRS release dates, possibly still be dinosaurs. Anyways I had bought it used and didn't check well and noticed the car had a large oil leak(learn my lessons the hard way) long story short I ended up fixing every seal their was in the car and it still leaked. Turned out the filter was cracked and the oil came out of it. $400 dollars worth of fixes for something about $40 Dollars.
Glad it worked out for you.
Old 05-30-2017, 10:40 PM   #87
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by phiflyhigh View Post
So the problem is fixed!!!! It turns out the oil filter the last person put on was either incorrect or wasn't secured hence the ringing/grinding/whirring noise. Anyways after some extensive testing between 5,000-6,000 rpms, no more noise.
I'm kind of amazed that a wrong oil filter only gave you noise, and not an engine bay full of oil.
Old 05-31-2017, 03:20 AM   #88
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Me too. Especially the grinding.
Scrappydoo is offline   Reply With Quote
Old 05-31-2017, 08:11 AM   #89
jasonojordan
Drives: 2013 satin white brz limited
I got really excited seeing a new thread and within the 1st page a new user not the OP with the words BANNED. I read this whole 7 page thread and it was very disappointing in the lack of shenanigans that I was expecting. Then again maybe I'm just spoiled on my local Subaru thread with the level of idiocy that happens there before a thread gets locked haha. I listened to the video and I to could not hear what you were talking about. Glad you figured our the issue. But as many others pointed out, You buy a new car if for nothing else to have a nice warranty. Use it. Especially if you are new to the car world its better safe then sorry and get it looked at
jasonojordan is offline   Reply With Quote
Old 05-31-2017, 11:32 AM   #90
jubella2
jubella2's Avatar
Drives: DGM BRZ
No other forum I've visited has come close to matching the MN shenanigans
jubella2 is offline   Reply With Quote
Old 05-31-2017, 12:44 PM   #91
mav1178
mav1178's Avatar
I mean, the last time I had an oil filter making noise from improper installation, my entire engine bay was up in smoke after a few minutes...
Old 05-31-2017, 03:27 PM   #92
Gforce
Drives: 2013 Subaru BRZ
So driving down the highway and you get a low oil pressure situation and your car just shuts down? OH sounds like a great idea.
If your low pressure light comes on it it either too late or no problem anyway. Shutting the car down automatically is the dumbest idea yet.
So when exactly is the ultrasonic device supposed to measure the level? The level varies with engine speed and temperature.
There is an ultrasonic wave generator that measures the distance to the surface of the oil, continuously. You will recall compression and rarefaction waves from your high school physics (also useful to understand tuned headers, intake runners and variable valve timing) and SONAR from reading about WWII submarine warfare. Same technology.
The resulting signals are processed continuously and if the actual level drops below the factory preset safe level (obviously some distance below the low mark on an analog dipstick) the warning is displayed. Most will not display oil level at all to the driver unless certain parameters are met: parked level, engine off for x minutes and not too hot.
There are also microwave versions (a type of RADAR) and thermal types (oil surface temperature will be slightly hotter than the air above it.)
Gforce is offline   Reply With Quote
Old 05-31-2017, 03:47 PM   #93
Yep. We have used them at work for static oil tanks for a couple of decades and they work great for that. Car engine oil levels are not static and the use of such a system would not work well while operating. If it was just to be used when the car is stopped, level and the oil at a certain temperature then sure maybe it would be fine but then it is just adding unnecessary tech and expense when a dipstick will do the same thing under those conditions. As far as a warning of low oil pressure (no matter what the cause) while the engine is running goes, gauges and idiot lights have worked fine since the car was invented.
Old 05-31-2017, 08:19 PM   #94
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Of course. Slow night?
Old 06-01-2017, 11:56 AM   #95
bababooey
Drives: BRZ SWP Limited -6MT
i too didnt hear funny noises
Old 07-10-2017, 07:10 PM   #96
angadam
Drives: 14 BRZ Limited
I guess it would be considered mostly off road but some street sweepers as well and airport maintenance equipment. The 30 seconds is to allow you to pull off to a safe area.
angadam is offline   Reply With Quote
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Major service Fletchlives78 AUSTRALIA 18 03-08-2017 05:22 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
Known Major Issues I should know about.... Darkone BRZ First-Gen (2012+) — General Topics 41 01-04-2017 09:51 PM
Major Mods.. Jaden Scion FR-S / Toyota 86 GT86 General Forum 72 08-28-2015 10:16 PM
