#85 |
Drives: None Yet
1LR-GUE hahaha!!!
#86 |
Drives: Honda Fit
#87 |
4G63 & Rotary
300-400 hp? Maybe for starters. This damn thing better get some fast aftermarket support or a swap will be in order. I want it to take over where my RX-7 is now. The RX is moving onto bigger and better things (BatMoWheel). And once she does there will be a vacancy, for upper 500rwhp, in my garage. lol
:happy0180: |
#88 | |
Drives: Honda Fit
No offense, but are you sure that the FT-86 is the right car for you? Why go for a car that is all about lightness and handling when what you want is HP? One would think that you should go with a car that is faster to begin with and modify from there. Cheers. :happy0180: |
#89 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
#90 | |
86 Member
#91 |
The Fail Boat
Drives: CWP S.B.
#92 | |
Drives: free Hyundai, 2006 Kawasaki ZX6R
Who said girls don't know nothing bout no stinking cars?! |
#93 | |
Drives: Toyota
#94 | |
86 Member
#95 | |
Drives: Honda Fit
Because power does not come with zero added weight. Because there is such a thng as too much power (this is car guy heresy, I know ).Because a really cool $22,000 car might be a car with the right balance of usable power and low weight. Because if you really want 500+ hp, there are, like I said, better cars to start with. Because if you really want 500+ hp, something tells me that you want to go in a straight line and run the quarter mile. So, you don't need a light car that handles well; you need a car that will keep the power wheels on the ground.Because . . . I don't know. I'm just thinking out loud here. 250-265 hp and a torque number that begins with a "2" would be awesome on a less-than-2500-lb. car. |
#96 |
Drives: Toyota
I do not think 300 PS from turbo worsen the cars balance and handling, and with 255 tires it should not have any problems putting its power to the ground, all this for 1000 kg stripped down car. Take an M3, you won't have it lighter than 1400 kg, but more power won't be controlable, just look at the G-Power M3's.
#97 |
Drives: '06 AM V8V Coupe
Again I'm really sorry but some of you guys have zero understanding about what the maximum torque figure actually means.
A high revving engine will be geared to take advantage of the maximum horsepower. The "lack of torque down low" some people complain about tends to be BS, if you just look at the max. torque curve. If you want max. power at a lower rpm, that's actually worse, because it means the engine efficiency drops faster at high rpm. Max torque means very little when the more sophisticated variable valve timing systems come into play, because the engine can more or less be optimized for multiple rpm ranges. The only thing you can read from the max. torque figure is if the engine is performance oriented, then it gives some kind of indication of how efficiently they were able to use the displacement. Even then, the difference is generally pretty small. The moral of the story is, max horsepower means a lot more than max torque, because max horsepower (with weight considered) is what gives the manufacturer the ability to make a faster accelerating car. |
#98 | |
Drives: Honda Fit
Duly noted. |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 05:10 PM |
| Toyota MR2 motor swap | Abflug | Other Vehicles & General Automotive Discussions | 18 | 01-12-2011 06:12 PM |
