Old 01-18-2017, 12:08 PM   #85
slowest86
Drives: slow frs
Does anyone happen to have definition files for the flexfuel maps in romraider? I have the flex fuel kit. My idol is all jacked up, I have told shiv about it a few times and gave him data logs but no updated maps were sent to me. I have asked him for the definition file for a D00C rom but no response. It seems like he has gone off the grid. It would be a waste of money for me just to disconnect the kit and go back to a stock map. My main problem is when I start the car off and give it gas the idol dips so low the car feels like its about to stall. Thats with all the accessories off like A/C, lights ect... When the A/C, OR lights are on the idol fluctuates so bad.
slowest86 is offline   Reply With Quote
Old 01-19-2017, 01:10 AM   #86
steve99
send me the rom, ill have a look I suspect its an A01G rom internally, but some of the tables are offset from stock A01G def and extra tables added.
you might want to log tune and make sure the LTFT is not 20% or something nd the AFR is arround 14.7 at idle. It might be that the flex kit is not hooked up properly.
Old 01-19-2017, 12:03 PM   #87
slowest86
Drives: slow frs
whats the best way to send that to you? My datalogs are good And I know I installed the flex fuel kit correctly, its just this idol manly thats causing me problems.
Old 01-19-2017, 06:27 PM   #88
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Figured out what was wrong with the idle. Just email me the tune file you are currently running and I'll fix it
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (01-19-2017)
Old 01-23-2017, 12:43 PM   #89
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
So is the kit and tunes still being tested? I see you can purchase the kit on Openflash's website, really considering picking it up.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 01-23-2017, 02:02 PM   #90
Shiv@Openflash
Drives: 2013 FRS
Yes, we still offer free OTS maps for NA cars running our flex fuel kit This is assuming you don't have any unusual mods like 3" MAF pipe, non OEM intakes, etc,.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
Allch Chcar (01-23-2017), Bowen (01-23-2017)
Old 01-26-2017, 10:55 AM   #91
Aussie
Drives: 2013 Scion FR-S 6MT
Shiv sent an update for my A01C FF Stage2 tune. The result is a more stable idle especially when the AC kicks in. The ECU is still learning but it is a nice improvement over the base FF tune I was using.
Aussie is offline   Reply With Quote
Old 02-04-2017, 06:27 PM   #92
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
[ame="https://www.youtube.com/watch?v=D4-Vx_BM9hU"]OFT Flex Fuel Install: Electric Supercharger - YouTube[/ame]
Here's an install video for the OFT Flex Fuel system
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (02-06-2017), Teseo (02-04-2017), Yoshoobaroo (02-06-2017)
Old 02-06-2017, 12:31 AM   #93
Turdinator
Señor Member
Turdinator's Avatar
Are the OTS flex fuel maps editable like your normal maps?
1974 TA22 Celica
2013 86 GT
Old 02-06-2017, 12:55 AM   #94
steve99
yes they will be editable,
you will just need to corresponding definition file as the flex fuel coding moves a couple of the standard tables a few bytes and thaier a a few additional tables to control the flex fuel timing fueling and cranking pulse depending on E%
Turdinator (02-06-2017)
Old 02-06-2017, 10:45 AM   #95
pancake
Drives: 2015 BRZ Limited MT
Is it OK to run the OTS flex fuel tune for a while (similar to Stage 2 uel)? Or is it just to use while you wait for an e-tune?
pancake is offline   Reply With Quote
Old 02-06-2017, 12:04 PM   #96
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Is there any downside to disconnecting the stock evap sensor?
I saw some other kits provide the option to use the rear O2 sensor wire as well.
Old 02-06-2017, 07:30 PM   #97
steve99
no
with the flex fuel tune the ecu is expecting a signal into the ecu from the flex fuel kit/sensor that tells ecu the current ethanol percent. dont run the flex tune unless yo have flex sensor kit installed and connected to ecu
Old 02-06-2017, 07:35 PM   #98
steve99
the evap pressure sensor is part of the emissions control system so it will be disabled when you run a flex kit input to the evap . This system is not even fitted to out cars in Australia, so appears their would be no downside, other than you may have a "fail/not ready " indication on an emmissions test.
connecting to the rear 02 disables the rear o2 sensor and this is used by ecu for cruise fueling. this may result in slightly worse cruise fuel economy. It will also cause a fail/not ready indication on emissions teats.
the evap connection is generally prefered, although the rear 02 is slightly easier to connect to, hence rear 02 kits are generally a little cheaper as you dont need the ecu harness, but you can cut and splice wiring if you dont want to buy the ecu harness its not that hard.
End of Summer Sale! OpenFlash tablet+OpenFlash Header+OEM Gaskets Shiv@Openflash Engine, Exhaust, Bolt-Ons 2 10-01-2015 07:25 PM
FS: New Openflash Tablet, New Openflash Header, New Ducktail Spoiler, NewCrawford BPB FT86POWER Engine, Exhaust, Bolt-Ons 5 09-16-2015 04:26 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
