#85 |
Anybody else here use anti-sieze?
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
#86 |
TRACKBREAD
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes
The OEM nuts suck. I haven’t had trouble with any studs, but I had 3 nuts that were going crunchy. Replaced then with fresh Mutekis and later Gorillas and threading had been smooth ever since. Only reason I got the gorillas is because I preferred the look of the closed end.
It’s probably not the only factor but I’m sure it helps keeping the threads clean. I wish everyone just used lug bolts, so much less hassle. |
#87 |
I've been using anti-seize for almost the entire time I've had the car (2014). I think factory wheel torque is 89 ft-lb, and I just use slightly less at 85 ft-lb.
My front wheel studs are extended ARP because I use wheel spacers only in the front, but the rear studs are still original. I swap wheels for each of the 15-20 autox/track weekends every year. Before switching to extended studs, I had been using McGard splined wheel nuts, but I've been using Muteki SR45R since 2017 when I installed the ARP studs in front. The car just hit 60k miles - also still on original TOB. Not everything's as bad as it seems on the forums. |
| The Following 2 Users Say Thank You to AFRichZC6 For This Useful Post: | SCFD (07-20-2021), strat61caster (07-23-2021) |
| WTB WHEEL STUDS | TomShugoy | Want-To-Buy Requests | 0 | 02-08-2016 07:44 PM |
| ARP Wheel Studs | FR-S Matt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 11-09-2015 07:50 PM |
| ARP Wheel studs and 10mm hubcentric wheel spacers | S1CNSTY_SUBIE | Wheels and Tires | 3 | 04-17-2015 09:31 AM |
| WTB OEM Wheel Studs | Anthony | Want-To-Buy Requests | 8 | 08-27-2014 04:22 PM |
| Meeting with Subaru field engineer in two weeks | Subie | Issues | Warranty | Recalls / TSB | 35 | 02-25-2013 02:50 PM |
